Results 1 to 7 of 7
    Oct 29 2011
    2003 Atlas S6 Avant, 2004 Ford F150
    Winnipeg Manitoba
    Angry ECS Tuning Scan tool
    Ok so I finally got my ECS100 scan tool, fuck I hate UPS and will try very hard to never use them again! Anyways I go to hook it up to my 2003 S6 and the way the plastic is molded at the diagnostic end of cable will not allow me to freely hookup to 16pin connector. I was very leery of trying to force it on and cant see anyway that it will hookup smoothly without damaging something or me trimming the plastic off the end. Phoned ECS and all I got for an answer was "there all like that just force it on". Anyone else using this scan tool and what are your thoughts on this problem. I live in Canada and am not thrilled about the idea of going through the hassle to return it.
    Active Member Two Rings tchuck's Avatar
    Apr 11 2010
    2004 Infiniti FX35
    Portland, OR
    Your socket might not be aligned properly in the access opening. Does it look centered and secure?
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    If you are that worried, you can remove the knee bolster (few screws underneath, two screws under the steering trim, and a screw behind the fuse access panel) and the connector will hang freely, allowing you get at it better.
    It shouldn't take THAT much force.
    Oct 29 2011
    Winnipeg Manitoba
    I will check out if its centered and if needed will pull that panel. Thanks hopefully I can get it connected so I can reset service light and get to fixing evap code.
    Senior Member Three Rings ben916's Avatar
    Feb 02 2010
    2012 CR-V (sipping gas while I gulp it)
    ^^^THIS^^^
    03 Audi RS6 Avus, Carbon, Sportec cooling, Frozen rotors, EBC Reds, Aces 4, Apikol, Phaetons, Plus Pedals, Aluminum paddle shifters, KomfortBlinker
    Senior Member Three Rings A6Avant's Avatar
    Mar 09 2010
    T4 Eurovan 2.5L 5spd dope eddition! B5 Passat 1.8T 5spd stock
    Salmon Arm , B.C. CANADA
    x2^^^
    Jeremy-
    1999 C5 Avant 2.8, 1992 T4 Eurovan 5 spd, Slammed and gift wrapped!
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Every single OBD II car has the exact same diagnostic port. They can be a pain to plug in the cable. I have just a basic OBD II scanner I got at autozone and I've spent up to 5-10 minutes just fiddling around with it trying to get it to plug in. I literally would have to get out of my car, push the seat all the way back, lay on my back in the foot well, look at both the cable connection, just to get it to plug in..
    Other times I can sit in my seat and reach down and plug it in in 2 seconds.
    Good luck!
    Jason
