Results 1 to 9 of 9
    Senior Member Three Rings JeeprageII's Avatar
    Jul 20 2004
    86 CJ7, 05 Grand Cherokee 5.7
    MA
    B8 A4 S-line suspension same as S4? (Shocks and Springs)
    I am looking for clarification on whether or not the B8 A4 and S4 share the same shocks and springs. The H&R aftermarket part numbers are the same for each car.
    I'm looking for OEM S-line suspension or H&R OE springs, but if just the springs, I'll need stock Sport shocks as well. My car does not have sport package and is really high.
    2009 Audi A4 Premium Plus 2.0t
    2010 VW TDI Sportwagen m6
    2007 A3 2.0T DSG S-Line REVO
    2002 TT 225 Roadster APR 93 * H&R 21mm rear sway * AWE Vent Gauge
    2004 A4 1.8tqm6 REVO big injectors * Neuspeed Exhaust * Ecode FMIC * B5S4 brakes * H&R * 18x8.5" Moven SP10's
    2000 S4 tqm6 Giac/Borla Stage II
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    I believe that there are only two suspensions, sport and regular. Sport is used on Sline, S4, and TI. I could be completely wrong though.
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Active Member Two Rings Jason H's Avatar
    Jan 02 2011
    2000 A4 1.8T Sedan
    Portland, OR
    I would think the S4 front part #s at least should be different. The Bigger V6 has got to weigh more than the 2.0T, seems that the suspension tuning would be different in both compression and rebound damping.
    2010 B8 A4 Avant 2.0T Misano Red/Black | Prestige | S-Line | Drive Select | Side Assist | Sunshades | CPO :: Mods: EU LED Taillights, CXP Carbon Tint, Höen Xm Fogs
    2000 B5 A4 Sedan 1.8T Ebony/Onyx | Quattro, Sport, Xenon, Nav | B6 Sport Wheels, S4 fender liner, RS4 grill, Bilstein Sport, Neuspeed rear anti-sway
    Senior Member Four Rings coolwater's Avatar
    Nov 06 2009
    NYC NY
    S4 shocks/springs are completely different part numbers.
    The s4 springs are 33% heavier than a4 sport springs.
    I had both and I am sure the s4 was stiffer.
    Shocks were different part nunbers compared to a4 ones.
    You can use s4 shocks paired with a4 springs or aftermarket springs made for the a4.
    That's what I did.
    I have OEM sport springs for sale if you are interested.
    Used for 20k and you can see the drop in the earlier pages of my build thread.
    -cW
    2010-A4-Q-TIP / BB - Black Int / Halogen to Bi-Xenon E-code / A5 Sline Y Wheels - Conti DWS
    GIAC ECU Stage 2(-) / STaSIS Exhaust / Eurocode Turbo Inlet / HR OE Sports/S4 Shocks / ALU Accents / LED Bulbs / Fog Rings / Reiger Style Trunk Spoiler
    AR rotors / StopTech Street Pads
    Future Mods: Side Blades / Eurocode HFIP / FMIC
    Build Thread =>http://www.audizine.com/forum/showth...m-build-thread
    Jul 20 2004
    MA
    Quote Originally Posted by Jason H View Post
    I would have thought so too, I knew that was the case on older Audis, but when I looked up H&R part numbers there was no difference. Just bought the car and want to lower it a bit, and maybe eventually get an S4. Debating on doing nothing and leaving it stock, putting on Sport suspension, or getting new springs/shocks or coil-overs and swapping them to an S4 if I do swap cars eventually.
    Used/cheap OEM S-line suspension would be ideal for now I guess. Only interested w/ shocks though.
    Nov 06 2009
    NYC NY
    Dbl check the HRsprings again. I was pretty sure the springs are different for a4 and s4.
    I've seen aftermarket shocks or coilovers be the same for a5/s5/a4/s4.
    -cW
    Jul 20 2004
    MA
    -cW
    A4 OE Springs: 50361-55
    S4 OE Springs: 50361-55
    (pulled from H&R website)
    Nov 06 2009
    NYC NY
    I guess they are the same part number....
    Very interesting. Should sit lower on s4 then.
    Anyway they are good springs. I got em on my ride and love them.
    -cW
    Dec 06 2011
    This is a typical issue with some aftermarket suspension parts, "they" make a general part for all of the cars in the range. If you want a lower car it will be fine, but if you are an auto x guy or are looking for the best handling you are going to want a set up that is made exactly for your car.
