Results 1 to 10 of 10
    Registered Member One Ring Red S-Line's Avatar
    Apr 08 2011
    Ijamsville, MD
    Question Wheel BACKSPACE question for all of you "staggered wheel" owners
    Hi,
    I am preparing to add some new wheels this summer and have some questions pertaining to the rear wheel backspace allowance on our cars. My stock 19x8.5 wheels, with a 32ET, have a 6 inch backspace (the measurement from the hub to the inner rim of the wheel.
    I plan to install 19x11 wheels (325/30-19 tires = 26.7" diameter) in the rear and I want them tucked under the car as far as they will go without rubbing on the suspension. I will use spacers to push them outside if necessary. My fronts will be 19x9 with an approximate 25 to 30 ET (275/35-19 = 26.5" diameter) so I have no worries there.
    My questions is, "does anybody know what the rear maximum backspace wheel allowance is for an A5/S5???" I can figure out the ET once I know what the maximum backspace is possible.
    Many thanks in advance...
    Billy
    2009 A5, 3.2 V6, Brilliant Red, S-line, Auto, Premium Pkg, Tech Pkg, Navi Pkg, B&O
    Jan 25 2007
    MK6 Golf
    San Francisco
    You can reverse engineer this...
    Rear
    Currently have 275/30/20 20X9 ET29 w/20mm DRA spacer no finger gap (Rubs like a b$tch)
    Previously had 275/30/20 20X9 ET33 w/20mm DRA spacer no finger gap (rubbed only slightly)
    The caveat: My rear alignment specs are unknown, or i didnt get the read out since i have raised and lowered my cars a few times after originally having 19s. You can run my exact specs if you want to add rear camber to prevent rubbing.. probably at least -1~-1.5
    2011 A5 S Line Prestige 6 Gang | Ecodes | AWE Quad Diamond Black | 034 HFC | H&R Coilovers | H&R F15mm R15mm | APR STG 2 | ABT Spoiler | Nano Fusion Clear | European 20" RS4 Wheels 275/30/20 | 70%/35%Tint | Folding Mirrors | Gloss Black Grille&Filler |
    2012 Golf Convenience 5 Gang
    May 13 2011
    san diego california
    if you're planning to run 19x11's, max tire size is 305/30/19 rear wheel et should be 30
    Apr 08 2011
    Ijamsville, MD
    thanks guyz
    Apr 08 2011
    Ijamsville, MD
    I've decided to downsize a bit and go with the following...
    19x9 wearing 265/30-19
    19x10.5 wearing 305/30-19
    thanks again!
    Veteran Member Four Rings 1SickS5's Avatar
    Jul 18 2004
    Orange County, CA
    I'm running
    20x11 305/25/20
    20x9.5 275/30/20
    No rubbing at all.
    Request an invite! - www.autohelix.com
    May 13 2011
    what offset are you running 1sicks5?
    Senior Member Three Rings NYSpeedRacer's Avatar
    Jun 21 2008
    2008 Porsche Boxster; 2008 Audi A4 2.0T, 2012 Audi A5 2.0T
    Gotham
    Quote Originally Posted by 1SickS5 View Post
    I'm running
    20x11 305/25/20
    20x9.5 275/30/20
    No rubbing at all.
    +1
    2012 Ipanema Brown A5 2.0T
    Installed Mods: 20" HRE P43s | Eurocode F & R Sway Bars | EuroCode F & R End Links | De-Badge | SPC UCA | KW v3
    Awaiting Delivery: AWE Quad Exhaust | CF Rear Diffuser | 380mm StopTech Trophy BBK| Alu Kreuz | Carbonio Intake
    Future Mods: Caractere Bumper | S5/SLine Skirts | Differential | Intercooler
    Jul 18 2004
    Orange County, CA
    Quote Originally Posted by efx1 View Post
    Offset is undisclosed from DPE.
    Sep 02 2005
    Land of beer and supermodels
    Then your information is useless, you know that right.
    2003 B6A4 || Bridgestone | BBS | STāSIS | ÖHLINS | Brembo | Rawtek turbo-back | Malone Tuned | DTH | EuroGear USA ||
    2012 B8A5 S-Line || Bridgestone | Volk Racing | H&R DRA | KW ADS coils | Rawtek quad tip cat-back | JL Audio | E-Codes front & back||
