Results 1 to 15 of 15
    New Member One Ring
    Feb 03 2012
    Rochester, NY
    B6 S4 Wheel/Suspension Thread
    I just recently purchased a 2004 S4 as I had been searching for a black on black 6MT for awhile and finally found one.
    I've been searching and researching suspension offerings, wheel widths and tire sizes for the past few weeks and stumbled onto what I feel was a good idea in the A4 forums.
    http://www.audizine.com/forum/showth...4-Wheel-Thread
    Since the S4 is 242lbs heavier, exclusively AWD and has significantly different and limited suspension offerings compared to the A4, I felt a that it would be wise to see if we could duplicate a collective of different setups, pictures and info all into one thread. (yes, I searched but didn't find a complete resource like the one I'd like to emulate)
    I will keep the format from the A4 thread:
    Format
    Brand/Name:
    Size:
    Offset:
    Spacer(s):
    Camber:
    Tires:
    Suspension:
    Spring Rates:
    Ride height:
    Fender mods:
    Rubbing:
    Brake Spec:
    I appreciate your submissions and hope this takes off. Thanks.
    Mar 26 2007
    Colorado
    Format
    Brand/Name: Linea Corse & Avant Garde
    Size: 19 x 8.5
    Offset: 35
    Spacer(s): no
    Camber: -1.5
    Tires: 235/35/19
    Suspension: H&R sport with Koni shocks/struts
    Spring Rates:
    Ride height:
    Fender mods: Top fender screw removed
    Rubbing: No
    Brake Spec:
    A Fully Catless JHM tuned S4.....
    Senior Member Four Rings Mr. Corey's Avatar
    Jan 14 2009
    B6 S4 / 5.9L Limited Jeep Grand Cherokee
    Syracuse / NYC
    Brand/Name: OEM Bentley Continental GT GTC Flying Spurs
    Offset: ET41
    Spacer(s): 4mm Front / 10mm Rear
    Camber:???
    Tires: Hanokook Evo 12
    Suspension: Bilstein PSS9
    Ride height: 24.75 Ground to fender
    Fender mods: Top Screw
    Rubbing: Hardly ever
    [IMG][/IMG]
    [IMG][/IMG]
    B6 Nogaro with some mods
    New Member One Ring
    Feb 03 2012
    Rochester, NY
    both cars look awesome, and Corey I met you at Stratmosphere... I was driving the bagged MK5 GTI on Oxblood Rotiform ROCs at the time.
    Let's keep the submissions coming
    Jan 14 2009
    Syracuse / NYC
    Quote Originally Posted by Umad View Post
    I remember the car!.... very Hott GTI!!!! You still have it?
    Dec 20 2005
    1 I like, 1 I don't mind, 1 that's free.
    Indy
    Can we update this to include B7s as well?
    "Good dude, bad night, right place, wrong time; in the blink of an eye, his whole life changed."
    -K. West
    Jan 14 2009
    Syracuse / NYC
    Quote Originally Posted by 0302 View Post
    Yes great idea!
    Active Member Two Rings Baby Kito's Avatar
    Apr 08 2010
    Lancaster, PA
    Brand/Name: OEM 18" Avus
    Offset: ET45
    Spacer(s):15mm all around
    Camber: I did, Won't do it again. Just ask my tires.
    Tires: Dunlop Sport winter/ Sunny SN3800
    Suspension: H&R Coils
    Ride height: 24 Ground to fender
    Fender mods: None yet, rolling soon/ top screw
    Rubbing: Happens a little every time I drive.
    Brake Spec: Stock
    Pics soon.
    Black Betty l I know Nick Broderick l xoxoxo PSU
    #1 STOP sign Mod
    Stratmosphere Catless X-pipe l Uni 2 tune l 4.5% tint l 034 goodies l Snub l 15mm rear l Stage 4 clutch LW FW l HR l
    Active Member Two Rings j2ther's Avatar
    Apr 05 2011
    Brand/Name: Hartmann b7 rs4 reps
    Offset: 32
    Spacer(s): f:0mm r:5mm
    Camber:
    Tires: michelin alpin pilot pa2 235/40/18
    Suspension: stasis sl
    Spring Rates: 750/1100
    Ride height:
    Fender mods:
    Rubbing: with 8mm spacers on front, no rub after spacer removal
    Brake Spec: stasis mono4 355mm
    New Member One Ring
    Feb 03 2012
    Rochester, NY
    Let's see some pics guys
    Mar 26 2007
    Colorado
    lol, pictures are supposed to be posted when you provide your specs
    Active Member Four Rings Axel-'s Avatar
    Jan 29 2011
    Toronto, CA
    B7 S4 Avant
    Brand/Name: O.Z. Ultraleggera
    Offset: 35
    Spacer(s): None
    Camber: None
    Tires: Hankook V12 245/35ZR19
    Suspension: KW v3
    Spring Rates: No clue
    Ride height: Forget
    Fender mods: Top middle screw
    Rubbing: None except with very big bump (except when my stabilizer end link broke and my 29mm rear sway bar no longer did its job. At which point, a lot of rear rubbing.)
    Brake Spec: Stoptech ST-60 6 piston
    Sprint Blue B7 S4 Avant 6MT - Dynos
    JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - Apikol snub mount - RS4 Pedals - TT-RS MFSW - Dectane LED tails - 19" O.Z. Ultraleggera - 35% Huper Optik tint - Zada Tech Gauges - Dynavin D99 Android
    New Member One Ring
    Feb 03 2012
    Rochester, NY
    Quote Originally Posted by Axel- View Post
    So Sexy.
    Oct 11 2011
    1975 Honda CB200T cafe racer
    Chicago, IL
    CAN WE PLEASE GET THIS STICKIED?! And please edit title to include "B7". I'd love to see a ton of info in here so I can figure out what my setup should be for my type of driving and preferred look.
    Brand/Name: VMR V710 Gunmetal
    Offset: 35
    Spacer(s): None
    Camber: None
    Tires: Continental 255/35
    Suspension: Stock
    Spring Rates: Stock
    Ride height: Stock
    Brake Spec: Stock
    SEE MY GALLERY FOR PICS, I don't have permission to post pics here.
    08 Ibis S4, MT6, black alcantara, CF beltline, 19x8.5 VMR V710 gunmetal, CF mirror housings, matte black window trim vinyl, black RS4 grille/plate filler
    Installing shortly: blacked out headlight mod w/ clear corners
    Next steps: custom CF rear valance, custom CF front splitters/canards, piggies, cat-back, tune, coilovers, big brakes
    Active Member Two Rings NikS4's Avatar
    Aug 10 2010
    Ellensburg, WA
    Brand/Name: Hartmann euro mesh 4-A (Will be upgrading to CCW Classics soon)
    Size: 18x8.0 (Classics will be 18x10)
    Offset: 32et
    Spacer(s):N/A
    Camber: Front -3.0, Rear -3.4
    Tires: Continental Extreme Contact DWS 235/40
    Suspension: KW V3
    Spring Rates: Medium, they are adjustable and are speed variable
    Ride height: 23" from ground to fender
    Fender mods: None
    Rubbing: Slight tire rub on sharp low speed turns, nothing severe
    Brake Spec: Stock
    DSCN1294 ver2 by BrentonNikolaus, on Flickr
