Page 3 of 3 FirstFirst 123
Results 81 to 87 of 87
  1. #81
    Active Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2011 Mustang GT, 2008 ZX6R
    Iowa City
    Quote Originally Posted by tayone415 View Post
    It doesn't sound good now with my res delete. But after suggestions and advice from this thread I'm down to either getting larger injectors and the stage 1+ tune or the HFC/TP with stage 2 or a catback then after all that get a CAI and FMIC. In the end I'll get all of them I'm just trying to figure out what to next since I can't afford all of it now and don't want to wait to get it all at the same time.
    Do the injectors and 2+ tune now, just tell them you have a gutted cat. Then save up for an exhuast/downpipe and a FMIC in that order. Don't do a "CAI" until you are using a large frame turbo, the stock box is more than sufficient and better yet, idiot-proof.
    2011 Mustang GT 5.0 - 419/378
    2003 B6 A4 TQM - 187/232
    --14.168@94.16 mph STOCK K03--
    2008 Kawasaki ZX6R - ?
  2. #82
    Active Member Two Rings tayone415's Avatar
    Jan 01 2012
    San Bruno CA
    Quote Originally Posted by vteckiller2000 View Post
    What is the reason not to get a CAI?
    KO3s Upgrade, APR Stage 2, 710N DV, Intake, Res delete, 034 HFC, Lowered on Springs, Autometer Boost gauge, New South Steering column gauge pod, Pioneer double din dvd player, fully tinted
  3. #83
    Jan 22 2011
    Iowa City
    It will in all likelihood make it slower. Maybe if you cut a hole into the fenderwell, but it will then be in a low pressure area and it may actually still lose power. The stock intake manifold is very well designed and works well even with big turbo setups.
  4. #84
    Jan 01 2012
    San Bruno CA
    Right now, I have just have a cone filter, which seemed like it helps spool faster, but most likely after short while and driving hard I get heat soak. I been meaning to put the stock intake back on the last few days, but I love hearing the sound of the DV. So would a drop in filter make the DV audible? And would APR's Carbonio CAI and AFE's pro dry stage 2 CAI be a waste of money?
  5. #85
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Quote Originally Posted by Pothole View Post
    http://www.ecodetuning.com/shop/cart...t_detail&p=564
    best place ive found to get he injectors, 1+ is a very fun set up
    and a text pipe or HFC will only make you more happy, I am currently 2+ on APR with a 034 HFC and it is night and day feel over a stock 1.8t
    THIS!
    198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Tuning Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. 11mm Forge spacers. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings)
    BT Build Coming Soon...
  6. #86
    Jan 01 2012
    San Bruno CA
    Did your MPG drop a lot after the larger injectors and re-flash?
  7. #87
    Jan 01 2012
    San Bruno CA
    Any opinions about raceland. I was looking at this 3" e-cut out
    http://www.racelandus.com/exhaust-sy...st-system.html
