Results 1 to 13 of 13
    Jul 17 2011
    sna jose ca
    Need help with a code
    I have this code stored in the ecu and it wont go away. even after clearing it its still there. check engine light comes on after driving around 100 miles.
    The dv has been replaced with the new piston type. I also have a catch can installed. Iv tested the system for boost leaks. Iv tried pulling the battery
    but did not work. Anybody else have this issue?
    17608/P1200/004608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    Possible Symptoms
    Power Loss
    Possible Solutions
    Check Boost Pressure Control Valve (N249)
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Maybe you should check your N249 valve.
    *ducks
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Senior Member Three Rings flyingfish2626's Avatar
    Nov 23 2008
    2000 Chevy S10 ZR2
    Colorado
    ^^^^^ Pretty funny. Good answer.
    2008 A4 Avant Spec. Ed/Ibis/Oynx/Sport/6-speed
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
    Jul 17 2011
    sna jose ca
    thanks for the help ***s
    Jun 27 2011
    Quote Originally Posted by wick3d View Post
    Well, to be fair, you never said if you'd checked the N249...
    When codes don't go away it usually means they are still active issues...
    -CP
    Jul 17 2011
    sna jose ca
    n249 valve is the dv
    Jun 27 2011
    Nope. It isn't.
    http://www.audizine.com/forum/showth...the-N249-Valve
    Edit, the above link is for a 1.8t, so its sorta irrelevant, but illustrated my point. There is no N249 as far as I know on the 2.0t. The function of the N249 was to allow the ECU to control the DV directly. The DV on the 2.0t is controlled directly by the ECU now (pretty sure here) so the function of the n249 valve is pretty much eliminated. You sure its not the N75 valve acting up? Or that the new DV isn't malfunctioning?
    -CP
    Active Member Four Rings bman005's Avatar
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    How did you test for boost leaks? If your DV was replaced and the fault came back are you sure it was installed properly? It only goes in 1 way.
    05.5 B7 under construction finally
    Jul 17 2011
    sna jose ca
    heres what i found.
    http://imageshack.us/f/714/a38p20tturbo.jpg/
    they changed the valve code names between 1.8t's and 2.0t's which makes it confusing as hell. went to the dealer and he told me the n249 valve is #13 on the picture. but looks like even the dealer cant figure out the code names.
    Senior Member Four Rings fly300kts's Avatar
    Oct 16 2008
    South Florida
    Pretty cool Manual
    Where is this picture extracted from? Do you know?
    Phil
    Jun 27 2011
    heres what i found.
    #13 is the N75 valve, the Wastegate Frequency Control Valve. Number 23 is the Divertor Valve. Weird, I've never seen the DV referred to as the N249 though. In the 1.8t we have a seperate N249 valve which is connected to the DV, but is a seperate part and serves to control the DV.
    I'm guessing the dealer is talkign about replacing the N75, which actually makes some sense given the problem you are experiencing.
    -CP
    Apr 01 2005
    dfw
    On the 2.0T the N249 is incorporated into the DV. It is a single unit (DV+N249).
    ACNA Member
    03 RS 6
    08 A4 2.0TQ
    Apr 01 2005
    dfw
    Pretty cool Manual
    Phil
    ElsaWin
    ACNA Member
    03 RS 6
    08 A4 2.0TQ
