Results 1 to 17 of 17
    Veteran Member Three Rings Spinnetti's Avatar
    Dec 10 2004
    Kentucky
    Replace accessory belt idler without pulling the whole front?
    Did my 2nd TB service, and got all done and heard belt noise.. Disgusted, took it to a shop, and they stung me for a accessory tensioner. $200 for what I could have done for $60 and 5 minutes.. Get it back, noise still there. Pulled the accessory belt, and no noise. Hmm. Checked the idler and it felt kinda crunchy and assume thats it. (no roughness or play in the AC or PS)... Anyway, I have it up in the air, but two questions:
    1. What's the easiest way to replace it? I REALLY don't want to put it in "service position" again.
    2. What's the size of the bolt? is that a Torx T40? I couldn't really get in there, but everything I had was too small. I'm tempted to cut away a bit of the fan housing where it blocks me from putting in the torx...
    TIA..
    2004 Touareg - Wife's car
    2002 1.8TQMS - GTRS,FMIC,Exhaust,coil-overs, bunch of other mods.
    1999 1.8TQM - Wife's car - K04/Test pipe
    1991 LS400 - Lemons race car - lots of mods
    1985 AE86 - SCCA IT/A race car - lots of mods
    Registered Member Two Rings mdk's Avatar
    Nov 21 2010
    I just did mine, and I did have to put it in the service position. I don't think there's any way around it. I believe the bolt is a 12mm triple square, but I cheated and used a 9mm allen because it fits in the same and was easier to find. Car sounded unbelievably better afterwards.
    Dec 10 2004
    Kentucky
    Quote Originally Posted by mdk View Post
    Arrg. I was hoping I wasn't going to have to do that. Such a PITA.
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    You may not need to fully remove the front end. For things like that you can just loosen the bolts that hold the front end on and let it hang forward a bit. This should give you plenty of clearance to remove and install the tensioner.
    I've replaced a timing belt on my B5 with out completely removing the whole front end like this.
    Jason
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    05 A4 USP Avant, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    You can get the front in service position in 30 minutes. Maybe 45-60 if it's your first time. No need to drain coolant....just spill some washer fluid
    Apr 10 2011
    People's Republic of NJ
    You must be a contortionist. I don't know how anyone can get their hands in there to deal with the TB without having the front clip physically pulled at least 6-8 inches forward. I generally just swing the entire mess off to the side so I can sit on a small stool in front of the engine and do the job in relative comfort. Sure, you've got to disconnect the radiator (and the transmission cooling lines if you've got an auto), but then everything is right there in front of you with plenty of room to operate.
    Jason
    2002 A4 1.8TQM
    Formerly...2001 A6 2.7TQM 6sp
    Before that...1999 A4 1.8TQM w/lots o mods
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Ritz View Post
    A good friend of mine is an Audi tech and he showed me this way. It's how he gets t-belt jobs done in a few hours rather than half a day!
    No need to disconnect the coolant lines or any of that jazz. It was just hanging forward and I had plenty of room to work.
    Jason
    Apr 10 2011
    Hmmm...I'll have to try that next time.
    Best,
    Jason
    2002 A4 1.8TQM
    Senior Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    I second that, i've done my TB on my 3.0 without putting the car into full service position. Remove lower/upper bumpers, remove the bolts holding the crash bar things to the core support. remove upper core support bolts (2 on each side). tilt the entire assembly forward, snub mount can even be popped out to get more access. I can probably do that in about 15 minutes. I'm not sure clearance difference between 3.0 and 1.8s but its pretty damn tight with the V6 and i didnt have a problem.
    02 Avant 3.0 // B5S4 Brakes // RS4 Rear Sway // MF 14851s // S4 Door Blades // Avant Garde Member // 3.0 Group Member
    Active Member Three Rings
    Dec 31 2010
    Chicago land
    No need to even put it in the service position. I just did mine. I bought a cheap 12mm triple square and cut down the bit as short as possible and used an opened end wrench on it. It is still a tight fit up against the fan but only took 5 minutes.
    Active Member Four Rings rollerton's Avatar
    Sep 16 2010
    03' 3.0/MT Avant + 02 S4 Avant+ 67 Speed Buggy
    Central Wash
    Obviously you don't have to go this far, but loosen it up mostly and slide/ tilt it forward several inches. Don't drain coolant or anything, shouldn't be hard at all. You seriously should have it done in under an hour.
    When you're the only one making sense, chances are no one else understands you.
    Support Kaylah!: http://www.audizine.com/forum/showth...=1#post7183644
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    Jason
    x2. This is how it's done.
    2001 Laser Red A4 1.8TQM, APR 93, 710N, electronic oil pressure gauge, B6 Sport 17's, OEM Sport Shocks, H&R Sport Springs, My 5-Speed Swap
    Need to borrow a Cam Chain Tensioner Tool? Just pay shipping ($4 total). PM me.
    "If i had a manual for my commuting, i would literally...LITERALLY...kill myself in the face. Kill myself dead... right in the face." -toaster
    Dec 10 2004
    Kentucky
    Jason
    Yeah, its just that I JUST had the whole mess off for the TB job. I hate doing a job twice, and I have a FMIC, and Oetty front end, its not as simple!
    BTW, Torx 40 or what is the size of the bolt again?
    Thanks.
    Dec 10 2004
    Kentucky
    Quote Originally Posted by Rausch View Post
    Ah, that's what I was thinking... where do you get the triple square? HF have that sort of thing?
    Dec 31 2010
    Chicago land
    They should. I bought mine from car quest.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Spinnetti View Post
    Thanks.
    I believe its T45 or T40 can't remember off the top of my head exactly.
    Jason
    Dec 10 2004
    Kentucky
    Cools.. Thanks for all the feedback.. Turns out I forgot I already had a triple square set.. I'll chop one off and see if I can do it without pulling the nose. Ready to have my DD back! Then its on to figuring out why my B5 stumbles and hesitates and throws lean codes....
