Results 1 to 9 of 9
    Registered Member One Ring JHays's Avatar
    Aug 01 2011
    Santa Rosa/ CA
    Head Gasket Blown
    Has anyone ever heard of a head gasket being blown at 78k miles for an 01' S4? Seems a bit early for that to happen. I am looking into getting this car. It now has 108k miles and hasn't had a problem since. Should this still be something to be concerned about?
    Veteran Member Four Rings BlkdoutA4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by JHays View Post
    I wouldn't be worried if the work was done by a reputable shop and the work was all documented.
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    do you think its blown hg or is the coolant just brown? depending on the situation it could be a bad oil cooler if you see oil in the coolant.
    http://img704.imageshack.us/img704/6597/dsc8639.jpg
    00-S4 noggi stg?
    99-M3 vert turbo
    Aug 01 2011
    Santa Rosa/ CA
    Turns out this car has turbos that whine really loud. I definitly am not going to get it. Sounds like too much of money pit.
    Senior Member Three Rings Timtheguru's Avatar
    Dec 30 2009
    There is another thread about the same car from today as well. :)
    Head gaskets are probably fine, either the oil cooler if there is oil in the coolant or they mixed coolants to make it brown. The other thing couldd be the turbos have a seal that is mixing oil and coolant I suppose.
    2001.5 S4
    Aug 01 2011
    Santa Rosa/ CA
    Yeah I saw that thread. I not gna bother with this car. I would rather wait around for something better to pop up.
    Senior Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Stg2 Nogaro, Stg3 Imola, Mk2 gtis X3, volvo s70 turbo
    Michigan
    How much ? Wheres car at
    Active Member Two Rings Taloras's Avatar
    Jan 19 2011
    East Bay, CA
    Quote Originally Posted by Timtheguru View Post
    +1, the head gaskets on our cars are pretty beefy. Something like oil in the coolant/vice-versa is more likely to be something like a failing oil cooler.
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Very unlikely the head gasket went at that mileage. Unless the previous owner was overheating the shit out of the engine.
    StrictlyEuros ::: Web
    J-Fonz Tuning
