Results 1 to 16 of 16
Thread: Airbox delete?
    Registered Member Two Rings
    Dec 23 2011
    2010 B8 A4 quatro premium +, Triumph Daytona 675, Volkswagen Jetta Sportwagon TDI
    Ohio
    Airbox delete?
    Opinions & facts welcomed please. Does someone make an airbox delete for 2010 A4 Quatro, instead of a cold air intake. What are the advantages or disadvantages of either?
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Do you mean something different than an open filter system such as the APR Carbonio? That is not really a true cold air system.
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Dec 23 2011
    Ohio
    Quote Originally Posted by Stubek View Post
    I'm still new to this and lingo, I heard an air box delete was cheaper then a cold air intake and did the same thing , but don't know the exact definition of an air box delete is
    Registered Member Two Rings Boneman's Avatar
    Sep 16 2011
    Quote Originally Posted by chrisshould View Post
    Maybe they are referring to removing entire stock airbox and replacing with conical type filter? Problem with that setup is the air intake temps are increased by the adjacent hot engine. The advantage of the stock airbox is that it shields the incoming air somewhat from the hot engine bay. Plus, if you look under the hood, there is a small duct near the top left corner of grill that feeds fresh cold outside air into the airbox at speed.
    The APR carbonio intake replaces stock airbox with carbon fiber cover and uses a conical type filter. Problem is, i dont think it makes much power, and is mostly an appearance mod.
    From what i gather reading these forums, the stock air intake is not very restrictive, and does not really need to be replaced unless going with a larger turbo.
    Just my 2 cents.
    Dec 23 2011
    Ohio
    Quote Originally Posted by Boneman View Post
    Just my 2 cents.
    thanks, I think an air box delete....deletes the resenator on the front end of the factory intake which helps cut noise, and water from getting in. after removing that and adding a new air filter (K&N) then it is a decent upgrade. BUT once again im also thinking cold air intakes are probably not needed on this car
    2010 a4 quatro
    Active Member Two Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    2010 a4 quatro
    I'm not sure if there's a resonator on the intake, but there is one after the intercooler. Replacing this supposedly reduces turbo lag. Eurocode calls it a HFIP.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS ECU/Exhaust/Springs/RSB/Rims | K&N Filter | Eurocode TIH/HFIP/IHK/HFC | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | LED Interior/Doors/Plate | 5000K HID Foglights
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Nope, no resinator on the B8 and yes, the Eurocode HFIP is good.
    The 034 Turbo inlet pipe which goes from the airbox to the turbo helps with turbo lag and throttle resposne also
    Dec 23 2011
    Ohio
    What about a diverter, would u say do all 3 options. How do you like your apr stage 1?
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    I don't know much about the diverter. I ran the stock one on my B6 for 92k miles. Right now, I have APR stage 1, 034 TIP, and Carbonio. I love it. I did APR first and that is a huge huge difference. the TIP and Carbonio are really just icing. If you wait until March, APR normally has a big spring sale where the stage 1 flash is about half price.
    Dec 23 2011
    Ohio
    Just so I have it straight. The 034 is the tube behind the air box into the turbo, and the carbonio is a forced air duction now into the air box?
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    TIP yes
    Carbonio is the airbox
    Forced induction is the turbo
    Active Member Two Rings sdy101's Avatar
    Apr 14 2010
    2008 Acura MDX
    Central PA
    ..and if by diverter, you are referring to the diverter valve, then you need not worry. The B6/B7's had a diaphragm diverter valve that Stage I folks upgraded to the piston-type to avoid tears and boost leaks. The B8's already have the piston-type diverter valves (OEM), so you're good.
    Our airboxes are pretty efficient, and there are lots of threads on the Carbonio discussing pros/cons for the price. I have a drop-in K&N and will be getting my TIP here soon from EC, then the HFIP will be next. I do miss my APR Stage I tune from my B7, it made such a huge improvement in driving pleasure.
    Now: 2009 2.0T Ice Silver, Auto, Quattro, Prestige Pkg, Navigation
    Hoen Xenon-match Fogs | LED Interior Lighting | K&N Drop-in | Eurocode Turbo Inlet Pipe
    Previous: 2007 2.0T Quartz Grey, 6MT, Quattro , Premium and Convenience Pkgs
    APR 93 Octane | OEM Rev. D DV | K&N Drop-in | Apikol Snub Mount | Podi Boost Gauge | 50% tint | LED City Lights | 17" Sport Edition KV5
    Dec 23 2011
    Ohio
    ok, im following everything now except for what exactly the HFIP does, because when i looked it up it just showed the tip
    intercooler tube?
    Dec 23 2011
    Ohio
    thanks for everything i found it
    Jan 12 2012
    For performance gains, a high flow cat (HFC) is a really good bang for buck as well ($320 + install).
    Peter
    Active Member Three Rings cyberbrutus's Avatar
    May 09 2011
    Appleton, WI
    Quote Originally Posted by STA4 View Post
    Frankly speaking, I am not super impressed with my HFC. It barely made a difference to me. APR Stage 1 was a huge difference though.
    I will switch to stage 2 and see if it makes a difference.
    2011 A4 P+, Titanium, P. Black, Nav, B&O
    TD1, APR Stage 2+, HFC, Carbonio, LED I/L, VAG-COM, Hoen Xenon, Llumar 35%, 19x9.5 40F/35R AG M310 M.Black (Winter)
    Build Thread: http://tinyurl.com/3zh6mtw
    Winter Thread: http://tinyurl.com/8x3oabo
    Project B.O.B: http://tinyurl.com/7gbgf65
