Results 1 to 9 of 9
    Oct 30 2009
    colorado
    Replacing 6 speed transmission. Do I really have to remove the aftermarket downpipes?
    I need to replace my 6-speed transmission but the questions is whether or not I will have to remove my aftermarket downpipes (no cats) in order to do so. I know (or from what I've heard) is that the stock downpipes have to be removed first but does the same goes for aftermarket downpipes. The reason why I'm asking is that the downpipes are partially welded to the catback so I'd have to end up removing the whole exhaust in case I can't remove the transmission by itself.
    Nov 02 2011
    Grand Haven, Michigan
    i am gunna say that you dont have to but trust me its going to be one bitch to get the trans out!. If you take the exhaust off it will make taking the trans off a cake walk. That's what i did and it was pretty easy.
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    If you're going through the trouble of removing your trans, I don't see what the big deal is if you have to remove the DP's as well.
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Oct 30 2009
    colorado
    I think you forgot the part where I mentioned that it was welded to the catback.
    Veteran Member Three Rings durfA4's Avatar
    Jan 01 2006
    2001 allroad 6 speed 2006 Mini Cooper S
    Boston
    Saws all, then buy a 3" autozone coupler clamp and drive to Midas, have it welded. Easier and only a few bucks
    2001 allroad stage III six speed
    J-Fonz tuned Frankenturbo, 52lb EV14, RS4 ICs
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    Remove the whole exhaust?
    Nov 02 2011
    what is so hard about removing the exhaust. Is your exhaust one solid pipe? with nowhere where it comes apart?
    Oct 30 2009
    colorado
    Quote Originally Posted by Boarder View Post
    Yes, it's solid. Thanks, I got my answer. I can remove the transmission but it's alot easier with the exhaust off.
    Senior Member Three Rings getslideways's Avatar
    May 16 2008
    WA
    I would say to remove the exhaust, i know when i pulled my trans it would have been near impossible to yank it out with the aftermarket downpipes still in place, and having them out of the way gives you much more room to work, and will help you get access to the trans bolts. I think the Bently lists removing the stock downpipes for the process, so if you have aftermarket downpipes that are larger, then i think you are are even less likely to get the trans out with them in place.
    Any time you might save by not removing the exhaust (assuming the trans would even wiggle out past them), you will most likely just add to the process in working around them.
    My advice is pull em out.
