Results 1 to 10 of 10
    Registered Member Two Rings
    Jan 26 2012
    Morgantown
    Which weight of oil to run in 2.8l?
    I was looking in the owners manual, but it has this stupid temperature chart that's impossible to decipher. I live in WV, where in winter, it can get down to 0 and even below on rare circumstances. In the summer, it can get up to 100 degrees. Should I run 0w40 year around?
    Active Member Three Rings ianwpb's Avatar
    Dec 11 2010
    West Palm Beach, Fl
    0-40 would work just fine year around.
    http://www.my-gti.com/2534/ for further reference. I use Castrol Syntec/edge 5W40, but as you see 0-40 is approved with a ton of other oils. Castrol is readily available at almost all autoparts stores.
    1999.5 2.8m
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Run 5w40 total quartz 9000 and don't look back. here you go.http://www.europaparts.com/oil-chang...2-8l-3-0l.html
    198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Tuning Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. 11mm Forge spacers. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings)
    BT Build Coming Soon...
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    5w-40 would be fine too (and might be easier to find)
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Jan 26 2012
    Morgantown
    Awesome. Thanks, sirs.
    Active Member Two Rings teleTay's Avatar
    Jul 19 2010
    2000 A4 Avant, 2004 S4 Avant
    SLC UT
    i use mobile 1 5w-40
    Senior Member Three Rings miggity02's Avatar
    Mar 22 2008
    B5, 8P A3
    East Bay, Nor Cal
    shell rotella t6 5w40.
    B6 1.8t Quattro sedan - lightly modded - SOLD
    B5 2.8l Avant 5mt quattro - Sport Package - JHM short shifter - K&N - Magnaflow with 2.5" piping - STs - Yak rack - 2500k fogs and highs - OEM USPs - tinted [7%/17%/35%>
    2007 8P 2.0t - 6MT - S-line - Sport Package- Premium Package - Nav - (tinted)Open Sky - Cold Weather - Bose - REVO - AFE Pro Dry - Magnaflow w/resonator delete - H&R sport cup kit - Eibach 23mm RSB - Ti wheels - 10mm spacers - BFI torque mount - AG M310s
    May 30 2008
    Quote Originally Posted by miggity02 View Post
    http://www.audizine.com/forum/showth...I-ZERO-add-oil
    -John
    Senior Member Three Rings FNK's Avatar
    Mar 07 2010
    Audi A4 2.8L 2001.5 Quattro
    Montréal, Éts
    I currently run 5w-40 oil in my 2.8 30V... however the oil temp is around 225F on the highway at 115kph... what I want to try is some 5w-30 next. If the temp stay at 200F like it's supposed to, then this would mean the heat is much better transfered.
    Yes the oil film will not have the same thickness, but it will be 25F lower too, so it should be almost the same cinetic viscosity.
    I am currently working on some Tribology problems, I will come up later with an approximation of the film thickness.
    Mar 07 2010
    Montréal, Éts
    Interesting results, indeedidly!!
    At 100C, the viscosity of the 5w-30 and 5w-40 are respectively 12.0 and 14.5 cST. [centiStoke, or 10E-2 mm²/s]
    Using 5w-40, my engine oil reach the temperature of 225F constantly on the highway.
    The Viscosity at 225F or 107C is now 12.4 cST.
    If the use of 5w-30 lower the operating oil temp to 200F or 94C.
    The viscosity would be of 13.7 cST. The film would be superior in viscosity using 5w-30 oil vs the 40 weight! So, Lower pumping loses, lower heat, more mpg and power...!?
    A more probable result would appear to be a lowered oil temperature to 212.5F. At this temp, the viscosity is about the same as the 40 at 225F, 5w-30 at 212.5= 12.0 cST.
    Considering the friction would be about the same with the oil at the same viscosity, but lower temps, an operating temp of 212.5F is therefor quite logical.
    I will be able to confirm this in the next two weeks when I'll have the time to change my oil from 5w-40 to 5w-30.
    Code:
    5w-30
    200F=13.7
    212.5=12.0
    225=10.4
    237.5=9.0
    Code:
    5w-40
    200F=16.7
    212.5=14.5
    225=12.4
    237.5=10.7
