Results 1 to 35 of 35
    Stage 2 Banner Advertiser Three Rings CampioniShop's Avatar
    Jan 30 2012
    Sponsorship Opportunity: MORR VS8.2 20" - 1 Piece Forged
    MonoForged™ - Lighter.Wider.Stronger.
    MonoForged™ VS8.2.
    Available AUDI fitments:
    20x9 - Audi S4/A4 - 22.8 lbs
    20x10 - Audi A5/S5 - 23.4 lbs
    20x10.5 - Audi S5 - 24.4 lbs
    *We would like to do a square - massively concave 20x10.5 setup! We have 1 spot available.
    Group buy
    Please note once we have this completed - a group buy will follow for all Audis in 19s and 20s. We expect to be able to price the 19s in the 3,000$ range and 20s at high 3,000s. Unheard of for a wheel of this quality!
    Finishes:
    Silver, Matte Silver, Matte Black, Glossy Black, Satin Black, Textured Black, Gunmetal, Satin Gunmetal, Textured Gunmetal
    Custom (anything you can imagine) + $100 per wheel
    *For the sponsorship, we are looking at doing at brushed or brushed and tinted finish.
    MSRP: $4875/set
    Audizine Sponsorship pricing (1 set): Send us a PM
    The wheels are available for delivered immediately - finishing and shipping will take 2 weeks.
    What we want in this sponsorship:
    1. Unbiased review
    2. Unboxing pictures
    3. Installation pictures
    4. Installed photoshoot (professional photoshoot will be made at our expense)
    Lighter. The new MonoForged™ VS8.2 is lighter, wider, and stronger than any of its predecessors. This weight reduction was achieved by implementing several advanced manufacturing processes including flow-forming. Flow-forming helps reduce barrel thickness by up to ten-percent. We also achieved such significant weight reduction by using Vehicle Specific Profiles (VSP) and Finite Element Analysis (FEA) by using Vehicle Specific Load Ratings (VSLR) and Vehicle Specific Weight Optimization (VSWO).
    By using VSLR and VSWO, weight can be reduced by eliminating the need of using excessive load ratings due to the wheel blanks being shared with higher rated platforms. MORR manufactures wheel blanks exclusively for every design it produces, allowing us to engineer the blanks according to the specific load ratings of the vehicle brand & model we are making the wheel for. This in turn increases our production costs, but allows us to make a far superior wheel.
    Through VSP, we can minimize excessive back spacing in our wheel blanks. Adding material to the back pad is required when sharing blanks among different platforms, increasing the weight and required excessive machining of the back pad which could compromise the integrity of the final product. Our MonoForged™ blanks are vehicle specific, thus requiring minimum machining of the back pad, resulting in a lighter wheel without compromising its integrity.
    Wider. At 10-inches wide, our new VS8.2 rears are .5-inch wider than its predecessors, widening the vehicle’s rear track, allowing for wider tires, increasing the concavity profile and improving the overall vehicle handling dynamics.
    Stronger.
    At MORR, during the design stage, our engineers run FEA simulations to ensure the weight optimization process does not sacrifice wheel strength. To ensure our wheels are ultra-lightweight and equally as strong, our MonoForged™ product line is manufactured using only the highest grade 6061-T6 Aluminum. All of our wheels conform to the strict international and domestic standards of wheel quality and manufacturing, which include VIA/JWL, TuV-Rheinland and SAE J2530 standards for the US DOT. Our MonoForged™ VS8.2 is rated at the new safety standard of 690-kg (1518-lbs) per corner and is also subject to extensive Rotary Bending Fatigue, 13-degree Impact @ 0-degrres, 13-degree impact @ spoke, Radial Load Endurance and Radial Load Fatigue physical testing.
    Product Features:
    Re-Designed - The new VS8.2 is a step above from our VS8 design. A lot of attention was given to detail during the design stages of this wheel. The spokes have been extended further out and the outer lip has been reduced, creating a larger appearance, while the spoke shape has been given more dimension through enhanced curvature. The outer lip has been smoothed as well for a cleaner, more "finished" look.
    Ultra-Concave - Being one of the pioneers of the concavity trend, the new MonoForged™ VS8.2 is the most concave 10" wheel currently available for the Audi S4/S5 with a profile depth of over 30-degrees!
    Inner Lip
    - One of the greatest challenges with the VS8 inner lip was its depth. At over 3", the availability of milling machines that were able to mill that deep was extremely limited. With the new MonoForged™ VS8.2, that lip was further increased to 3.25", further enhancing the overall look of the design.
    Optimization
    - Through Vehicle Specific Profiles (VSP), Vehicle Specific Load Ratings (VSLR) and Vehicle Specific Weight Optimization (VSWO) we can create wheel blanks that are specific to the vehicle applications. This reduces excess back-pad material, reducing weight and improving strength. The minimal back-pad spacing, as shown below, eliminates the need for excessive machining. This ensures structural integrity is not sacrificed.
    Ultra-Lightweight - The new MonoForged™ VS8.2 is one of the lightest 7-spokes wheels available. Weighing in at only 19-lbs for the front! (in 19")
    FEA
    - Finite Element Analysis helped optimized the wheel strength and remove unnecessary material for the lightest possible wheel. Even at 19-lbs (in 19"), the new VS8.2 wheel was tested at a load of 690kg and passed every FEA with flying colors.
    Pictures:
    20" E92 M3 - Signature silver
    Detail showcase on a VS8.2 Hand-Brushed w/ Tinted Clear
    Available finishes:
    Super silver
    Mystic Black
    Frozen titanium
    Flat black
    Satin Black
    Gloss black
    Smoked titanium
    Signature black
    Signature silver
    Diamond black
    Sparkling silver
    Matt / info@campionishop.com / (718) 690-3380 / www.CampioniShop.com
    Brands: Forgestar | IForged | ADV1 | COR Forged | MORR | StopTech | Akrapovic | REMUS | SuperSprint | Capristo | Eisenmann | KW | Vorsteiner | IPE Innotech
    Official NA Distributor for SuperSprint Porsche - Mercedes AMG - Audi S/RS applications.
    Active Member Four Rings Beast's Avatar
    Jul 25 2011
    Benz, Caddie
    TDoT
    you can sponsor me
    Audi A5: Prestige | Phantom Black | []S-Line
    Modz: 35% Tint, Lamin- X Smoked Tails
    Coming Soon: AWE Exhaust | B Ops Grille | Spacers | Coils
    aKa: A5 SKiD
    Senior Member Two Rings audienthusiest's Avatar
    Apr 06 2008
    nada
    CALI
    and me
    MURPHY'S LAW
    Active Member Four Rings Mops's Avatar
    Sep 28 2010
    10 VW GTI 4dr, 05 Impreza 2.5RS DD
    Wilkesboro, NC USA
    me me me.
    08' A5 3.2 6MT Avus Silver Pearl
    Build Thread
    DD: 05' Impreza RS/10' GTI
    Previous Rings:
    98' Silver B5 1.8Q
    05 BB B6 1.8Q USP
    08 Ibis B7 2.0Q S-line Ti
    Jan 30 2012
    PM PM PM PM PM us us us us us !
    We want to do this within the next 2 weeks, the set is at MORR ready to get finished!
    Jul 25 2011
    Benz, Caddie
    TDoT
    ill send you my car, put rims on, do what u want, and send car back. Deal?
    aKa: A5 SKiD
    Senior Member Three Rings NYSpeedRacer's Avatar
    Jun 21 2008
    2008 Porsche Boxster; 2008 Audi A4 2.0T, 2012 Audi A5 2.0T
    Gotham
    Too bad my Ipanema Brown A4 isn't coming in until early April!
    Sep 28 2010
    Wilkesboro, NC USA
    PM sent.
    Build Thread
    Previous Rings:
    98' Silver B5 1.8Q
    05 BB B6 1.8Q USP
    Active Member Three Rings UbiquitouS5's Avatar
    Jun 16 2010
    C350 Coupe
    Good luck to the lucky S5 owner =(
    '13 Audi S5 Daytona Gray - Maybe?
    '10 Audi S5 Prestige Quartz Gray - Sold
    '11 Audi A5 Daytona Gray - Canceled
    Jul 25 2011
    Benz, Caddie
    TDoT
    A5*
    aKa: A5 SKiD
    Senior Member Four Rings GSS5's Avatar
    Jan 27 2010
    LI/NYC
    pm sent.
    DD: Daewoo Leganza '98
    Mods: Test Pipes, Custom Supercharger, K04 Turbo, Muffler Delete, Neon Lights, Roll Cage, NO2 - 14583 FWHP < Undefeated by bknewtype
    Garage Queen: Lamborghini Reventon '08
    Mods: JHM Tune - 88372 AWHP
    Winter Beater: Audi S5 '10
    Mods: Bridgestone BLIZZAK Winter Tires - 270 AWHP
    Active Member Three Rings aLTTP's Avatar
    May 09 2011
    LaLa
    wish i had my sideskirts. i'd def want a sponsorship
    Fun Comes Usually Kneeling
    Senior Member Four Rings bader.abbas's Avatar
    Feb 04 2010
    Boston,MA
    very clean wheel
    mopsta81:"Very nice touch. You got those from bader? Wow, you have a little piece of royalty on your S5. I bet two dudes in black suits rolled up in a black quattroporte to hand deliver."
    Audi S5 '09 Meteor Gray Magma Red
    Mods: Euro Headlights,AWE track exhaust,AWE downpipes,BC Racing Coil-overs,20" D2 Forged VS1, Adams rotors, Black ops, Carbon Fiber Splitters and Valence,Tune, H&R Rear Sway Bar.
    Active Member Four Rings bknewtype's Avatar
    Jan 07 2011
    2003 g35 coupe, 2007 g35x sedan
    Brooklynnn, New York
    Love these wheels. Too bad my car is long gone :(
    Via iPhone
    2009 Audi S5: Phantom Black/Magma 2/2011-11/2011 </3
    93 Geo Prizm supercharged 439whp
    89 Merkur Scorpio twin turbo 564whp
    94 Suzuki Cultus single turbo 245whp
    90 Chevrolet Sprint ALL STOCK
    BMW Isetta 600 APR SC'ed 1095whp.
    NEW:
    1991 Toyota MR2 w/ f-18 Dual Afterburner Mod 12324whp
    Cars owned: All of GSS5's
    Jul 25 2011
    Benz, Caddie
    TDoT
    Pmed also
    aKa: A5 SKiD
    Aug 05 2011
    LI, NY
    Stunning, simple stunning. Think I found the wheels I want come spring time whether or not I get chosen.
    PM sent.
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    Daily Driver -2011 Audi A5 Prestige / Ibs White ('09 Audi A5 Premium Plus / Deep Sea Blue Pearl)
    Weekender - '97 Mitsubishi 3000GT VR4 550awhp
    Nov 01 2011
    Hong Kong
    Great wheels....lucky guy who will get the sponsorship!
    Yeah ok....then we have to wait for the group buy!
    2008 S5 tiptronic, black, 20" INCURVE M7 staggered wheels, CARGRAHIC Super Sound exhaust, K&N airfilter, H&R springs, pear silver interior, carbon, keyless go, Premium sound
    Jan 30 2012
    Thanks guys - we are answering all PMs as we speak. For those of you that cannot get the sponsorship - you will love the GB we will introduce by March !
    Active Member Two Rings 13055's Avatar
    Nov 15 2005
    Atlanta
    Id love to get it for my a5.
    Veteran Member Four Rings seph's Avatar
    2002 A4 3.0Q
    Norwalk, CT
    Pm sent. Details please
    -Ant
    2012 A5 2.0TQ 6MT Ibis white - RS4 pedals - 35% tint
    2002 A4 3.0 TIP Quattro - lip spoiler - RS4 pedals - s4 blades - s4 grill - ADR M-Classics 19" - stasis ss co's - magnaflow 14851's - RNS-E - usp front - slotted/dimpled rotors - cc mod - stealth signals - xenonmatch fogs and hi's - 35% tint - DTH USP splitter
    Jun 16 2010
    C350 Coupe
    Quote Originally Posted by Beast View Post
    A5*
    Campioni is looking for an S5. I wonder who got the lucky prize.
    Jul 25 2011
    Benz, Caddie
    TDoT
    im pretty sure it can be an A5
    aKa: A5 SKiD
    Jun 16 2010
    C350 Coupe
    CampioniShop
    CampioniShop is offline
    Stage 2 Banner Advertiser Two Rings CampioniShop's Avatar
    Jan 30 2012
    My Photo Gallery: 0
    My Classifieds: 0
    0 stars
    Re: Sponsorship
    We are on MBworld and have found the 2 MB we wanted to sponsor, we're really looking to do an over the top 20x10.5 S5 !
    Can't wait to see photos of these wheels on an Audi.
    Senior Member Four Rings staticuxo's Avatar
    Sep 16 2008
    I'm located in NY and have an S5 on coil overs waiting for 20x10.5's all around. PMed.
    [] S5 - 6MT | NAV | TECH | B&O | H&R| FAST INTENTIONS | VOSSEN CV2 20x10.5 | HANKOOK V12 275/30/20 | THULE |
    Jan 30 2012
    You guys have PMs on their way.
    P.S.: That S5 looks stunning!
    Active Member Three Rings tboooe's Avatar
    Jan 29 2012
    San Clemente, CA
    Quote Originally Posted by staticuxo View Post
    Nice...it says in your signature you are using 20/25 F/R spacers on the stock rims which have an ET of 32 meaning your final ET is 12 F/ 7 R? Is that right???
    Senior Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2010 MB Blk/Blk E350 Sport
    La Quinta, CA
    I'm in
    2007 A6 , Blk/Blk/Sport - Traded for S5
    2009 S5 6M , Phantom Black/Tuscan Brn/Loaded - Totaled
    2009 S5 6Tip , Phantom Black/Blk/Loaded - 30* tint/KW ADS Coil Overs, Überlegenes Stabilisatoren System, HR 10/20 Spacers/RS5 instrument trim/ClearBra/BB Sport Exhaust/AWE S-filter/Hoen zenon/Blk Ops Grill & Valence/LoJacked/trunk panel net/led's
    Jan 30 2012
    Guys, we have our S5.
    Thank you very much for the interest in the MORR VS8.2. For those that love this wheel but could not get the 1st set, stay tuned as we will introduce a GB following the first photoshoots at very low pricing!
    Aug 05 2011
    LI, NY
    Ya didn't think there was much love for an A5. Anyways looking forward to the pics and group-buy. Any eta on when that will be?
    Jan 29 2012
    San Clemente, CA
    Quote Originally Posted by oohnoo View Post
    I was told around first of March. Time to start saving my pennies! Really digging that diamond black color!
    2012 Ibis White S5 Cabrio | Sport Differential | Nav | B&O | Carbon Inlays | Adv Key | Parking Sensors
    Mods: Tint | VentureShield | Vertini Monaco Wheels 20x10 | Hankook Ventus 275x30 | 5/10mm spacers | KW V1 | AWE Air Filter | Black Optics | Ecodes | Int LEDs | RS5 pedals | HOEN
    VAG-COM: Voice com | Show gear | DRL no dim | VIM | LED @ 30% | No winking | Remote windows | Fogs on w/high beam
    Wish List: Flat bottom | O-carbon | SPC UCA | RS5 switches | Sways
    Feb 10 2004
    2009 A4 2.0T Sedan
    There was a slight misspelling in your original post, Matt. I fixed it for you.
    CURRENT: '95 Ur S6 Avant | '12 A6 3.0 TFSI sedan
    Sep 28 2010
    Wilkesboro, NC USA
    Congrats to the S5 and owner of course...its gonna be siiiick. No one likes A5's;)
    Build Thread
    Previous Rings:
    98' Silver B5 1.8Q
    05 BB B6 1.8Q USP
    Senior Member Two Rings AvantQuattro's Avatar
    Jul 18 2009
    a box with wheels
    I noticed that this morning....lol.
    Quote Originally Posted by mopsta81 View Post
    Oh STOP! You know we all <3 your car buddy!
    Jan 30 2012
    Thanks guys - this will turn out absolutely awesome. Expect a S5 with 20x10.5 VS8.2s in brushed and double tinted finish on these boards in the coming weeks!
    Jan 30 2012
    Since I know you guys like teasers, here are the sponsorship sets getting out of finishing yesterday. The group buy will start within 2 weeks. 19s will be available under $3,000 !
