Results 1 to 30 of 30
    Active Member Two Rings robstitzer's Avatar
    Jul 18 2011
    Wilkes-Barre, PA
    Help! Any idea what this is??!!
    08 A4 SE. Stage 1 AWE/GIAC Chip. APR Test Pipe. H&R Springs. RWerks LED Tails. Hoen Yellow Fogs. Blacked out front/rear rings. Debadged. 40% Tint all around. H&R Spacers F 10mm R 15mm. Emils LED kit.
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    Just looked at mine the other day when I did my brakes and it looks the same! Does yours have a slight smell to it?
    I am going to do a flush soon because of it....
    Let me know what you find
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Jul 18 2011
    Wilkes-Barre, PA
    Reading online it says this is usually contributed to a leaking head gasket... I hope not! I just had my piston rings replaced!
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    its a coolant resevoir...
    haha jk, looks like you are getting deposits in your coolant from something.....
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Jul 18 2011
    Wilkes-Barre, PA
    Quote Originally Posted by DRAKLORE View Post
    Hahaha.. I talked to the tech that worked on my car. Since he had everything apart to replace the piston rings.. he said it's usually sediment from the lines and things.. they usually try to get it all out, but I'm taking it down and having it cleaned out.
    I'll tell ya what though... car runs GREAT after having the piston rings replaced. I also had a new N80 and BSH PCV block off installed. ..
    Jul 19 2011
    I hope not either, and I really doubt it, but if I need to do a head gasket, I might just save up an extra $2k and throw in some rods/pistons/studs while I'm in there
    How many miles are you getting before your oil is low now after the rings?
    359awhp/K03-GT
    Oct 03 2010
    Did Audi replace your rings or did you do it on your own? If on your own, what did it run you?
    07 A4 2.0T Quattro 6 spd. manual S-Line
    Active Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Quote Originally Posted by CorneliusRox View Post
    Either I am lucky or I don't get it. I read thread after thread about burning oil, but mine doesnt burn shit....(knock on wood)
    Active Member Four Rings wildcat333's Avatar
    Feb 25 2011
    2009 Suzuki GS500F
    Seacoast NH
    Quote Originally Posted by Inked View Post
    Lucky.
    2008 Audi A4 2.0T | S-Line | Quattro | Automatic-Tiptronic | GIAC 93 | 35% Tint | KW V1 Coilovers | Evolution Thor Skid Plate | 6000K Bi-Xenons (DDM) | Clear-Corner Mod | Clear Sidemarkers | Hoen Endurance Fogs | LED DRL's + 6OHM/50W Resistors (Krauto Parts c/o Emil) | 6000K LED City Lights + 25OHM/25W Resistors (V-LEDS)
    *Pics of my car/ projects/ installs*
    Jul 19 2011
    x2
    I make at least 5k before a low oil light (and that's if I run not so premium oil).
    359awhp/K03-GT
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I have never had a low oil light in 165k miles
    Jul 19 2011
    Quote Originally Posted by chrislane31 View Post
    You have gone 165k without an oil change?!
    359awhp/K03-GT
    Senior Member Four Rings shiro1745's Avatar
    Jul 26 2009
    dishwasher
    South Jersey
    Quote Originally Posted by robstitzer View Post
    Let us know if after you clean it you get the same deposits.
    Full Apr tune stage 2+ - K&N custom CAI - Treadstone TR6 FMIC (Greddy piping) - APR HPFP - VMR TP - Milltek Exhaust - H&R/Bilstein suspension - VMR v701 19" - RS4 sway bar - Apikol snub mount - Revised piston DV - Short shifter - AWE boost gauge - Votex 3 piece trunk lip - Cupra lip - LED interior - De-badged
    Mar 24 2007
    At 5000 miles for an oil change I do not get a low oil light. The low oil light is not the change oil light.
    Jul 19 2011
    wait, there is a change oil light at 5k? What does it look light?
    359awhp/K03-GT
    Mar 24 2007
    No there is no oil change light. You made it sound like the low oil light has to come on at 5k miles.
    Jul 19 2011
    oh, no sorry. I have thrown in different oils to see how they like our hot turbo's and junky rings. Most go past 6k, but a couple I have only made just past 5k. (I know it isnt great on the pump, or my cam's, but I'll deal with that)
    359awhp/K03-GT
    Mar 24 2007
    I have a 2005.5 so I think I have the wossner type crown pistons and have always ran Mobil 1 0W40
    Jul 19 2011
    Funny how the 05.5's seem to get better life out of the piston/ring setup. I have moble1 in it right now. I am going to try rotella next
    359awhp/K03-GT
    Senior Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Not everyone burns oil... nor should they.
    Jul 19 2011
    Quote Originally Posted by Sprode View Post
    I know that. Unfortunately, on these cars, almost everyone does.
    ^Fact^
    359awhp/K03-GT
    Jul 18 2011
    Wilkes-Barre, PA
    Quote Originally Posted by shiro1745 View Post
    Will do. I'm hoping to get it cleaned out today. He said a little may come back, but it looks like most of it is cleared up.
    Jul 18 2011
    Wilkes-Barre, PA
    I literally just got it back so I haven't had the low oil light yet. I'll keep everyone posted.
    Jul 19 2011
    Sounds good!
    Also did you just drain your coolant and refill it or did you have a pump/filter/white vinegar flush done?
    359awhp/K03-GT
    Active Member Three Rings Jay-Bee's Avatar
    Feb 25 2011
    North Alberta
    Mine consumes a lot less oil with Shell Rotella compared to the twice as expensive Motul 8100 5w40, and whatever junk the Hyundai dealer threw in when i bought it, not that it really uses up much... i check often enough to not rely on a dummy light... however I have heard Rotella is very thick at extreme temps probably not an issue for anyone who doesn't live in the arctic.
    (it's rating is comparable to a 15w40 oil says right on the bottle) So I blend in some 0w30 German Castrol.
    This honestly seem to be the 'perfect' blend for my car.
    -Jon
    2007 A4 Avant 2.0TQM
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Has the car had G12 in it its whole life? Could be some one goofed and ran the green or orange stuff in there and it got all gunked up and now its leaving a residue.
    Jason
    Jul 18 2011
    Wilkes-Barre, PA
    It's had G12 in it as long as its life... As far as I know. It definitely has since August when I purchased it.
    The tech who worked on the car flushed it and re-added new G12 coolant when he was finishing up the whole piston ring fiasco.
    The "crud" in the tank is a light tan almost foamy looking stuff.
    The tech said when he resurfaces the engine block during the process that some of that crap falls in the bores for the coolant so they have to blow that put and it's not always 100% successful. Apparently it's also common that when you drain and fill the coolant some of that sediment moves.
    Jul 19 2011
    Quote Originally Posted by Jay-Bee View Post
    I run it in my bike (revs to 15500) and it's great, and in my truck (14Quarts) and when it gets below zero, it is a lot of work for the starter to turn it over. It is a lot of engine though.
    359awhp/K03-GT
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    I have two audis and neither burns a drop of oil. Neener neener!
    I wouldn't be too concerned with the sediment myself. It doesn't seem to terrible. Just keep an eye on the makeup and color of the coolant for a then next couple of thousand miles and you should be able to tell if its something worth losing sleep over.
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Jul 18 2011
    Wilkes-Barre, PA
    It seems it was the 08's that were definitely impacted for some reason. It's the only year the techs I'm friends with can definitely say that there is a recognized issue. I'm just glad I got mine taken care of. I wish I took some photos of my valves... They looked pretty cruddy. We're going to clean them up next.
