Results 1 to 8 of 8
    May 28 2011
    Eugene,Oregon
    Audi s4 b5 timing belt!:)
    Hey guys im doing my timing belt at the end of this month and this is what i got so far
    timing belt
    idler roller
    tensioner roller
    hydraulic tensioner
    relay lever for hydraulic tensioner
    water pump
    cam seal (2)
    crank/oil pump seal
    thermostate
    thermostate o-ring
    drive belt
    schwaben cam locking tool
    anything else you guys would recommend while im in there?
    Senior Member Three Rings Timtheguru's Avatar
    Dec 30 2009
    Crank lock pin, makes it fool proof!
    What year? Think about trying to find a metal thermostat housing if you don't have one. I think the early 2000/2001 models have it, 2001.5 and up have plastic.
    Also, do an oil change.
    2001.5 S4
    Active Member Three Rings 2.7taudi's Avatar
    Sep 08 2011
    Atlanta
    alternator, but thats optional.
    Aug 05 2011
    North Jersey, USA
    Complete valve cover job is easier with front end and timing belt off if you want to add that in. Can also consider upgrading the snub motor mount at this point too?! I also did a headlight washer delete(since my RS4 bumper hits the ground and pops off the nozzle and caps all the time). APR bipipe and lighter pulleys are other upgrades you can also consider at this stage while in there.
    May 28 2011
    Eugene,Oregon
    It's a 2001.5. I have already taken care of the vavle covers. I think i will do the alternator while im there. Thanks guys.
    Jan 11 2007
    SLC,UT
    Don't do the alternator just for fun. And don't do any lightweight pullies.
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Quote Originally Posted by jibberjive View Post
    This. And you don't need the crank lock pin.
    StrictlyEuros ::: Web
    J-Fonz Tuning
    Aug 05 2011
    North Jersey, USA
    What is wrong with lighter pulleys? I've heard some people have bad experiences and others are fine. Mine are ECS tuning ones and my car runs well. I didn't do the pulleys myself...they are from the previous owner.
