Results 1 to 8 of 8
    Active Member Two Rings jamaicanmecrazy's Avatar
    Feb 05 2010
    westchester ny
    Tire size opinions
    Sup guys ?. Can i run 225 /45 /18 tires in the front and do 235 /45/18 in the rear..otherwise what's a good size setup esp with stage 3..(ko4's on the way yeah ).thanks
    Senior Member Three Rings ride1157's Avatar
    Jan 18 2010
    2001.5 Audi s4 6MT, 2001.5 Audi s4 Avant Tip :(, 2008 WE Jetta 2.0t DSG, 2011 Jetta SEL
    Dearborn, Mi (SouthEast MI)
    Not good sizes...
    Go with either 225/40/18 or 235/40/18 that is it. 45 is thick and you will have rubbing issues when you hit bumps it will work on a 225/45/18 but from experience do not do it!
    Active Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 Silver S4 , 03 Grey Passat
    Waukesha Wisconsin
    Yes a 45 will work unless you have really wide wheels
    Sure it's a Stage 3 S4
    I BUY IPHONES
    Looking for White Armrest, Catalytics, 15mm Spacers, Rubber Mats, 18Z Brakes, Sidemounts, Aquamist, Fuse Cover, Rear View Mirror
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    Most people run 225/40's or 235/40's.
    If you want a "meaty" setup, run 245/35's.
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Feb 05 2010
    westchester ny
    Thanks forgot to mention its lowered too
    Active Member Two Rings Taloras's Avatar
    Jan 19 2011
    East Bay, CA
    225/45 on 18s is probably too big a diameter, especially if you're lowered. And because of the AWD, you have to keep the diameters of the fronts and rears as close as possible if you're gonna run staggered sizes.
    http://www.1010tires.com/TireSizeCal...?action=submit
    Unless you wanna get in to VAG-COM and recalibrate your speedo/test it for accuracy with GPS or radar or something, try to keep diameter to as close as the stock 24.97" as possible. If you want staggered, 225/40 18 in front and 255/35 18 in the back is closest, and the backs could definitely fit with the right offset and judicious fender rolling...I'm not sure why you'd wanna stagger on our nose-heavy cars, though: you must REALLY love understeer
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    235/40
    245/35
    255/35
    Rich | 2001.5 EPL stg III Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Feb 05 2010
    westchester ny
    Ok i am gonna go with 235/40 .. Thanks guys ..
