Page 1 of 7 123 ... LastLast
Results 1 to 40 of 246
    Active Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2011 Mustang GT, 2008 ZX6R
    Iowa City
    CXRacing (ebay) FMIC review
    So I figured I would do a FMIC while redoing the clutch job, so I got a CXRacing FMIC on ebay for $400 shipped. I could have spent more for a "nice" one, but since nobody has chronicled fitting one on a B6 here I would go ahead and try it. I am still running the k03, so no real loss there.
    Packaging and shipping:
    The intercooler setup came well packaged and in a timely manner, I believe 4 business days. The core was in its own separate box with an inch and a half of foam on each side. All the piping was relatively polished, and each pipe was actually tagged with its correct location, which couplers were to be fit on each side and numbered in correct order of install. The couplers and t-bolt clamps were all packaged individually and insulated with plastic and foam. It also included an aluminum pre-fabbed upper mount and various mounts and pipe brackets.
    Modifications to install:
    Disclaimer: I knew going into this I was going to do a USP front bumper and any cutting or maiming of the stock bumper was really moot because it was damaged anyway prior to my ownership.
    There was cutting aplenty required to make it fit. I had to cut most of the rebar away on the lower half in the center (see pic) and a decent amount of the bumper immediately adjacent to the center grille on both sides and part of the fog buckets on both sides. I originally had it fit where the foglights needed to be removed, but with some careful massaging I retained both stock fogs. It fits a bit tight on the drivers side, but it was always that way since I have owned it, I will utilize a new USP upper/lower soon and have it fitted professionally before paint.
    Driving Impressions:
    The car now has a BIG FAT increase in power and torque in the midrange, from when it spools until around 5k rpm. It still chokes off past 5k, but it is much less pronounced. The power and boost are much more linear as well, plus the boost holds 18-19 psi mush longer than before. I now have a solid 18-20 lbs of boost for at least 1500 rpm. I feel much safer running the 93 octane tune now, and can feel where there previously was a bit of timing retard from heat soak. Unfortunately now I have run out of mods I can do with the stock turbo, so now I need to justify the expense of that upgrade. There is really no performance downside to this, it actually feels like it spools at the same rpm as with the stock IC and is just generally much less peaky and meatier throughout the powerband. It is a similar feel to when I went to the TT225 injector file from stage 1.
    Installation Difficulty:
    I would rate this as a 6 out of 10, it requires a decent amount of modification, and if you are unfamiliar with modding your car, you should probably have a shop install or buy a FMIC kit from one of the big companies which is guaranteed to fit well. I did not mind, but I used to build engines in my parents garage in high school, so YMMV.
    Pics:
    2011 Mustang GT 5.0 - 419/378
    2003 B6 A4 TQM - 187/232
    --14.168@94.16 mph STOCK K03--
    2008 Kawasaki ZX6R - ?
    Senior Member Four Rings kneel's Avatar
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    needs fog grills
    Neil_
    2003 Atlas Gray Avant w/ REVO STG.3
    PSi Concepts 20g Turbo..... Baby Recaro Seats!
    PODI
    Dubs on Defrost 5 - April 7th, 2012 - Westport, CT
    Jan 22 2011
    Iowa City
    needs fog grills
    I'm working on trimming those to fit better, I didn't have a dremel last night and figured a sawzall was a little much.
    Active Member Two Rings McCheese's Avatar
    Nov 08 2010
    va beach VA
    needs fog grills
    yes
    Dec 18 2011
    Colorado Springs
    Thank you so much for doing a review on this, I was very seriously looking into one of these units.
    Could you please post the link to which one specifically this is?
    '03 Crystal Blue A4 1.8T - ECS Tuning Snub Nose - AFE Filter - Joey Modded headlights (HID) - Stained Yellow Fogs - Smoked Tails & Side Markers - 20% Tint - Modded Airbox - Test Pipe - Prior owner D-bag cut off mufflers - N249 Reroute - Reversed DV -
    Jan 22 2011
    Iowa City
    Active Member Two Rings 5TAK's Avatar
    Mar 30 2006
    Sacramento, CA
    it doesnt look too bad. Highly considering getting one of these. Wondering if the core is too small for a GT28Rs snail
    Jan 22 2011
    Iowa City
    It probably is not, the core is actually a really high quality unit. It is bar and plate, and has alternating rows of fins in each row from front to back just like the big boys.
    The core is larger then even the USP inlet. There wouldn't be much to gain from a bigger core, plus it is 2.5" in/out. The hot charge pipe is 2" transitioning to 2.5 and the cold pipe is 2.5" to the tb.
    Jun 05 2010
    Traverse City
    Thanks for taking the time to do a write up on this, I was just looking at these on ebay this morning.
    Did most of the difficulty come from having to trim the bumper? Did the kit come with everything you needed to complete the install? No missing hoses or clamps, etc? Fog grills will fit with some trimming?
    04 DG USP 6MT l BB FMIC l 710n l 2.0 CPs l AudiUp snub
    Dec 18 2011
    Colorado Springs
    I'm really glad you made this thread...I was thinking I would get severely flamed if I asked about it considering how many times its been asked, but this is exactly what I was looking for haha. I wish I could buy just the piping, I have shit tons of intercoolers layin around.
    Care to be more specific about the modification that was required? Was it modification of the parts you received? Pipes too long? not the right angle?
    I'm going to assume most was from the body modification?
    I remember doing the APS FMIC on my 06 STi, 2 hours mounting all the parts and to get it running....6 hours of bumper trimming to make it fit right haha
    Any pictures of no bumper with the rebar mounted? I'd love to see how much of the rebar was removed with the IC as reference for how much is being blocked.
    Jan 22 2011
    Iowa City
    Quote Originally Posted by p8nt View Post
    Did most of the difficulty come from heaving to trim the bumper? Did the kit come with everything you needed to complete the install? No missing hoses or clamps, etc? Fog grills will fit with some trimming?
    Yes, in fact, it went on like a charm and everything fit extremely well in respect to all parts not including the bumper cover. If I had a USP/Caricature/pretty much any bumper cover except the base model one, it would have been monumentally easier. There were no missing parts, exactly the right amount of clamps and hose couplers were included and there were even a few extra misc. brackets I didn't use because I fabbed my own lower core supports.
    Jan 22 2011
    Iowa City
    Quote Originally Posted by B6A4Dave View Post
    The pic of the cut rebar is above, It is mounted to the bumper cover so I did not have them apart, I just cut the bar with the bumper attached. The actual mounting of the intercooler took about 30 mins and the modding of bumper cover and support took about 2 hrs. Almost all the offending material was the rear part of the bumper cover. I will go take a couple of better pics of the cuts. Bear in mind I am replacing the whole front upper/lower bumper with USP soon and did not take a lot of care in my cutting. The core only protrudes into the support beam about an inch, so you aren't losing any appreciable amount of airflow.
    Dec 18 2011
    Colorado Springs
    Thanks so much! I also plan to go USP, but only USP Lower. Im not sure if you're planning an entire USP or just the lower or not.
    But it looks great man! I see you mentioned 16-18psi, what other modifications do you have?
    Senior Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    I have that exact same core and didn't have to trim anything. All I did was mount it lower
    -Andrew
    Frankenturbo/GIAC
    Jan 22 2011
    Iowa City
    I am doing the complete USP, I got some insurance money for a replacement from a neighbor who backed into my car. I am Stage 2+ APR tuned with every supporting mod. My full mod list is in my profile.
    Jan 22 2011
    Iowa City
    Quote Originally Posted by android3000 View Post
    Are you using a USP bumper? My core rests on the lower section of the bumper as is, I have it mounted as low as I can with the standard base model bumper cover.
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    Yes sir, that's what it is. Wow I didn't realize usp was that much lower
    -Andrew
    Frankenturbo/GIAC
    Jan 22 2011
    Iowa City
    Some more pictures:
    Active Member Two Rings screwball's Avatar
    Jun 29 2009
    B6 A4 - Mk4 GTI
    Northeast
    Gonna see if they'll sell me those pipes mated with the small PTE350 IC.
    B6 A4 1.8t & Mk4 GTI 1.8t - PAG Parts 50 trim - AEB - RMR/70mm
    Jan 22 2011
    Iowa City
    It is a little lower, but the big difference is that the base model lower curves back so much and the USP goes almost straight down. The lower is where all the interference happens.
    Apr 01 2007
    2012 MazdaSpeed3
    houston texas
    Get some logs! Lets see how this FMIC really preforms.
    DD - 2012 MazdaSpeed3
    2003 A4 1.8TQ
    APR stg2+, MTM injectors, Ecode FMIC, PSi testpipe, OC.T TIP, Hyperboost DV, B5S4 calipers, Goodridge SS lines, Stern firm snub, motor and transmission mounts, Podi, Vogtland Jr. Cup Kit, RS4 Rear Sway Bar, USP front and spacers front and rear
    Jan 22 2011
    Iowa City
    Quote Originally Posted by texasboy21 View Post
    I need to get a Vag-com cable first!
    Jun 29 2009
    B6 A4 - Mk4 GTI
    Northeast
    ebay IC is an ebay IC, they all seem to need to be huge to do what a smaller and better core will do. IATs always seem to skyrocket on these things too though. Buschars test here: http://forums.evolutionm.net/evo-eng...cts-truth.html which are largely mirrored on back to back tests elsewhere on the net.
    Jan 22 2011
    Iowa City
    I am sure it will work just fine for my small frame turbo. You are comparing a tiny turbo to a much larger one referencing that post.
    Jun 05 2010
    Traverse City
    Thats not quite an apples to apples to apples comparison. The consern for me isn't weather or not this fmic can effectively support big hp applications, but is it a legitamate upgrade over stock at a reasonable cost. I'm willing to bet that logs will verify just that.
    Mar 27 2005
    Ducati S2R & Land Rover Discovery 2
    Tampa Bay Area
    Looks like a typical low density core.
    If you guys are going to trim the plastic atleast finish the plastic edges so it looks smoother.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin/Swift Suspension w/ H-Sport Sways
    -STaSIS/Alcon 355mm Mono4 BBK & 305mm Rear
    -STaSIS 4:1 Center Diff & STaSIS LSD Rear Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Jan 22 2011
    Iowa City
    Quote Originally Posted by EBG 18T View Post
    Define low-density. Meaning the fins between the plates? Does anyone read anymore? I don't care what it looks like because I am swapping it out for a USP!
    Jan 22 2011
    Iowa City
    YES! It pulls MUCH harder now. I should have used the shop owner's VAG to log IAT...
    Jun 29 2009
    B6 A4 - Mk4 GTI
    Northeast
    Log IATs.
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Only good for a k04. You're IAT's will sky rocket after a handful of pulls and forget about the summer drive.
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
    Jan 22 2011
    Iowa City
    Quote Originally Posted by viceprp View Post
    It is better than the stock side mount based on surface area and composition alone. I would love to log IAT, I just need to find someone with Vag-com. I just checked and I cannot log iat with VCDS-lite.
    Oct 17 2009
    alonE, Pa
    I understand this. You might want to recalibrate your butt dyno.
    STEVE
    Jan 22 2011
    Iowa City
    I have a 500 hp Mustang I was just driving for a few days before installing this. If anything my butt dyno would "read low" after that... Don't be a dick.
    Oct 17 2009
    alonE, Pa
    The 500hp mustang is a slow pig. I felt like I was driving in a crown Vic.
    I'm being honest bc I have a similar core that I had for my car. No good.
    STEVE
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    looks nice, do you feel a difference?
    198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Tuning Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. 11mm Forge spacers. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings)
    BT Build Coming Soon...
    Jan 22 2011
    Iowa City
    11 second car is slow? Wow you must have a sweet race audi then eh?
    That slow pig pulls 1.0 lateral G stock. Your Audi did what? Slalom mph?
    Jan 22 2011
    Iowa City
    Quote Originally Posted by bondar1989 View Post
    Yeah, most definitely. I just pulled some metrics from the GPS Gtech:
    I didn't launch the car due to the new clutch.
    60ft - 1.977
    0-60mph - 5.911
    1/8th Mile - 9.176@76.01
    1/4 Mile 14.448@93.75
    Seems pretty stout to me.
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Quote Originally Posted by vteckiller2000 View Post
    60ft - 1.977
    0-60mph - 5.911
    pretty nice
    Oct 17 2009
    alonE, Pa
    Nah, my car is slow. I've only driven a new GT and a slightly older 427. It just felt like a slush bucket. I have the same core in black that I could have sold you for $50 brand new.
    STEVE
    Jan 22 2011
    Iowa City
    I don't mind if it sucks, I'll just buy a better one. Point of this thread is to show people it does function and is an upgrade worth doing if you are willing to put in the work. I will log asap.
