Results 1 to 10 of 10
    Active Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    Empty space for side jobs ;)
    Des Moines, IA
    Transmission and rear differential upgrades/maintenance time!
    Center differential/transmission/clutch
    Inspect transmission mounts for leaks and wear
    034 Motorsport street density transmission mounts (includes hardware)
    Drain and refill center differential/transmission
    Audi OEM flywheel resurfaced
    Audi OEM flywheel bolts
    Audi OEM pilot bearing
    Audi OEM RS4 clutch disc
    Audi OEM RS4 pressure plate
    Audi OEM pressure plate bolts
    Audi OEM throwout bearing
    Bleed and refill clutch master cylinder
    USP metal slave cylinder
    USP stainless steel clutch line with yellow sheathing
    Empi right front CV shaft assembly
    Empi left front CV shaft assembly
    Audi OEM front left outer CV joint kit
    Rear differential
    Drain and refill rear differential
    Apikol street density rear differential mount
    Audi OEM rear differential carrier custom painted
    034 Motorsport street density rear differential carrier bushings
    There's a few upgrades that I know of that I don't have yet. One would be a short throw shifter. The other ones are ones that I'm still curious about, which would be the 4:1 center diff and an upgraded rear diff setup. The car already has some sort of short throw in it, but I'm not sure which one it is. As far as the 4:1 center diff goes I decided to pass for now due to issues in the snow. Also, I want to upgrade the rear diff but don't think it will be worth the money for me. Looking for some more maintenanace and suggestions at this point. What are you guys using for short shifter setups?
    2002 Audi S4 Sedan Manual Transmission - S4SAKEN - Mine
    1997 Land Rover Range Rover HSE Vitesse - Wife's/Tow Rig
    2001 Audi TT 225 Convertible Manual Transmission - TTRUBL - Mom's
    - Cody T.
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    JHM Trio Kit. The linkage is what's makes the huge difference. Expensive, but changed the entire shifting experience on my vehicle
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Nov 06 2006
    Philadelphia
    Question on this one: Drain and refill center differential/transmission
    I know there is a drain plug and fill plug for the trans and a drain plug for the diff but, is there a separate fill plug for diff.
    Also would you use the same fluid for the trans and the diff. If you wanted to use OEM fluid you could use this part number for both - G 052 911 A2 ?
    I will be changing mine shortly and I think I am going to use Fuchs Titan SintoFluid 75W80 gear oil from Scotty.
    Thanks
    Active Member Two Rings Mitternacht's Avatar
    Nov 06 2011
    Pittsburgh
    I just recently had a shop take care of my transmission and all 3 diffs. I had them use 4 Liters of Motul 75W90 for all 3 diffs.
    Nov 29 2010
    Des Moines, IA
    I'm currently using Mobil 1 75W90 in my trans and diff. Both are working well.
    - Cody T.
    Jan 11 2007
    SLC,UT
    If you're going to put the effort into swapping a CV joint onto an axle, that effort is probably better put on an OEM axle, no? The reason why most go with EMPI is so that they don't have to deal with the CV's separately, but since you are anyways...
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
    Nov 29 2010
    Des Moines, IA
    Quote Originally Posted by jibberjive View Post
    Oh, I forgot to change that. At one point in time the previous owner had put a CV boot kit onto an old axle and later down the road replaced both front CV shafts with complete Empi assemblies. Currently it has Empi axles in the front. :)
    - Cody T.
    Nov 29 2010
    Des Moines, IA
    Forgot to add that I know there's flywheel upgrades as well, but I'm starting to hate LWFW setups. I've got one in my GTi and don't think I like it much. The chatter kind of pisses me off. I went with the RS4 clutch for the same reason - wanted something stiff but still nice. Also, it should be able to hold a Stage III setup for a while before it gives out. I'm gonna pass on the rear diff upgrade for now as it's rather pricey for me and the center diff as well. I like the idea for the center diff, but in the reality of driving the car in the snow the stock bias seems a better choice.
    I am still curious about the shifter upgrades though. I love how mine feels now but have no idea what it is.
    - Cody T.
    Nov 29 2010
    Des Moines, IA
    Thinking of going with the JHM trio at this point but am open to suggestions. Also looking for any more ideas on maintenance or upgrades for the tranny. Thanks guys!
    - Cody T.
    Nov 29 2010
    Des Moines, IA
    I've been reading some mixed reviews on the JHM trio package. Some people say it is too stiff and some say it's perfect. Does anyone know which of these components will make it "too stiff?" My car has some sort of short shift setup on it already but I can't figure out what it is. All I know is that it's much stiffer than my 01 S4 was and much more precise.
    As I stated before I've decided at this point to pass on the lightweight flywheel. After driving my GTi for a couple months now the LWFW chatter is annoying to me. I like the smoothness the DMFW provides. Also glad I went with the RS4 clutch at this point. It was very inexpensive, great engagement, and long life. The rear diff upgrade is out of my price range at this time, so I'll stick with what is in there. The center diff is something i've thought about doing as well, but am curious of negative effects when driving in snow (girlfriend drives this car as well). I know upgraded axles are available too, but I'll stick with my lifetime replacement ones from the local parts store as they are free when the boots split, not to mention they are much much cheaper than OEM units. I could also talk about upgrading the tranny, but that will be taken care of once the 1-2 shift collar locks up. I may do TDI 5th and 6th at that time as well. :)
    I think that about covers it!
    - Cody T.
