Results 1 to 22 of 22
    Active Member Two Rings TehC0de's Avatar
    Apr 26 2011
    Duluth, GA
    Performance, Bang for your buck.
    So I'm looking to drop about $2500 strictly on performance upgrades. I'm looking for suggestions from the more experienced modders of the 1.8t longi.
    My thoughts so far are at a minimum: GTRS Eliminator turbo / or K04
    high flow injectors
    Exhaust manifold
    high flow cat / bolt on cat delete
    FMIC
    Stage 3 Revo upgrade
    Everything else already installed on the car is currently in my sig. Any suggestions?
    My Denim Blue Build 2003 A4 1.8T Quattro MT5
    Revo Stage 2 ECU, Bosch 386cc Injectors
    Carbonio Intake, Forge Splitter DV/BOV 90%/10%
    MagnaFlow Cat back performance exhaust #16601
    034 Motorsports HFC, TT Downpipe
    AWE Tuning FMIC
    ABT Lip Spoiler
    RS4 22mm Rear Sway Bar
    OEM RS4 19x9's black
    more to come...
    Jun 08 2007
    2003 A4 StgIII
    Orlando, Fl
    With an Eliminator setup you'd be really stretching it with $2500. It's doable if you kind find used parts. When you consider that a new GTRS is $1500 and software is $600 you are left with $400 for everything else. I say you save a bit longer so that you can do things right. When I pieced together my GTRS setup I bought some new and some used items and I think I invested around $3000-3500.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Senior Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    8 more rings
    Northridge, CA
    I believe your $2500 can only get you to K04 or Frankenturbo
    unless you settle for a used GTRS setup
    Edit: ^^ He beat me to it haha
    Silver 02 Audi A4 1.8T Q MT
    LED headlight :)
    Buy my trash!
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Just go frankenturbo for like 1600, get a good fmic, and some other supporting mods.
    Active Member Two Rings DBM's Avatar
    May 31 2011
    SLC, UT
    You wouldn't need an exhaust manifold with an eliminator setup...that's kind of the whole point.
    But still, A4Dit is right, you need more $$$
    I'd get a good FMIC, a high-flow cat, injectors and Revo stage 2 if I were you. That should be within your budget
    Apr 26 2011
    Duluth, GA
    Thanks for the response A4Dit, I could stretch as far as $3500, I was just looking to see if I was in the correct ballpark for the items needed, and if anyone has done a similar setup.
    On a side note, I have been seeing some GTRS turbos that function fine with a stock manifold, that could cut the cost if the case is true.
    **EDIT: couple of responses as I was typing this lol a lot of questions already answerd, thanks guys ;)
    AWE Tuning FMIC
    ABT Lip Spoiler
    more to come...
    Jun 08 2007
    2003 A4 StgIII
    Orlando, Fl
    I would recommend the log manifold or porting the stock manifold. It's going to free up power that would otherwise be restricted by the stock mani as well as lower egt's.
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    I'd recommend a good fmic before an exhaust manifold. Stick with the stock manifold and keep your iat's down w/ the fmic, unless you get turned on by trying to install the most tight fitting exhaust manifold nuts with a home made wrench to only be rewarded with bloody knuckles and a cracked manifold a few thousand, maybe hundred, miles later...
    /run on sentence.
    I'd do:
    GTRS snail (new used would be ideal for cost)
    Software
    Injectors
    FMIC (pick up a used one if you can find one)
    + gaskets, oil, coolant, all that jazz...
    USP CLUB MEMBER #71 BetaAlphaTau Member #16
    tumblr
    Active Member Three Rings
    Dec 18 2011
    Colorado Springs
    ...dont mean to sound stupid but, can someone define frankenturbo??
    '03 Crystal Blue A4 1.8T - ECS Tuning Snub Nose - AFE Filter - Joey Modded headlights (HID) - Stained Yellow Fogs - Smoked Tails & Side Markers - 20% Tint - Modded Airbox - Test Pipe - Prior owner D-bag cut off mufflers - N249 Reroute - Reversed DV -
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by B6A4Dave View Post
    72 pages should help you out...
    http://www.audizine.com/forum/showth...t=frankenturbo
    tumblr
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Are you still on a stock clutch setup? Going with an elim kit would be nice but if you need to fork out another grand because your clutch is slipping, you'll blow right through your 2.5-3.5 budget. (Ask me how I know... go on)
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    true.
    Just drive with the stock clutch until it can no longer hold the additional power. I went for quite a while on a stock clutch w/ an elim. The only reason I replaced it was because my motor was out and it was the perfect opportunity to.
    tumblr
    Jun 08 2007
    2003 A4 StgIII
    Orlando, Fl
    I've logged 15-20k miles on my elim with a stock clutch. It can be done but my situation may be rare.
    Senior Member Two Rings jalcom1's Avatar
    Feb 23 2009
    '04 A4tqm, '07 BMW 328xi, '69 Camaro SS
    Antioch, IL
    I've put 12k on my stock clutch with an eliminator (85k total miiles.) The key is not launching your car.
    $2.5-3.5k is definitely reasonable for an eliminator setup. If you can be patient and wait for deals in the classified's you could easily find yourself in the lower end of that price range.
    - Jason
    Apr 26 2011
    Duluth, GA
    Hmm, didn't think about the clutch issue with the added power, however theres only just over 40k miles on the car, and i baby the clutch. So here's hoping it lasts a decent while haha.
    AWE Tuning FMIC
    ABT Lip Spoiler
    more to come...
    Active Member Two Rings AWDxTY's Avatar
    Nov 07 2011
    Fayetteville, NC
    What kind of AWHP can be expected out of a GTRS elim?
    B5 S4 brakes/ Hawk HPS pads, apikol snub
    Aug 28 2011
    Portland
    I think 250 whp for gtrs. Anyone want a GT3071r with log manifold, internal 5 bolt with vband downpipe and has 2000 miles?
    Nov 07 2011
    Fayetteville, NC
    Damn thats it?
    Aug 28 2011
    Portland
    Yeah thats one of the reasons why I thought gtrs was not worth it and got a 3071r. Might as well go full setup instead of eliminator since its not that much more.
    Nov 07 2011
    Fayetteville, NC
    what are you pushing with the 3071r? And why are you getting rid of it?
    Aug 28 2011
    Portland
    3071r will get you at least 300, I think I'm right around there. It faster then my old Evo 8 with 300, but I'm looking to upgrade to 5857.
    Apr 26 2011
    Duluth, GA
    I've seen reports of 300+, as well as there own claims that AWE Tunings GT28r setup will net you 290, and it's quite cheap as a matter of fact for the whole kit. Includes exhaust manifold and GIAC software.
    AWE Tuning FMIC
    ABT Lip Spoiler
    more to come...
