Results 1 to 11 of 11
    Jan 31 2011
    My bed and half of my living room
    Fullerton, SoCal.
    120K miles on OEM clutch.
    Hi, I dont post here often, but when I do its because I like you guys.
    now serious point, my car just hit 120k miles with the stock clutch, wondering if its known on the 1.8 engine to fail at that (young) age? I had my bar since 80k, it doesnt slip and shifts well, but I get this feeling like it doesnt hold well from 1st all the way to 3rd...
    any thoughts?
    Active Member Two Rings elsst3's Avatar
    May 15 2010
    b7 avant 2.0t 6sp b7 a4 2.0t 6sp & b6 avant 3.o 6 sp
    Pittsburgh, PA
    That's nothing I have 265k on a 96 a4 2.8 Oem clutch , 02 b6 avant 3.0 with 180k Oem clutch and my dd is a 07 b7 avant 2.0 with 135k on a Oem clutch so keep driving her that's what they are made for.
    Senior Member Three Rings Pothole's Avatar
    Jun 02 2008
    2004 Audi A4 1.8T Quattro 6Spd, 1997 Jetta Trek
    Kirkland Washington
    ^WTF??
    I had to replace my clutch at 34K, and one month after buying the car
    .......im the second owner also
    Please Drive Right
    FS: TT ballast, GTI Stock Springs, 2.0 Cams
    Senior Member Four Rings Elliott's Avatar
    Oct 28 2007
    I've also got 120k on mine. It engages REALLY high but it's always been like that, so I guess it's just the nature of the clutch. Just don't launch all over town and it should last a good while.
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    My brother bought his a4 1.8TQ at 120k miles with a completely broken clutch (pressure plate snapped, disc completely worn and mangled, flywheel *roasted*, what-have-you). But the previous (first) owner was a 20 yr old girl, so that says a lot. It all depends on how it's been treated. Getting to 200k is certainly possible, but is probably the exception - especially on the turbo cars which might see more "spirited" driving styles.
    2001 Laser Red A4 1.8TQM, APR 93, 710N, electronic oil pressure gauge, B6 Sport 17's, OEM Sport Shocks, H&R Sport Springs, My 5-Speed Swap
    Need to borrow a Cam Chain Tensioner Tool? Just pay shipping ($4 total). PM me.
    "If i had a manual for my commuting, i would literally...LITERALLY...kill myself in the face. Kill myself dead... right in the face." -toaster
    Jan 31 2011
    Fullerton, SoCal.
    Thanks I will drive it until it gives, I just thought there was a proper time to change it like the timing belt ;)
    Feb 17 2004
    Round Rock, TX
    I replaced my OEM clutch preventatively around 140k, and 100k+ of those miles were with a K04. Had no issues, and probably would have lasted quite a bit longer based on how the clutch/flywheel looked upon removal
    2002 A4 1.8TQ 5M. 182k+ miles
    FWD-->Quattro swap, Frankenturbo + MTM, Valeo SMFW/clutch, 034 HFC, Mototec exhaust, ER sport FMIC, S4 e-codes, USP front lip, Zender trunk lip, Stoptech 355mm front/B7 S4 rear brakes, Stasis Ohlins SL COs, Neuspeed 21mm RSB, Sportec Mono 10 (rep) wheels, B6 S4 nogaro alcantara front seats, Euro shift knob, JHM short shifter, B7 console, RS4 pedals, OEM brushed interior trim, SII+, TT-S MFSW, color instrument cluster, Alpine PDX-5, IDQ 10" sub
    Senior Member Two Rings ScaryGary's Avatar
    Nov 29 2007
    Silver 04 Audi A4 1.8T 6-Speed
    Sacramento
    when my clutch failed, a few others' on the forum had also failed concurrently. we were all between 60k and 80k miles.
    my other ride is a Rocky Mountain ETSX-50
    Senior Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    GnarCal
    156k on mine. Engagement point is really high too.
    Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Passport 8500 X50
    "I'm talking rip her from her V to her A and back again." - Dan[FN]5857
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Quote Originally Posted by gbeto60 View Post
    any thoughts?
    A failing clutch is going to start slipping in the much higher gears before it will in the lower gears because there is way less load in the lower gears. As for how long the stock clutch will last, that all depends on how you drive it.
    AZ Content Team Four Rings CyberPMG's Avatar
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    It all depends on your driving habbits (and that of any previous owner/owners). As long as you don't feel any slipping of the gears while driving (watching RPMs go up, but no acceleration), it can last for a long time.
    I only upgraded my OEM clutch at 40k miles only because I had a unique opportunity to have my car be a test car for ECS Tuning to make the RA4 kits available. I have the RA4 Stage 2 clutch kit which includes an OEM B5 RS4 clutch and pressure plate and a lightweight aluminum flywheel. It's been holding up for over 160k miles with no issues.
    USP CLUB MEMBER #34
    2004 A4 1.8T USP - GT2871R Eliminator - Unitronic program - ER Comp FMIC - Stoptech BBK & lines - AMS SS - CIM gauge - ECS RS4 clutch & LWFW - ECS LW pulley - RNS-E - RS4 pedals - RS4 e-brake - S4 Bi-Xenon ecodes - 19" OZ SLIII - Bilstein PSS9 - B6 S4 Recaros - more stuff...
