Results 1 to 13 of 13
Thread: JHM Shoutout!
    Active Member Two Rings oef_vet's Avatar
    Nov 01 2011
    2008 S4 DTM SOLD: 2002 C240, 2006 C230.
    Vilseck, Germany
    JHM Shoutout!
    So I finally got my JHM Tune, FI Catback and Piggies installed. Wow is all I have to say. The car is completely different. SO much more throttle response. So much quicker, so much more fun! Thanks to Keaton for all his help with my incessant questions.
    If you get any other tune for your S4 you're crazy. THIS is THE tune to have. Thanks to JHM for an amazing product!
    Active Member Two Rings V8Beast's Avatar
    Mar 28 2011
    Earth
    Quote Originally Posted by oef_vet View Post
    LIKE!
    Senior Member Three Rings gear_head81's Avatar
    Apr 08 2008
    2007 S4, 2000 GMC Sierra 1500
    Ft. Lewis, WA
    after 5 total years spent in combat zones this is a given, witch is why I'll probably get either UNI or MRC.
    Make something idiot proof and someone will come along and make a better idiot.
    A.M.A. Member - A.R.M. Member - Military 4 Rings Member (Active Army)
    Active Member Three Rings Apat's Avatar
    Jul 04 2011
    Minneapolis, MN
    Quote Originally Posted by gear_head81 View Post
    LOL
    I drove around with just piggies and FI catback for 4 months. Then I got the JHM tune. WOW. I was forced to punch myself in the stomach for every day I didn't have the tune. Those 3 things together make this car proper quick
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // 19" MRR GT1 summers // 18" VMR V710 winters // PSS9 Coilovers // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I fully agree. being someone that has sampled all the tunes the JHM was so far ahead of the rest it was crazy.
    please vote if you find the time.
    http://www.audizine.com/forum/showth...ustomer-review
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Oct 03 2011
    2004 Imola S4, 2009 R1
    Sacramento
    i know its not recommended, because of constriction above 5500 rpms, but how is the jhm tune on a stock car? anyone done this? i dont have enough money to get all three at once (or two even if i gut the piggies) im saving for services before upgrades as well.
    Jul 24 2008
    chicago
    Quote Originally Posted by SacAudi View Post
    Its fine. The ECU will pull power to keep the car safe. For the max power pull the Pre cats out and get a solid 2.5" catback with a X. That unlocks the larger section of the JHM tune. As now the motor can flow better and make more power.
    Nov 01 2011
    Vilseck, Germany
    Keaton from JHM told me that you can do the tune first if you need too and when you get piggies or the cat back the Tune itself will adjust to the new mods.
    Senior Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    '05 S4 MT6 pollution machine
    Chicago NW Burbs
    Piggies alone will make a huge difference
    GO: 2.5" trexturk catless dp's // 2.5" x- piped cb // JHM Stg 3 // 034 LWFW // JHM 93 // JHM SS // JHM LW Rotors // Apikol Snub // Stern Street Motor // Stern Trans // JHM LWCP // 034 MAF hose // RS4 Sway
    SHOW: 18" Enkie RPF1 // FK Coils // 35% Tint // Ecodes // HID fogs // Pioneer F90BT // RS4 Shifter // RS4 Pedals // B7 Console // Valentine 1
    AudiRevolution.net
    Senior Member Three Rings SpeedETC's Avatar
    Oct 29 2007
    2004 Audi S4, 2004 VW Touareg
    Poquonock
    Good stuff OP. When I finally got the tune I really had to kick myself for not doing it earlier. I already had a tune on the car and was completely amazed at the difference.
    Jul 24 2008
    chicago
    It will. Its the only tune that will adapt up when you reset the system after a performance modification.
    Quote Originally Posted by SpeedETC View Post
    You would definitely know Didn't you switch from another tune to the JHM
    Senior Member Two Rings R&Cs4's Avatar
    Oct 19 2009
    2005 S4 Cabriolet, 2008 Jeep SRT-8
    Albany, NY
    Quote Originally Posted by Justincredible View Post
    How do you properly "reset the system"? Is there another way besides unplugging the battery for 30 mins?
    2005 S4 Cabriolet~ JHM 93 Tune~ JHM IM~ Milltek Catless DPs~ Magnaflow 2.5" Catback~ Apikol Snub~ JHM Intake Spacers~ Hotchkiss RSB~ 19" VMR V710s~ LW Slotted Rotors~ Pioneer DVD Head Unit~ Cupra R Lip~ TB Elbow Bypass
    Jul 24 2008
    chicago
    Quote Originally Posted by R&Cs4 View Post
    when you reset the system by taking off the batt terminals make sure to touch them together for 45sec. This will prevent you needing to keep the batt unplugged for 30 min.
    You can also hit the reset codes (even if you have none) in vag com
