Results 1 to 6 of 6
Thread: timing belt
    Sep 27 2011
    chicago il
    timing belt
    hey guys planning on doing my timing belt in a month. what all do i need and what else should i do while im in there? any advice?
    Dec 05 2009
    New York
    full timing belt kit (people like ecs, jhm, etc) - JHM has a cool video that's helpful
    DIY - http://www.audiworld.com/tech/eng63.shtml - this will tell you a lot of the tools you need also
    upgrade diverter valves (lots of options here)
    upgrade throttle body boot and bi-pipes
    snub mount (i like stern)
    gallon of G12
    cam lock bar and crank lock pin (if you want to do it by the book)
    bandaids
    case of beer
    double check all the torque specs on everything you reassemble, also INSPECT THERMOSTAT HOUSING, i had to take everything apart again because mine was cracked
    If you have any leaking value cover gaskets and seals, this is a good time to do that. Blauparts has a good kit and video. Good luck and godspeed
    Sep 27 2011
    chicago il
    Thanks bud. What kinda tools will I be needing. Anything out of the ordinary?
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Below is our most popular timing belt kit for the 2.7T
    Click HERE to order or for more information.
    Jason
    Sep 27 2011
    chicago il
    That's perfect. Exactly what I'm looking for
    Dec 02 2009
    Wichita, KS
    Take a hard look at the accessory tensioner.
    Valve cover gaskets and tensioner gaskets are also good to look at.
