Page 1 of 3 123 LastLast
Results 1 to 40 of 83
    Active Member Two Rings jkash31's Avatar
    Jun 14 2011
    WI
    Air Intake padding
    Just got a new K&N drop in and a 034inlet, I know some people have taken out the noise reducing padding in the stock box for a bigger turbo "sneeze" as i like to put it. - Is there any pictures or instructions on how to do this? I searched the tech area and couldn't find anything, and I really didnt want to start taking apart my air intake.
    Active Member Three Rings yungcotter's Avatar
    Jun 09 2010
    queens New York
    I just ripped mine out. Theres a plastic piece holding it in pop that off and pull out the padding.
    06 A4 2.0T, Quartz Gray, Quattro Tiptronic.
    APR Stage 2,RS4 Rear Sway bar, Carbonio Intake, Smoked tails,
    Hawk HPC ceramic pads, Zimmerman cross drilled Rotors, Tyrolsport rigid caliper sliders AWE Exhaust
    S-Line Trunk, Podi Boost gauge, Hard wired Passport 9500ix, HiD Projector Retrofit
    -Theo
    Active Member Three Rings Jay-Bee's Avatar
    Feb 25 2011
    North Alberta
    Quote Originally Posted by jkash31 View Post
    Good luck getting the filter in then.
    Once you open it up it's pretty clear, not hard.
    -Jon
    2007 A4 Avant 2.0TQM
    Jun 14 2011
    WI
    sweet, thanks guys.
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    lol you're definitely going to need to. The hardest part it dealing with the overhead (grill to box) tube, and you need to take that out to do the inlet pipe.
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Jun 14 2011
    WI
    yeah that grill to box is easy, I had to do that for my headlights. I just ment I didn't want to start ripping apart my box. lol
    Senior Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-350 Super Duty, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    No one wants a ripped open box...sorry, couldn't resist. I took mine out, this is before I put the Carbonio in. It definitely adds a deeper "tone" to the intake if that makes sense.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage II+, APR HPFP, JHM 4:1 Center Differential, Carbonio (APR) intake, AWE Tuning FMIC, 034 Motorsport turbo inlet pipe, BSH catch can, OEM "D" DV, APR test pipe, Neuspeed exhaust, H&R coilovers, ECS Stage 4 BBK with Pagid pads, RS4 rear sway bar, Neuspeed short shift, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas and H&R Trak+ wheel spacers
    Jul 13 2011
    Huntington Beach, CA
    can this process be reversed, or do you have to break some clips etc to remove the assembly?
    Registered Member Two Rings
    Apr 21 2010
    G35 coupe, B7 A4, MK3 GTI
    PA
    Quote Originally Posted by bnish View Post
    The lattice holding the foam in place is plastic welded to the airbox if i remember correctly so it's not easily reversed.
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    It's things like this that make me happy I no longer need to worry about revision DVs, upgraded PCV systems, opening air boxes, or basically anything that has to do with fucking about on the stock motor
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Senior Member Four Rings shiro1745's Avatar
    Jul 26 2009
    dishwasher
    South Jersey
    Don't do it. U won't get any extra noise. Ask me how i know.
    Full Apr tune stage 2+ - K&N custom CAI - Treadstone TR6 FMIC (Greddy piping) - APR HPFP - VMR TP - Milltek Exhaust - H&R/Bilstein suspension - VMR v701 19" - RS4 sway bar - Apikol snub mount - Revised piston DV - Short shifter - AWE boost gauge - Votex 3 piece trunk lip - Cupra lip - LED interior - De-badged
    Oct 14 2009
    Robins AFB, GA
    Removing the hood padding adds the most noise
    -Shane Drake
    DRAKLOREs Build
    Active Member Three Rings Ed Gein's Avatar
    Sep 21 2011
    is nonexistant
    Location, Location!
    Quote Originally Posted by DRAKLORE View Post
    what does this involve doing?
    2008 Ocean Blue A4, Turbo, AWD
    REVO stage 2|2.5" test pipe|B8 DV|K&N drop in|NewSouth boost gauge
    Oct 14 2009
    Robins AFB, GA
    5 mins at most. 6 plastic pins or so, push them together and pull them out
    -Shane Drake
    DRAKLOREs Build
    Sep 21 2011
    is nonexistant
    Location, Location!
    thanks
    Jul 19 2011
    probably going to do this tonight when I do my cam follower
    359awhp/K03-GT
    Senior Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    I just yanked mine out, it wa nice when the box was clean inside, whenever there was sand, animal nests, leaves in there it would rustle around and be super annoying. So I just bought a p flow cone the other day strapped it onto the maf/ custom heat shielding. Sounds much better.
    Team ACE - CT
    Jul 26 2009
    dishwasher
    South Jersey
    Correction, removing the hood itself adds the most noise LOL
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Linden, NJ
    Quote Originally Posted by shiro1745 View Post
    Correction, destroying your DV adds the most noise. Psssssshhhhhhhhhhhhhhh...
    Hubert Sobon
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 800.877.7033
    Email: hubert@europaparts.com
    COUPON CODE: HUBERT
    Active Member Three Rings mec's Avatar
    Jul 25 2010
    Denver, Colorado
    how do you know?
    2006 / A4 Brilliant Red / 2.0TQM /
    AG M310 19x8.5 / KONI FSD / APR / 034HFC OEM RS4 catback/
    HPFP /s1 pump 145 PRV/ A3 RNS-E Retrofit/
    Senior Member Three Rings grassrootz's Avatar
    Apr 01 2010
    North Jerz
    Quote Originally Posted by Hugh@EuropaParts View Post
    All day whhoooosshhh. STi type whoosh..even better with the WOT pppssssshhhhh.
    -GrassRootz
    Jul 26 2009
    dishwasher
    South Jersey
    how do you know?
    I read a lot LOL
    Active Member Two Rings soleam87's Avatar
    Apr 07 2011
    Slow ass B7 on Merc wheels
    Florida
    Hey Shane, other than the noise, any other side effects from take the sound deadener off (i.e., paint flaking, warping)?
    F.T.W.L.T.B.D.W.I.C.T.W.
    Jul 13 2011
    its intended use is not to deaden the sound. its supposed to put out a fire in your engine bay if you ever get one. i took mine off on my gti like 10 years ago and it didnt ruin the paint or anything
    Jul 25 2010
    Denver, Colorado
    I just removed my firewall, definitely added more turbo woosh.
    Feb 20 2004
    Fridge full of Beer
    Marion, IA
    Umm....no heat suppressant on the hood?
    -Dan
    2007 Audi A4 S-Line Ti - JoM, Carbonio, Ecodes, RS4 Black Optic Grille, Tint, whole bunch of APR stuff, Forge, and AWE stuff, Devils Own Methanol Injection, just your run of the mill B7 that's been "tinkered" with
    Sep 21 2011
    is nonexistant
    Location, Location!
    I pulled it out today and noticed no difference :(
    And to everyone who thinks its to protect the paint its not. It dosent get that nearly hot enough under there to do anything to the paint lol
    Jul 19 2011
    I took my padding out of my air box last night and hear no difference at all. And for those of you that think it will be just unclipping a couple things... it's not. I took the box out, threw a long allen wrench down the skinny hole, beat it with a hammer, and that's how I got those damn clips out.
    Oh well, it just had some dirt on it. They didnt make changing air filters the easiest thing on our cars did they?
    359awhp/K03-GT
    Apr 07 2011
    Florida
    Quote Originally Posted by CorneliusRox View Post
    Remove airbox, and oem filter, replace with any dry cone filter. And boom, you have a "custom" intake with your spooling noise...
    Approx $20 and about 10 minutes.
    Jul 19 2011
    frees up some room too. Why didnt you leave the stock heat shield?
    and what size OD does the cone have to be? do you know off hand?
    359awhp/K03-GT
    Apr 07 2011
    Florida
    Heat shield came off with the box, I just never thought about it. IIRC, I think 3" cone, If anything just use couplers to size up or down. Cleaning the intake now is a breeze.
    I now have a 034 TIP heat wrapped just like the pictures stock inlet pipe. It doesn't really make a difference as far as heat sink, Our cars are still gonna get heat sink no matter what, unless you get a fmic
    Jul 19 2011
    Quote Originally Posted by soleam87 View Post
    I might do this this weekend
    359awhp/K03-GT
    Jun 14 2011
    WI
    not to be a dick, but your inlet hose looks like foil and cheap.
    Jul 26 2009
    dishwasher
    South Jersey
    After I'll change my timing belt I'll get some logs with
    1. the stock air box on
    2. the custom CAI I have on
    3. the Cone filter sitting in the engine bay with no heat shield
    and be put and end to all these speculations. I'll record boost, IAT, MAF, but my question is how I get logs for power or torque with VAG-com? cause at the end I guess that's all that matters.
    There's probably no accuracy in logging power numbers with VAG-com on a modified car ??
    EDIT: but ^ this option is the easiest and cheapest I've ever seen. Doesn't look bad either. So instead of getting a ~40 K&N drop in just get a ~40 cone filter, nice...
    Jul 19 2011
    I started a thread where someone already did this. It was called something like 'restrictive oem air intake'. Turns out that our OEM air boxes flow better (more and colder) air than the cone. At least with our K03's and I would assume with a K04 and K0R too. BT you would probably want a cone, and vented to the pass side SMIC since you would probably have a front mount by then
    359awhp/K03-GT
    Active Member Two Rings Philthy's Avatar
    Nov 10 2010
    Wildwood Mo
    I yanked the padding off both the hood and inside the airbox as soon as I got the car. The airbox padding is meant to suppress noise, but I don't think the effort was worth it. I just hated the way the padding under the hold looked, plus I clean my bay constantly in the summer and it got wet and looked worse...ran without it for over a year through summer and winter with no ill effects to paint.
    Sep 21 2011
    is nonexistant
    Location, Location!
    I thought for a sec about doing the cone mod too but I think if anything it would just suck in hot air rather than the well flowing oem box that gets its cold air through the grill....
    Feb 07 2010
    Wilton, CT
    My setup is same as soleam86 but i went for a cleaner look (no offense) I love it every bit and sounds awesome!
    Here's my build thread if your interested : http://www.audizine.com/forum/showth...04#post7268304
    Team ACE - CT
    Sep 21 2011
    is nonexistant
    Location, Location!
    I like the open one more, no offense.
    Senior Member Three Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey Finest
    ^ open "may" look better but the intake is completely exposed to heat radiating off the turbo & CAT. Basically making this a HAI.
    Sean
    The New
    B7---BBS--DDM--StaSIS SS--EBC GreenStuff --034--more in the werks
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
