Results 1 to 10 of 10
    Registered Member Two Rings Pletsch's Avatar
    Feb 16 2011
    Roughly 32 KC-135's ;)
    Wichita, KS
    stage 2 s4. good deal?
    Hello all. What do you guys think about the car. Is it worth the price? He said there's nothing wrong with it and lives locally.
    Any insight would be helpful!
    http://wichita.craigslist.org/cto/2826865083.html
    Active Member Two Rings frankie V's Avatar
    Mar 30 2011
    Chicago, Illinois
    miles?
    looking for a set of 18" b6 s4 avus with tires. PM me
    Feb 16 2011
    Wichita, KS
    Theres 175k on the chassis. 20k on the turbos. the top end was rebuilt 30k ago. The transmission had issues and was replaced at 140k.
    Active Member Two Rings smashed s4's Avatar
    Jul 06 2011
    san jose
    psh just buy mine;) nogaro>silver
    looks good. tons of miles though... 12k seems a bit much for just k04s with over 170k miles....
    2000 S4 6MT Stage 1 034 ECU 276 AWHP 331AWTQ SOLD
    2000 S4 6MTStage 3+, K04s, 034 Flash, 034 Injectors, 034 MAF, RS4 Accordion hose, RS4 Fuel Pump, JHM ss, AWE Twin 1, AWE LWFW & Southbend Stage 2, 18" BBS CH, X-1 Carbon Fiber Cold Air Intake, H&R/Bilstein combo
    425AWHP 435AWTQ SOLD
    2003 Carbon Black M3
    2004 Suzuki GSX 600 Katana
    Senior Member Three Rings morris400's Avatar
    Dec 18 2008
    2001 Audi S4 2007 Jeep Grand Cherokee
    Alberta, Canada
    stage 2 on k04s would worrie me.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    unitronic Stage 2+ (3-) with BW K04s, 034 inlet pipes, 710n DVs, 034 trans and motor mounts (track density), Podi boost gauge, SSAC full exhaust, OEM RS4 Grille, silcone TBB and hose kit, JHM FMIC, custom spider hose, Stern power ring rear dif mount Not installed yet.
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Um that ad says K04 turbos, which (by the wiki standards) put that at Stage 3-
    Get a new tune and a fueling kit and you have a full Stage 3 car.
    As far as the price goes, there are a couple full Stage 3 cars in the classifieds for roughly the same price. But if the car is clean and has proper documentation of all the stuff he is claiming, then it's worth what he's asking.
    Feb 16 2011
    Wichita, KS
    How does that worry you, morris?
    Active Member Three Rings nJoy's Avatar
    Dec 18 2010
    01.5 B5 S4
    Illinois (South Suburbs)
    Quote Originally Posted by morris400 View Post
    Exactly
    MTM
    Dec 18 2008
    Alberta, Canada
    It worries me cause its running a stage 2 tune for k03. but if its got k04s you need a tune for k04s. The ecu thinks its running k03s when its really got k04s. Im sure this would cause a major issue. But im sure someone will chime in with more turbo smarts then i. I was told that i need ed a.stg 3minus tune when i installed k04s on stock fueling.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Pembroke Pines, FL
    I have ran K04's on a stg2 for almost 2 years now and I have no issues at all. It went from Miami to Boston in this configuration and got about 26MPG on average HWY.
    Engine doesn't pull timing, no CEL's (except for rear O2 sensor acting up). Then again I don't beat on the car so I'm not a good judge of that.
    FWIW I am probably going to see the S4 in a few months (need bigger car).
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
