Results 1 to 9 of 9
    Feb 07 2012
    Springfield mo
    Please help me with info on swapping heads
    My moms 97 a4 quattro needs a replacement head and I need to know if the 2001 head will work in her block her head code is aeb. I know you are going to say search but I'm at work and I'm not able to right now. Please help
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Any 1.8t head will work on any 1.8t block. You will just need to make sure that the correct cam tensioner and cam pulley are being used for the motor it is on.
    Active Member Two Rings builditup's Avatar
    Feb 24 2011
    beaver PA
    I m the guy you are trying to buy the head from. I found this info while searching not sure if it true or not...Any help would be great so i can ship this head out and help him out. Thanks
    The head that is on my cousins 2001 1.8t is an AWM so the list is true so far.
    97-99.5 = AEB (Large-port head, forged pistons, 20mm wristpins)
    00 = ATW (Small-port head, same bottom end as the AEB)
    01 = AWM (Same head casting as ATW, but uses a VVT controller instead of a standard cam tensioner, and uses a 06A block, with cast pistons and 19mm wristpins)
    Feb 07 2012
    Springfield mo
    Yours is the awm right so that wrong work in my application if I'm reading correct for a bolt on and go application
    Feb 26 2010
    NOVA
    if you have an AEB it is best to find another AEB, there will not be a drop in and go solution unless you get another AEB.
    Feb 07 2012
    Springfield mo
    An atw head should just go on though right
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    2001 AWM head would work fine, drop in and go. You could swap the tensioner if you wanted to (easy), but just leaving it unplugged will work fine. Then you'll need to block off the SAI port (or make sure it comes with the combi valve and just leave it attached to plug the hole). You'd also need to change the shutter wheel for the cam sensor with the one from the old head. The intake manifold ports will be a little mismatched, but I doubt it would be noticeable on a dd anyway.
    So, it would certainly work if you had to, but getting another AEB head would be ideal.
    2001 Laser Red A4 1.8TQM, APR 93, 710N, electronic oil pressure gauge, B6 Sport 17's, OEM Sport Shocks, H&R Sport Springs, My 5-Speed Swap
    Need to borrow a Cam Chain Tensioner Tool? Just pay shipping ($4 total). PM me.
    "If i had a manual for my commuting, i would literally...LITERALLY...kill myself in the face. Kill myself dead... right in the face." -toaster
    Feb 08 2011
    Murrieta
    Quote Originally Posted by Futurerider103 View Post
    It can be bolted on, you would just have to swap the cam chain tensioner and cam pulley from your AEB head. Then get a transition intake manifold gasket if you plan on using the AEB large port intake manifold on the small port head.
    Active Member Four Rings
    Jun 23 2010
    Athens, PA
    I have an AEB head in awesome condition. Can send you a picture if you're interested. It's practically brand new. It also has a new cam chain tensioner on it with less than 1,000 miles
    Complete '98 A4 1.8TQM PART OUT
    Stock 16" Wheels w/ BRAND NEW tires
    Goodyear Eagle LS2 Grand-Touring 17" tires- NEED GONE!
    PM ME!
