Originally Posted by
staubs
That ^^ and regular header wrap on the exhaust down pipes
I had always been curious about if there were any mild gains to be had from gold heat wrapping some of the intake parts, but have not seen any data or info on it
I used the DEI Titanium header wrap on my downpipes, it had a higher direct heat rating, doesn't require "wetting" the wrap to install, and doesnt require any special coatings afterwards that other header wraps recommend/require. I ditched the factory head shields at the same time, and I have zero complaints, things stay 'relatively' cool back there (you can work around them shortly after cool down without too much radiant heat from them), and the subtraction of the factory heatshields makes working around back there a breeze. Not sure if it helped insulate the cabin noise at all from the thinly walled downpipes, but i think my car is pretty quiet inside compared to others' videos, so maybe it did help.
Here is what i am pretty sure i used:
