Results 1 to 11 of 11
    Senior Member Three Rings HIS4's Avatar
    Aug 15 2004
    Mililani, HI
    Anybody know anything about KW street comfort coil overs?
    How do they differ from the V1 and V2. Seems like there is some level of adjustability to them but they are cheaper than V2s.
    2011 Meteor Gray A4 Avant - Premium, AMI (retrofit), Bluetooth, Homelink, VAG mods, TunerDomes.com LEDs
    2009 Interlagos Blue BMW M3 - 20" HRE P40, Eibach Pro Kit, Zapco DC650.6, Zapco DC500.1 a/d/s 344is, MB Quart QTD25, Morel ADMW9, Morel Ultimo SC10
    Active Member Two Rings Bells7246's Avatar
    Sep 16 2006
    San Diego
    V1's only change ride height
    V2's change ride ht and rebound
    V3's change ride ht, rebound, and dampening.
    I could have the dampening and rebound reversed for V2 & V3
    Senior Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Deluxe Sunroof Volkswagen
    Northern VA
    A couple ppl around the forum have this setup. I'm sure they'll chime in tomorrow, since they're all passed out after watching the Super Bowl.
    Tschüß!
    Šave
    ____________________________________________
    2010 Brilliant Black A4 Sline • Hüper Optik • Alu Kreuz/ÜSS • Hankook V12's • 034 HiFlo Turbo Hose • EC HFC • Milltek • ST-40 BBK
    Pending: Black Grill • Höen H11 • EC Intercooler
    Wish List: New Wheels • ECodes • EC Short Shifter
    Senior Member Three Rings A4 Centaur's Avatar
    Jun 05 2009
    2008 Ducati 848, 1199 Panigale on the way
    Colorado Springs Colorado
    I went with the Vogtland Coilovers from Actuning.
    We will see. Should finally have them on in a week or so. Ran Koni's on my B7. They lasted well over 5 years.
    My buddy has the V1 KW's on his 2008 B7. Seem fine to me.
    I ran with price.
    Black B8 A4 Avant S-Line Prestige Package, Tiptronic 8 speed, V1, Vogtland Coilovers, APR 91 & 93 ECU Upgrade, VMR RS4 Reps, and more mods to come!
    Aug 15 2004
    Mililani, HI
    Quote Originally Posted by Bells7246 View Post
    So where does street comfort fall in between the V1,V2 and V3?
    Aug 15 2004
    Mililani, HI
    Quote Originally Posted by A4 Centaur View Post
    I ran with price.
    I had Vogtlands on my B5 S4 and those were great for the short time I had them. I traded the car in 6 months after I installed them. I also had Koni's before the Vogtlands and they were horrible. It was impossible to adjust the ride height on those without spring compressors because there was nothing between the bottom of the spring and the spring perch and because the bottom of the springs weren't grinded flat, it would dig into the spring perch. Terrible design on those. Only a few years after did Koni start supplying a plastic washer between the perch and the spring to fix that problem.
    Jun 05 2009
    Yea, I know my B7 had Koni's.
    Hard to adjust and I hope my new Vogtlands will be better.
    Active Member Two Rings BarEaterB8's Avatar
    Nov 13 2011
    2008 BMW 135i - 1999 Jeep XJ
    I acutally have them on my BMW 135i. Like the V2's they are adjustable for both height and dampening but the spring rate has more of an OEM type feel as opposed to a straight coilover. I really like them, and would definitely reccomend them.
    2008 BMW 135i Alpine White
    2009 Audi A4 B8 Brilliant Black
    1999 Jeep XJ Red
    2011 Ford Edge Limited (Wife's Ride)
    2000 Acura Integra Type R Phoenix Yellow (sold)
    1996 Chevy Blazer Aspen Blue (sold)
    1989 Jeep XJ Red (sold)
    Active Member Two Rings han's Avatar
    Oct 01 2004
    Bay area, CA
    so hows these coilover compare to stock suspension/H&R OE springs. interested in these but having a hard time finding out the specs...
    Senior Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    bump, how much do the street comforts lower b8's
    2012 S4 black, prestige, titanium, sport diff
    -h&r oe springs
    -vmr v701 19x9.5 midnight blue
    -awe res exhaust res dp's quad black diamond tips
    -hotchkis front and rear sways
    -blesk led plate bulbs
    -hoen yellow fogs
    Senior Member Three Rings wwhan's Avatar
    Mar 26 2010
    CA
    Quote Originally Posted by bengtc View Post
    The KW street comfort coilovers are similar to the V2 kit, but are setup with softer progressive rate springs.
    The minimum drop is 1.25" in the back (without the spacer), the maximum drop should be about 2", though I have not tested max drop. The rear spring adjuster range delta is 1"
    The front coilovers have a minimum drop of about 0.8" and the maximum drop must be close to 2", though I have not tested max drop. The front spring adjuster range delta is about 1" (there are enough threads to go beyond the spec range).
    In the KW instructions, front & rear, for maximum drop, the minimum distance from the center of the wheel hub to the wheel well is specificed as 13.4".
    11 S4, P+, DSG, B/O, SD, Ibis/Blk
