Results 1 to 18 of 18
    Active Member Two Rings force fed's Avatar
    Mar 20 2011
    Albany
    225/40 or 235/35 18's
    I just ordered a set of 18x8.5 st8's from sonic tuning, ray is the man, anyway i wanted to see your guys opinion on tire size. Id like to go a little wider with the 235's for the track. The car is lowered, koni's and springs not coilovers, so its not slammed to the ground. Any one have any pics? Opinions? Thanks
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Pretty sure Bimmerchop was running a 245/35/18 on his 18x8.5's and they where nice and squared off, yet not overly meaty. Might be something to look into as well. I'm sure he'll chime in with a pic.
    EDIT: Sorry Rich Found these from another thread. Pretty much perfect if you ask me.
    Active Member Three Rings sherbet's Avatar
    Jun 26 2010
    B8 S5
    East Bay/ Los Angeles
    Im running a 235/40-18 on my 18x8.5's. If I could do it again I would have gone 245/35.
    FRRG Nothern Ring
    Stage 2 Banner Advertiser Two Rings Sales@EPL's Avatar
    Jun 23 2011
    http://farm5.staticflickr.com/4009/4...02d5829e_z.jpg
    http://farm5.staticflickr.com/4034/4...bf017936_z.jpg
    http://farm5.staticflickr.com/4017/4...bf3e0756_z.jpg
    Can't wait to step up to 255s though
    European Performance Labs
    (203-345-6499)
    Sales@eplabs.net
    http://www.facebook.com/EPLabs
    Please feel free to contact us with any questions!!
    Active Member Two Rings antisparkplug's Avatar
    Jul 29 2011
    Northeast
    sorry to butt-in with a noob question, but with proper wheels at the ride height you guys seem to be running (I have STs.. haven't installed them yet), would I be able to run a 235 or even 245 without rolling my fenders? I've seen a bunch of threads on this, but I've had trouble finding a definitive answer
    '01 S4 Avant 6MT
    '11 S4 6MT (stable mate)
    depends on the offset.. generally no.. you will need to do at least a slight roll on the fronts depending how low you are.
    Rear doesn't need to be touched from what I understand
    Jun 26 2010
    B8 S5
    Quote Originally Posted by antisparkplug View Post
    My car is currently on stasis street sport coilovers and Im not sure what my GTF is exactly, I need to re-measure, but my car isnt super low, and I only rubbed with a full load over large dips , and pretty much ONLY on the highway, in which case, the speed was also a factor. I moved to and from LA and drove the car 400+ miles with a pretty sizeable load and had no troubles either. The Continental DWS have a decent amount of tread depth and are a decently meaty tire for the size so all in all, as long as your not slammed you should be good. If I went lower however, I would roll the fronts just as a precaution. I think bimmerchop has rolled front and rears IIRC. Hope that helps.
    ...yes and forgot to add what Notorious said, offset plays a major role. Mine are +35 for reference.
    FRRG Nothern Ring
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    im running 245-35-18, slight roll in the front no rubbing in front or rear 8.5inch wide not sure of the offset atm. its lowered but not slammed, doesnt rub with anything in the trunk and people in the back seat.
    http://img704.imageshack.us/img704/6597/dsc8639.jpg
    00-S4 noggi stg?
    99-M3 vert turbo
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 07 MKV GLI, 07 F150
    Vancouver, WA
    Can you fit a 245/35 on a 18x8 rim? I really like the look of your car Rich.
    --Mike--
    01 Casa S4
    07 MKV GLI
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by Kruat View Post
    Yeah, they will fit. But they will bulge out a little more than Rich's. I'd go 235's on an 8" wheel.
    Active Member Two Rings ImolaDriv3r's Avatar
    Mar 14 2011
    01 Audi S4, 99 Audi A4, 06 Yamaha R6S
    New York
    I run 235/40 on iForged Aeros 18x8.5 w/ 5mm spacers front and rear...
    EPL Stage III
    Jun 23 2011
    Depending on the suspension setup and wheel specs, rolling the fenders might be needed. My front fenders are both rolled and pulled with the liners trimmed. However, I'm dropped pretty low with an aggressive final offset (not pictured above).
    Thanks! As Vinny mentioned, you should be able to fit that size no problem, it'll just sit slightly different on an 8" wide wheel.
    (203-345-6499)
    Sales@eplabs.net
    Nov 10 2004
    Vancouver, WA
    I run 235/40's now on my B6 Avus's. I just really like that flush wide tire look.
    --Mike--
    01 Casa S4
    07 MKV GLI
    Jun 23 2011
    Same here.
    You sure those aren't 235/40s though, typo maybe? It might just be the angle, but those don't look like they have a 45 sidewall.
    (203-345-6499)
    Sales@eplabs.net
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    I ran 235/35/18 on my b5 rs4 reps that were 18x8 et35 and i though the 235's were perfect. So i think i would do 245 on 8.5" wheel, and 255 on a 9" wheel. Rich's car looks perfect imo.
    Jun 26 2010
    B8 S5
    Quote Originally Posted by Turbwhistle View Post
    on a 9 inch, I'd be going 255/265. Agreed, the 245/35-18 looks perfect
    FRRG Nothern Ring
    Jan 02 2011
    The meatier the better, this summer i hope to try out some meaty set ups.
    Nov 10 2004
    Vancouver, WA
    Quote Originally Posted by Sales@EPL View Post
    Same here.
    Yes sorry, 235/40 not 45's.
    --Mike--
    01 Casa S4
    07 MKV GLI
