Results 1 to 25 of 25
    Active Member Two Rings Porkibear's Avatar
    Dec 01 2011
    Orange County, CA
    Deciding which stage 3 fueling kit to go with...suggestions?
    Hi there, kinda new posting here but an old timer when it comes to different Audi forums. I am finally going stage 3 on my B5, and have been stagnant as far as modding my car for several years. I haven't done much research about stage 3 kits because I honestly didn't think it was going to happen.
    I have K04's brand new sitting around waiting to be installed, and now I'm going to bite the bullet on a full stage 3 fueling kit as well as get some maintenance stuff out of the way since the engine is going to get pulled anyway.
    I've been doing research on fueling kits, but google searches only get me YouTube comparison runs of certain stage 3 B5's or dyno runs without any horsepower numbers. So far ASP seems like a good kit, but wanted to get input from other stage 3 owners. What kind of horsepower numbers are we looking at for K04 stage 3 cars? How is the EPL fueling kit? Which kit is the most reliable for track use? My B5 will end up being mostly for track use and only a few times a month on the street.
    Veteran Member Four Rings BlkdoutA4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Hey, I have a JHM stage 3 fueling kit for sale right now. Its perfect for someone in CA since its for 91 octane. I made 400whp with the tune and meth. PM me, I am willing to sell everything for much less than I paid for it, only reason I'm selling is because i'm switching to bigger turbos.
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Dec 01 2011
    Orange County, CA
    Quote Originally Posted by BlkdoutA4 View Post
    Hey, thanks for the offer. I will consider it. That brings me to another question: i see a lot of used fueling kits for sale in the classifieds. Is there a drawback from buying a used fueling kit versus a new one? The only concern I would have is the injectors being worn after certain number of miles...
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by Porkibear View Post
    It all depends. My kit only has 25k miles on it and everything is in like new condition with absolutely no problems when removed.
    Senior Member Three Rings Sole_'s Avatar
    Oct 29 2009
    In my opinion, piece the fueling kit together instead of getting an OTS fueling kit. You will have better results and you can get the car tuned to your liking.
    The things you'll need :
    Hitachi MAF if you dont have yet
    Bigger MAF, I'm guessing for you an 85mm
    Injectors, I would go with 52LB EV 14s
    4Bar FPR
    Possibly a better fuel pump
    Silver POS.
    Active Member Three Rings sqitis's Avatar
    Sep 03 2010
    00 Imola S4 - Tools - BMX Bikes
    Nashville, IN
    It really does depend on supporting mods but I would talk to Max at 034 or call up Tony at EPL.
    Senior Member Three Rings morris400's Avatar
    Dec 18 2008
    2001 Audi S4 2007 Jeep Grand Cherokee
    Alberta, Canada
    Im going with jfonz. Ive heard alot of good things about jfonz. Also epl is another great road to take.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    unitronic Stage 2+ (3-) with BW K04s, 034 inlet pipes, 710n DVs, 034 trans and motor mounts (track density), Podi boost gauge, SSAC full exhaust, OEM RS4 Grille, silcone TBB and hose kit, JHM FMIC, custom spider hose, Stern power ring rear dif mount Not installed yet.
    Veteran Member Three Rings durfA4's Avatar
    Jan 01 2006
    2001 allroad 6 speed 2006 Mini Cooper S
    Boston
    It depends on what your goals are, cheapest is Jfonz, tune, and self source parts, the 52lb injectors from gt500 are $228 for 8, adapters are $40 for 8, they eBay mafs were a good deal for $45, and 034 hose is $75, so about 800-900 depending on where you can source the maf housing. EPL is about $800 for tune and then hardware varies, but they want you to use thir parts which makes sense they know they can trust products, dyno time also helps.
    If you want to do it your self,then Jfonz, if not then go to a off the shelf tune from a major shop.
    I also did not mention nefmoto, you can learn and tune yourself for free.
    2001 allroad stage III six speed
    J-Fonz tuned Frankenturbo, 52lb EV14, RS4 ICs
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Quote Originally Posted by Sole_ View Post
    4Bar FPR
    This
    StrictlyEuros ::: Web
    J-Fonz Tuning
    Nov 10 2009
    Somerville, MA/Palo Alto, CA
    I'll be going with epl whenever I sack up and pull the trigger. It's a relatively short drive (day trip) if I need any support. I would see who your local shops are dealers for and make your decision that way.
    Jan 06 2007
    Virginia
    I think HP numbers (assuming higher is generally preferred) and reliable track use are opposing attributes. You get higher HP by pushing the systems, and track use also pushes the systems, so combing the two is going to up your chances for component failure. My suggestion would be to contact a tuner that will be able to customize something for you, and from my experience I would suggest EPL. ASP is another good option, and possibly 034, though I don't know much about their tuning options. I don't see Jfonz as being as strong an option as EPL when it comes to tuning experience, and if I were pushing my motor at the track I'd want to know the tune was coming from a source that has a lot of experience. VAST is another option but they are moving to a volume model, pushing out tunes quickly to move onto the next, and their customer support is a complete crap shoot whether they help you or add you to the growing list of unhappy customers.
    An 85mm MAF housing, Hitachi MAF sensor, 52# or 72# EV14 injectors, and possibly a higher capacity fuel pump are pretty typical fueling hardware bits. Being able to get the car tuned on a dyno is a plus.
    Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL/TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H
    VAST Performance Sucks (Updated: 27 Apr 2012)
    Senior Member Three Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2007 A4
    San Diego, CA
    I would suggest you contact Wicked Motorsports or Raven Motorsports for local support.
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    I picked up EPL's stg 3 fueling kit along with a set of K04's, haven't installed yet but I've heard great things.
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Stage 2 Banner Advertiser Two Rings Sales@EPL's Avatar
    Jun 23 2011
    Thanks for the support guys! PM coming your way OP
    European Performance Labs
    (203-345-6499)
    Sales@eplabs.net
    http://www.facebook.com/EPLabs
    Please feel free to contact us with any questions!!
    Stage 2 Banner Advertiser Three Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Long Island NY
    Go with EPL or ASP. Whatever is closest to you. Good luck!
    ELITE MOTORSPORTS
    Become A Fan On Facebook!
    Follow Us On Twitter!
    P: 631.775.6634
    1139 Station Road Suite #10
    Medford, NY 11763
    Email:kayihan@elitemotorsport.net
    www.elitemotorsport.net
    Senior Member Two Rings Fiyacracka's Avatar
    Feb 13 2008
    I wouldn't go with ASP. They're still using Siemens injectors. I switched to J-fonz and couldnt be happier
    2000 Audi S4 PJK04, J-Fonz Stage 3 (93 File), APR Bipipe, APR Snub Mount, RS4 Tranny mounts, VAST Stage 3 Clutch, piggies, 2.5 inch exhaust, AWE Intercoolers, 3 inch dp's coming soon, spal high flow fan coming soon
    Dec 01 2011
    Orange County, CA
    Quote Originally Posted by phila_dot View Post
    Thanks for all the input, everyone. Sounds like I have some major decision making to do. Wicked and Raven seem to be the only local tuners who do custom tuning. Wicked has their own in-house tune from what I hear. Or do they sell both ASP or EPL? Raven I believe sells EPL fueling. Both will tell me they won't warranty their work if I source parts on my own, so that would make it hard for me to go with the option of piecing the stg 3 parts myself.
    Are Wicked and Raven the go-to installers in SoCal? I know Eurotech motors does turbo swaps, but they are charging ridiculous pricing now.
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    As has been made clear by this thread. The B5 S4 has so many good tuning options these days.. How far we have come.
    Dec 01 2011
    Orange County, CA
    Quote Originally Posted by FlyboyS4 View Post
    I actually completely agree with you on this. I'm not looking for crazy quarter mile times. After researching tial kits and some of the other big horsepower kits, I decided that it wouldn't be a good fit for road racing. I want a good balance, and I'm actually looking into a center 4:1 diff as well as a rear LSD ($$$). That's why my stage 3 upgrade isn't "just" the turbo and fueling install. I'm looking to get my car towards a reliable track-car at the same time. I guess my question is whether certain tunes have much differing horsepower gains between different fueling kits.
    Dec 01 2011
    Orange County, CA
    Quote Originally Posted by Fiyacracka View Post
    Hmmmm...what's wrong with Siemens injectors?
    Dec 01 2011
    Orange County, CA
    Quote Originally Posted by Don Supreme View Post
    Yup...it's funny because I own a 2010 335i sedan as well, and ppl on the 335i forums went through exactly what the B5 S4 owners went through back in the day.
    Registered Member Two Rings mjacksons4's Avatar
    Oct 20 2011
    Wa
    EPL!
    [B]2001.5 S4 Brilliant Black 6sp fully gutted AMD track preped
    My Dynosheet is faster then yours
    Active Member Four Rings RedB5S4's Avatar
    Dec 06 2010
    B5 S4, K4 750
    I'd like to keep my car.
    This. Stay with a local company. It's going to be a pain in the ass ordering different things from different places, going some place else to get the car tuned, and then trying to deal with companies that are on the other side of the country.
    I find it ironic that the colors red, white, and blue represent freedom until they are flashing behind you.
    Feb 13 2008
    Idle sucks on them, EV14 injectors are always a better choice
    Registered Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Whatever you do definitely buy EV-14's. If I were you I'd go with the 72lb'ers and get a e85 tune
    the spray pattern is not the best. They idle/decel a little choppy
    K04|Eurodyne ME7|E85|No bitchassness
