Results 1 to 18 of 18
    Registered Member Two Rings
    Mar 19 2010
    VA
    Any pics of painted rear fog light panel?
    did a search came up with nothing.
    Active Member Two Rings OGBULLYLOCDAWG's Avatar
    May 28 2011
    '01 A6 2.8 Quattro
    NY/PA
    Mar 19 2010
    VA
    thanks for the pics...my car is ming blue and was thinking to color match..what do you guys think? you like the look or prefer how it is?
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    I did mine matte black
    Mar 19 2010
    VA
    Sick car! Vin..blk and white looks good..i dont think it would on my color tho..
    Senior Member Two Rings JediJoker7169's Avatar
    Dec 11 2009
    SF Bay Area/Willamette Valley
    Of course, there's always the delete mod...
    Not a fan.
    Cheers! :-)
    - JediJoker
    "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    - RS4 clutch kit / 710N diverter valves
    - Bilstein PSS9 coilovers / Hotchkis Sport anti-roll bars / 034 Density adjustable front upper control arms / 034 Track Density front strut mounts
    - O.Z. Superturismo LM 18" x 8" / Michelin Pilot Super Sport 235/40ZR18
    - Hella E-code xenon headlights / LED tail lights (ATL-254-LED-CR-LT) / Facelift black rear license plate trim
    Active Member Two Rings JakAzz425's Avatar
    Aug 14 2011
    2000 S80 Volvo, 1974 260Z Datsun
    Tulsa
    Yea don't think I like that look personally... Hey vin do your lights penetrate your paint? Or just no rear fog light for you?
    Active Member Two Rings DJPoochi's Avatar
    Jan 15 2012
    Atlanta, GA
    Quote Originally Posted by JakAzz425 View Post
    I'm curious about this as well.....Is this a light-deletion mod as well as a paint job? Or is this painting over the lights and the rest of that assembly?
    ...and if painting over the lights....is there light-bleed?
    Active Member Two Rings chrisaudi4.2's Avatar
    Jan 26 2010
    paterson nj 07514
    Did mine's shiny black!!
    May 28 2011
    '01 A6 2.8 Quattro
    NY/PA
    Jan 31 2010
    S-Line A6
    East Haven, CT
    No rear fogs. The paint was thick enough to cover it well enough to not let leak through. I've also toyed around with the idea of using spray tint in a lot of coats, then using LED bulbs to shine through, and make it a black LOOK but keeping the rear fogs. (I've since purchased a euro tub, so its back to stock color anyway lol)
    Senior Member Three Rings RaudiA6's Avatar
    Mar 23 2009
    02' A6 2.7T Qtip
    Dirty jERSEY
    Quote Originally Posted by chrisaudi4.2 View Post
    i wrapped mine with glossy vinyl aswell!
    The C5 Union
    Mods: K&N Drop-in/Carbon fiber wrapped interior/Silver Body Black Roof/ Tinted LED tails/98% De-chromed/Yellow fogs/10k HIDs
    --Talon
    May 28 2011
    '01 A6 2.8 Quattro
    NY/PA
    Quote Originally Posted by RaudiA6 View Post
    Do tell!
    any links or locations?
    Active Member Two Rings gbjoshe's Avatar
    Nov 20 2010
    New Kia Optima, Old 2 door benz
    Grand Blanc Mi.
    Hey quick question. How do you guys remove the fog housing from the car? ive done a quick search and the only things that have been showing up is how to add the extra fog light and all that. I want to take mine out to paint it soon so thanks for any help!
    Senior Member Two Rings ilikeaudis's Avatar
    Feb 15 2009
    Manchestrr NH
    ^^^remove the trunk liner. There are two fabric covered screws in the corner, two in the hand hold, and two behind the warning triangle. Then its just clipped in and you pull it out. For the plate surround there are three torx screws along the bottom edge and for bolts that go through the latch assembly. Remove the nuts in those bolts and the screws and pull it off.
    For Sale: Oem 4.2 upper and lower grilles - $100 | 0em all red c5 taillights - $100 | 4.2 rear bumber cover- $350 | Oem 4.2 sway bars|
    May 28 2011
    '01 A6 2.8 Quattro
    NY/PA
    Quote Originally Posted by ilikeaudis View Post
    Here's a DIY (RS6 Spoiler Install) showing the process 'ilikeaudis' describes for removing the trunk liner/
    http://www.audiworld.com/tech/ext60.shtml
    Nov 20 2010
    Grand Blanc Mi.
    Quote Originally Posted by OGBULLYLOCDAWG View Post
    Thanks alot guys. Hopefully its not to much of a bitch to get out
    Feb 15 2009
    Manchestrr NH
    Honestly takes like 5 mins
