haha no it wont! how many pictures or times do I have to say it! Im done here......
I do agree about the stud kit though however in the OP's case I dont think he needs it...
I would run a stud kit, for the price you pay for me lugs, why not get studs. It makes it so much easier to put the wheels on also. The studs I got from raven ms fit under the stock center caps still with no spacers.
2001 Audi S4 Avant - 6MT Non-Sunroof with 605s
1991 Audi Coupe Quattro - S2 look-alike Stockish DD
1983 Audi UR Quattro - 3B Swapped A2 Bodied Street Car, in progress
these are too expensive let me know what you think about these
You practically stole those wheels at that price and you gripe about $160 in spacers? The ebay ones will cost $130, soooo $30 worth the risk on cheap spacers? Not that ECS is the prime choice of spacer brand, they are still very good.
To bring this thread back from almost getting into the "2012 Hall of Fame for worst post", what year B6/B7 S4s (2006 I think?) had these as an option? And can anyone tell me the specs? 18x8, ET ???
Also guys, the A3 was offered in 2007 and 2008 with a BBS CH024 which is identical to the CH028 except its 18x7.5 (028 is 18x8). Not exactly sure on the offset...
Only because I recently picked a set of these up myself am I literally laughing out loud as I read this. Listen to witwer... "nube" and your "negaro" will look... wait for it... "kewl!" lol
Ignore others, just go by everything stated in my previous post. You NEED 40mm lugs to fit the 10mm spacers in the front, and 45mm lugs if you do 15mm in the rear. Do NOT use stock lugs with 10mm spacers, that would be your first mistake. Like I said, I would just do 10mm all the way around so you dont have mismatching lugs (40mm and 45mm) that could get mixed up later down the road. Plus, 10mm all the way around is the perfect stance:
Lulz, stance is subjective but that is so far from perfect. Idk what to say.
If they were my wheels and my s4 I would have 20mm minimum in the rear and probably a 15mm in the front. But then again I wouldn't bother.
well thanks for all the advice!! i got the info i needed, and some!
definatly coming back to audizine i posted a thread on other forums all i got was cocky ***gs with hating comments! lol
