    Apr 15 2009
    NY/NJ
    Question thoughts on high milage ATF change
    Hey all
    I'm trying to get quote from few nearby shops on ATF change, and have been reading online about it as well. One of the shops, as well as few post here and there, warned about changing ATF on a high-mileage car that never had it done before due to potential transmission failure. I'm the 2nd owner of my 05 S4 with 86K on it, and never track my car but have pushed it once a month or so. I'm incline to have it changed, because Audi's definition of lifetime doesn't mean forever. But I would like some more opinion on this, especially if someone here had a failure due to ATF change.
    Thanks in advance
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    I am pro ATF change.
    BUT - you MUST change the filter, and it would be VERY WISE to change the filter again 500-1000 miles later.
    I bring this up because a lot of transmission shops just want to hook into transmission cooler lines (or similar) and pump new into it till the other side runs clear - many don't bother to touch the filter.
    The reason people see AT failures after a fluid change is because ATF is a high detergent oil. Replacing the fluid renews all these detergents and ends up cleaning out your valve bodies and grabbing stuff that has settled along the way. This is then caught by the filter, it plugs it up, and the tranny dies of fluid starvation.
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    Best thing you can do is change the fluid and then change it AGAIN about 500 miles later. And yes, change the filter.
    2005 S4 saloon 6MT
    Active Member Two Rings nicotino15's Avatar
    Jul 24 2011
    dallas
    From what I heard from other people I was always afraid of a high mileage flush, I did a drain/refill on my old 98 maxima with 130k miles and drove it until 165k miles with no issues.
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    If you are truly concerned, take it to the dealer and let them handle it.
    2005 S4 saloon 6MT
