Results 1 to 20 of 20
    Senior Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    Thumbs down Debadged my car and...
    Debadged my car on Sunday used a blowdryer/floss/goo gone and cleaned the car. Today the car has some dust on it from driving. Perfect outline of the A4 and 2.0T . Wish i would of taken photos but cleaned the car and its gone again. Never had this problem with my B7, anything i can do to prevent this? Anyone have this problem? Suggestions to fix it, can't feel anything on the car
    Here it is clean after i debadged it
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5)/Black OEM caps/35% Tint/Needle Swipe/Fob/Wink & Amber Delete/More VagCom/Black RS Grille & Rings/Hoen Endurance Fogs/ST Coilovers/Debadged/V1 w. Concealed display/More2Come
    Build Thread
    Active Member Two Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Is it still sticky? I use WD-40. Did you wax it afterwards?
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS ECU/Exhaust/Springs/RSB/Rims | K&N Filter | Eurocode TIH/HFIP/IHK/HFC | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | LED Interior/Doors/Plate | 5000K HID Foglights
    Oct 08 2007
    Syracuse, NY
    Not sticky and no WD-40, what did you use the WD-40 for? Just a quick wash and dry after
    Build Thread
    Active Member Two Rings pf_lewis's Avatar
    Apr 10 2011
    2 b8 a4s, one white, one silver
    Bremerton, WA
    Weird, when I debadged mine I blow dryed/flossed/and goo be gone'd it and next wash the outline was completely gone. Was/is the car takin through automatic car washes a lot prior to you de-badging it?
    Active Member Three Rings Highlander1010's Avatar
    Apr 05 2011
    2010 Toyota Highlander Limited
    Bellevue, WA
    Clay bar and wax. Works every time.
    2009 A4 2.0T Tip, Quartz Gray
    APR Stage II|APR Quad Turboback|APR Carbino|H&R Street Coils|H&R 24mm Rear Sway|EC Alu Kreutz|EC HFI Pipe|Stoptech F&R Rotors|Stoptech Street Pad Fronts & Posi Quiet Rears
    3 Spoke OEM S-Line Wheel w/ Paddles|RS4 Blackout Replica Grille|Hoen HD Yellow Fogs|Cool White Interior LEDs|CF Di-Noc Trim|VAG’d|Pirelli P-Zero Neros
    Jan 12 2012
    I used WD-40 to get rid of any adhesive residue. Try applying some wax.
    Peter
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by pf_lewis View Post
    5-8x's max due to the cold NY weather right now
    Quote Originally Posted by Highlander1010 View Post
    Will do this when the weather gets better
    Quote Originally Posted by STA4 View Post
    Thanks, Will do
    Build Thread
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2010 Audi A4 Quattro / 2012 Volkswagen GTI
    Germany/Colorado Currently
    Definitely Claybar and Wax. It will get rid of the outline without damaging your car.
    2010 Audi A4 2.0T
    Engine Mods: EuroCode Tuning High Flow Cat - Lower Intercooler Pipe - Intercooler Hose Kit, APR/Carbonio Intake, 034 Motorsport Turbo Inlet Hose
    Tune: APR Stg II - Fully Loaded
    Cosmetics: OSIR Design Carbon Fiber Front Mask - Carbon Fiber Logo Base - D-trim, 35% tint
    "...every single one of ya'll is TD14LFE." - David@EuroCode
    Active Member Two Rings brinesi's Avatar
    Nov 14 2011
    Yeah, same happened to me on my bb. Took it to my detail / car wash place and they just lightly polished it out.
    '12 P+, S-line, NAV, OEM Sport Package
    HR OE Sports, HR 15mm spacers, 3.2 Grill, Gloss Black painted surround
    Wincos 45 tint, Rieger replica rear trunk lip, VAG COM mods, Festoon LED license plate bulbs
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by brinesi View Post
    Thank you! Off-topic read ur sig, how do you like the 45% tint? Any pics?
    Build Thread
    Forum Moderator Four Rings MiracleWhips's Avatar
    Jun 02 2009
    San Francisco
    Is the outline duller or brighter than the rest of the trunk?
    I am thinking that maybe the outline is the fresh and clean factory paint vs. the rest of the paint that has been exposed to the elements.
    But I agree with others, a clay bar and cleaner wax, but possibly focus on the whole trunk sections rather than just the outline. Blending is the key because black paint is very unforgiving of mistakes!
    STaSIS ECU & 23mm RARB / AWE FMIC & Exhaust / Eurocode IP / Carbonio / 034 TIP / 20% Tint / S5 Mirrors / Rotiform MIAs 19x8.5 / Hankook 255/35 / H&R Avant Sport Springs / RS6 Pedals / Hoen Fogs /Stoneguards / ecodes / A4L Fog grills
    Active Member Three Rings TofuShop's Avatar
    Aug 24 2010
    Fancy Jetta
    +1
    2011 Audi A4 2.0T 6MT
    APR k04 | EuroCode HFC | EuroCode FMIC | Milltek Quadtip Exhaust | Forge DV spacer
    H&R Super Sport Springs | Koni Yellows | EuroCode Alu Kreuz | EuroCode ÜSS
    Podi | Bastuck Valence | Votex Rear Guards | 19x10 Mystery Wheels
    Active Member Two Rings xbimmer06's Avatar
    Jan 23 2011
    MB ML350
    El Paso, TX
    Agree with above Vr...clay the panel and hit with some fine polish (menzerna 4000 or something similar) then fresh coat of wax. Had the same on my brilliant black and looks like black glass now. Best of luck!
    | STaSIS Exhaust | Carbonio CAI | BFI Spacers | H&R OE Springs | HFIC Pipe |
    | HOEN Fogs w A4L Housings | AWE Boost Gauge | RS4 Pedals | S4 Side Mirrors |
    | S4 Trunklid | S-line Side Blades | S-line Steering Wheel | S-line Shift Knob |
    | Aluoptic Eurogear Spoiler Cap | Exclusive Door Runners | Votex Rear Diffuser |
    Active Member Four Rings tenfour's Avatar
    Apr 11 2011
    clutter
    hawaii
    That's what I did. A little bit of clay bar and some wax finish should do it.
    -roger
    current whip: ibis white 2011 B8 A4 2.0T
    VMR (v705 in sparkle silver) x AirRex Air Suspension x Eurocode x Adams Rotors x Stvbek x OEM+ x ...
    former whips: 08 G37s 6sp (sold), 99.5 b5 5sp quattro (sold), 04 E46 M3 6sp (sold that pos)
    Registered Member Two Rings
    Sep 29 2011
    Rochester, NY
    ^^ What they said. Clay it.
    Nov 14 2011
    Quote Originally Posted by Vito Roma View Post
    I'm really happy with the 45 Wincos. There's just an ever so slightly blue hue to it - it's only noticeable in the slightest when staring at a window with heavy sun light going through it and comparing it to the front windshield - even then, it's barely noticeable. I much prefer this to a green hue which many ceramic tints have and it actually makes it look more OEM+. On that note, if you TRULY want an OEM+ look to your tint, 45 is perfect IMO. 30 makes the windows obviously tinted aftermarket. 45 can look just barely aftermarket tinted in some lights but then in most, looks like it's just factory darker. It's exactly what I was after:
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    2007 MBZ CLK 350 Cabriolet
    Miami, FL
    I debadged around 2 years after I bought the car. I used glue gone to remove the residue. I had the same problem, whenever the car got dirty, I could see the outline if the badges. Clay and wax fixed the problem. the paint wasn't even discolored at all - it is completely clean now..
    Sent from my Galaxy Nexus using Tapatalk
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front & Rear Bumpers | S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
    Jun 14 2005
    Irvine, CA
    +1 for the clay bar and wax. I wouldn't use any harsh chemicals when they weren't necessary.
    JB @ VMR | Wheels
    (714) 442-7916 ext. 108 | jb@velocitymotoring.com
    www.velocitymotoring.com | | | Blog
    Jun 02 2009
    San Francisco
    On second thought, complete respray.
    Apr 10 2011
    Bremerton, WA
    Quote Originally Posted by tenfour View Post
    You don't need a clay bay, just pick up some play-doh (jk, please don't).
