Results 1 to 18 of 18
    Active Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    old issue reoccurred. :(
    well my 3500$ s4 still has one final issue I need to resolve.
    I've already fixe the coolant leaks
    (heater hose fitting replaced with hose clamp and temp sensor replaced)
    and the new oil gaskets are on the way.
    but I have 2 issues that are bugging me.
    1 is the car is misfiring When flooring it from a low rpm
    I'm not getting a cel for anything and I was thinking possible
    ckps?
    I also replaced the oil sensor on bottom of oil Pan, but the oil sign keeps
    poppin up on my display, even though I'm full on the dipstick.
    and one more issue is my temp light also pops up randomly, but the gauge on
    the cluster is sitting perfectly at the 1/2 way mark.
    HELP ME PLEASE!
    also, does anyone want to trade some 18s for 17s? haha
    I'm to low for this big of a wheel!
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    Quote Originally Posted by zrider91r View Post
    ckps?
    HELP ME PLEASE!
    Kinda sounds like a faulty sensor for the oil pan, I think that sensor does temperature as well as level (I know on some other models it does)
    What kind of 18's?
    -Nic
    2011 Honda CBR250R - gas sipping toy
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | RS4 Grill | Plasti-Dip'd center console | Podi gauge pod | VDO boost gauge | TSX-R clear lenses
    1994 Suzuki RF900R - It needs some love but it'll get there!
    1994 Jeep Grand Cherokee - rattle canned OD green Zombie Response Vehicle
    Senior Member Three Rings getslideways's Avatar
    May 16 2008
    WA
    what style oil pan sensor did you use? I know people were talking about the non-hella ones not working properly. If oyu dont have the Hella Manufactured one that may be your problem, also like somebody5788 asked, does the oil temp work?
    Registered Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Sounds like your coolant temp sensor is going out.
    It will cause misfires and show erratic readings on the temp gauge, i.e. the car is overheating but the thermostat is still closed. (I popped a head gasket and a blew a ringland on a 1.8t because the sensor was telling me the car is at normal running temp while in reality it was drastically overheating )
    K04|Eurodyne ME7|E85|No bitchassness
    Jan 06 2012
    California
    The coolant temp sensor has less than 200 miles on it (i just replaced it with a green top)
    the oil sensor is new as well, and the oil temp DOESN'T work.
    My coolant temp on the gauge is right where is should be, but the warning pops up on the display still..
    Jan 06 2012
    California
    what brand sensor should I get for the bottom of the oil pan?
    I order from rocak autp.com
    Senior Member Two Rings s4cappa's Avatar
    May 19 2009
    cars
    ma
    there are 2 diffrent kinds of sensors for the pan 00 have to have a certain sensor to read right do a search on that part. as for the coolant light it could be the sensor in the overflow bottle or the wires going to it they are pretty much the most common to be broken. as for the misfire i say check for any boost leaks (diverters if they are still stock and tbb) and from there try plugs and check for cracks in any of the coils.
    Jan 06 2012
    California
    Quote Originally Posted by somebody5788 View Post
    What kind of 18's?
    I ment to put 19s
    and they are flik wheels
    also have a ugly looking spare rim (no tire on it)
    Senior Member Three Rings digitalAUDI's Avatar
    Apr 14 2010
    Union, NJ
    I don't own an s4 myself, so don't hold me against this, but your misfiring issue may be injector related. I'm having similar issues and its leaning towards the injector on cylindar 3 because I keep getting misfiring codes on that cylinder. My mechanic suggested I try 2 bottles of injector cleaner to see if it clears it up, otherwise, just gonna replace it.
    Revo Stage 2, FMIC, Upgraded DV, RS4 Rear Sway, Tein S.Tech, BSH Block off plate w/Catch Can conversion... other stuff I don't remember right now
    Senior Member Two Rings mpower's Avatar
    Feb 02 2008
    01.5 Nogaro S4, Birel 125cc ICC shifter
    Chicago
    As others pointed out.. Use only the OEM Hella brand oil sensor. It runs around $80. The cheaper Meyle and any other aftermarket will not work right.
    Active Member Three Rings csosnowski's Avatar
    Sep 05 2010
    00 A4 Avant 1.8TQM, 77 Chevy 4x4 454, 88 Pathfinder
    Bend, Oregon
    what temp light are you getting? the big red warning on the DID?
    also, i have a set of 17" 35 offset tsw nogaro wheels that are my summer set that Id gladly trade for some 19's, the tires are worn out but the wheels are ok. Im even on the same coast lol. pm me.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - APR Stuff, Piggies, Darintake, 710N's, 034 Track density stuff, Vogtland - GONE
    2000 A4 Avant Sport 1.8TQM - Silver - Black - GIAC, Darintake, H&R / Bilstien
    russianguy.2007 - "Oh tight! thats the S4, A-Line"
    Jan 06 2012
    California
    OK, I am going to get a refund on my current oil sensor, and I will order the Hella one.
    As for the Temp. light, it is the big red on on the indicator screen.
    The wires to my coolant bottle have been repaired already, and the plug isn't too secure (the clip is broke off)
    Sep 05 2010
    Bend, Oregon
    the indicator youre seeing is the low coolant?
    second icon second row.
    if so then its either that loose connector or wires are damaged further up or down the run from where they were repaired. I wrapped mine with electrical tape and foil tape to keep them from being eaten.
    Jan 06 2012
    California
    low coolant and low oil pressure warnings...
    Veteran Member Three Rings beerock's Avatar
    Mar 26 2005
    Rs4
    that coolant light is for the overflow, is that filled? sometimes it will be empty and then fill up
    2001.5 Audi Laser avant 6 speed Asp stg3
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    My oil gauge is not reading too, oil level sensor in oil pan was replaced with an OEM one last year.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Senior Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    the coolant light is for the coolant level sensor in the coolant tank those can go bad or the wiring can be all jacked up due to the heat.
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
