Page 1 of 3 123 LastLast
Results 1 to 40 of 87
    Active Member Two Rings tayone415's Avatar
    Jan 01 2012
    San Bruno CA
    Performance Upgrade Suggestions
    I have a 02 A4 1.8T
    Only Performance Mods so far...
    APR stage 1
    Upgraded DV
    KO3 to KO3s with different internals (NOT sure what exactly I bought it used)
    Resonator delete
    Intake filter/Breather filter
    I'm thinking of getting reflashed to either stage 1+ that requires injectors but I heard the HPFP should be replaced to avoid fuel cut and a FMIC to prevent heat soak while stage 2 that only requires a TP or HFC. But my timing still sucks so was also thinking of getting a adjustable cam gear but don't know how that works after an ecu re-map or getting the sprint power booster converter from ecs tunning?
    http://www.ecstuning.com/Audi-B6_A4-...tle/ES1896878/
    Any ideas or advice? Thanks in advance.
    BTW this is a daily driver and I CAN'T afford or do BT so that's not an option.
    KO3s Upgrade, APR Stage 2, 710N DV, Intake, Res delete, 034 HFC, Lowered on Springs, Autometer Boost gauge, New South Steering column gauge pod, Pioneer double din dvd player, fully tinted
    Feb 17 2004
    Round Rock, TX
    you have a B6, no HPFP to worry about. Get a HFC and the stage 2+ flash (larger injectors) and you'll be set for a while. Don't waste your time with adjustable cam gears or sprint boosters (which just screws up the throttle response)
    2002 A4 1.8TQ 5M. 182k+ miles
    FWD-->Quattro swap, Frankenturbo + MTM, Valeo SMFW/clutch, 034 HFC, Mototec exhaust, ER sport FMIC, S4 e-codes, USP front lip, Zender trunk lip, Stoptech 355mm front/B7 S4 rear brakes, Stasis Ohlins SL COs, Neuspeed 21mm RSB, Sportec Mono 10 (rep) wheels, B6 S4 nogaro alcantara front seats, Euro shift knob, JHM short shifter, B7 console, RS4 pedals, OEM brushed interior trim, SII+, TT-S MFSW, color instrument cluster, Alpine PDX-5, IDQ 10" sub
    Senior Member Three Rings Pothole's Avatar
    Jun 02 2008
    2004 Audi A4 1.8T Quattro 6Spd, 1997 Jetta Trek
    Kirkland Washington
    http://www.ecodetuning.com/shop/cart...t_detail&p=564
    best place ive found to get he injectors, 1+ is a very fun set up
    and a text pipe or HFC will only make you more happy, I am currently 2+ on APR with a 034 HFC and it is night and day feel over a stock 1.8t
    Please Drive Right
    FS: TT ballast, GTI Stock Springs, 2.0 Cams
    Feb 17 2004
    Round Rock, TX
    Quote Originally Posted by Pothole View Post
    these work just as well: http://ecodetuning.com/shop/cart.php..._detail&p=1229
    Jan 01 2012
    San Bruno CA
    How long have you had the stage 2+ because from stock to stage 1 I been told the same and I did notice a change but after 2-3 days it felt boring and slow again.
    Jan 01 2012
    San Bruno CA
    Quote Originally Posted by Matt Devo View Post
    So the b6's don't suffer from fuel cut with larger injectors?
    Active Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2011 Mustang GT, 2008 ZX6R
    Iowa City
    Quote Originally Posted by tayone415 View Post
    No way, I have had mine 2+ for a couple thousand miles and it feels much faster than stage 1. You should do injectors and a hfc/testpipe and drive it that way until the mod bug bites again.
    2011 Mustang GT 5.0 - 419/378
    2003 B6 A4 TQM - 187/232
    --14.168@94.16 mph STOCK K03--
    2008 Kawasaki ZX6R - ?
    Jan 22 2011
    Iowa City
    No. If you have a fuel cut feeling, you have a problem which needs correcting.
    Jan 01 2012
    San Bruno CA
    Quote Originally Posted by vteckiller2000 View Post
    Sounds good I'm just to impatient to save up for both the larger injectors and the TP/HFC. Which would give higher gains? APR's website estimates the stage1+ but not the stage 2 or 2+ and I'm not worried about paying 2X to the reflash the car since it will only cost me $60 for each software upgrade
    Jan 22 2011
    Iowa City
    Sounds good I'm just to impatient to save up for both the larger injectors and the TP/HFC. Which would give higher gains? APR's website estimates the stage1+ but not the stage 2 or 2+ and I'm not worried about paying 2X to the reflash the car since it will only cost me $60 for each upgrade
    The reflashes for 1+, 2 or 2+ are no charge from your apr dealer. The big injector file will make it feel meatier everywhere, and the hfc/tp will free up the top end, help spool and is a good start to a full 2.5" or 3" exhaust.
    Jan 01 2012
    San Bruno CA
    034 motorsports charge a $60 shop fee for the software upgrades between stages...at the same time I'm trying to build more of a sleeper because of the area I live in, I was thinking about getting an electronic cut out but as far as spooling I'm boosting @2000rpms and by 3000-3-5000 I hit 15-18 sometimes 19 psi by then. But my mpg is at around 12-15. How much decrease did you see after the larger injectors and apr file?
    Jan 22 2011
    Iowa City
    That is BS, my local tuner told me the flashed should be no charge per APR. I actually saw an increase in mileage, but I don't dog it everywhere. With the stage 2+ flash I see 20-21 lbs spike and 10 psi at 6500 rpm.
    I get 25-35 in town depending on my route and how many lights I hit and around 30 on the highway. I have seen as high as 40 in town, but that was hypermiling HARD.
    Jan 01 2012
    San Bruno CA
    APR doesn't charge for the new files but 034 motorsports charge a $60 shop fee each time. What other mods do you have besides the obvious tune and required larger fuel injectors and did you go TP or HFC?
    Jan 01 2012
    San Bruno CA
    Any opinions on getting an electronic cut out on 2.5 or 3" piping to stock exhaust?
    Jan 22 2011
    Iowa City
    That is really weak. Powerwise mine is on the stock k03 turbo, 93 octane Stage 2+ APR tune with TT225 injectors and test pipe, APR TIP, Borla 140100 with the front pipe section (2.12") cut out and replaced with 2.5", Techtonics 2.5" downpipe, and 710N DV. I also have a foam air filter element in the stock box and I have a FMIC going on this saturday.
    Do it, I am going to do an e-cutout on my downpipe as soon as I recover from the clutch/flywheel/FMIC purchase...
    If you are concerned with exhaust being loud, there are a couple of quieter systems like my Borla, the Techtonics (which uses Borla muffs) or the Milltek. None are cheap.
    Mine, for reference:
    Jan 01 2012
    San Bruno CA
    I'm in BS California we only have 91 octane and a TP is from what I read is about a $2-2.5k fine and a federal fine or something but 034 motorsports said the difference between their TP and HFC is only 2-3HP
    Miltek is way too expensive, Borla I can get a decent price on but I'm going for more of a sleeper this time, it's my daily driver.
    Jan 01 2012
    San Bruno CA
    Any opinions on getting either the Forge 004 splitter or 007 or 008 DV and a MBC?
    Jan 22 2011
    Iowa City
    Any opinions on getting either the Forge 004 splitter or 007 or 009 DV and a MBC?
    Use a DV. MBC is not very friendly with our car's relatively smart computer and tiny insta-spool turbo. Much better setup and more daily friendly to get a tune for injectors. The MBC won't do much if you already have a tune and the stock n75 is far better at modulating boost.
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    It does not matter what you do, as long as you are on the stock turbo, it's always going to be a sleeper... You just get to choose noisy or quiet.
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Jan 01 2012
    San Bruno CA
    Quote Originally Posted by EErie B6 View Post
    I want something quiet. I love coming from behind ricers trying to showoff then passing them up or driving side by side letting them hear the sound of the DV and watching them back down. I might just get a electronic cut out.
    Dec 18 2011
    Colorado Springs
    you can hear your DV??????
    I can only hear mine in 2nd if I really listen for it...
    '03 Crystal Blue A4 1.8T - ECS Tuning Snub Nose - AFE Filter - Joey Modded headlights (HID) - Stained Yellow Fogs - Smoked Tails & Side Markers - 20% Tint - Modded Airbox - Test Pipe - Prior owner D-bag cut off mufflers - N249 Reroute - Reversed DV -
    Jan 01 2012
    San Bruno CA
    Quote Originally Posted by B6A4Dave View Post
    After getting rid of the restrictive stock air intake and just installing a cone filter and breather I can hear it in all gears and revving it on a stand still and in reverse actually in my car it's a kinda too loud at times.
    May 30 2008
    since when do ricers back down?
    ...and the moment you try running one, its going to smoke you.
    you asked if the difference from 1 to 1+ is going to be boring in 2-3 days, the answer is yes... and in the grand scheme of things you will still be slow. Most minivans on the road today will still be able to put you away.
    Not sure if you know this or not, this is just kind of an FYI...
    the only difference from stage 1 to 2 or 1+ to 2+ is a CEL. The tune is exactly the same. The "2" just ignores the cat efficiency code... so don't expect power from the "tune" when you upgrade b/c the power comes solely from the TP when and if you upgrade that.
    -John
    Jan 22 2011
    Iowa City
    Exactly, if you are going to reflash it, just go to the 2+ file in anticipation of the tp/hfc.
    Jan 01 2012
    San Bruno CA
    I had quite a bit of ricers slow down and stop revving when they heard the sound of the DV mine is loud especially when I hit 16-18 psi sometimes 19 psi I know 1 to 1+ is only a difference of 20 HP and 35 lbs of TQ but when I called my APR dealer they said the stage 2 tune does a little more than just delete the CEL from the HFC or TP but it's not as good as stock to stage 1.
    Are you still getting smoked by ricers? I've only messed with ricers that were N/A.
    Jan 22 2011
    Iowa City
    I got "raced" by some jackwagon in a quad cab Dodge ram with a hemi 5.7 when I was trying to thread the needle in traffic. I only just pulled ahead in time...
    Senior Member Four Rings BUSAfREAkA4's Avatar
    Dec 17 2009
    Busa has a 1.3L engine so ill call it a small compact
    NJ All Day
    Lol...your in a 1.8 stage one, its not a racecar. Drive it like the lux sedan it is. You want power, get an s4.
    -Nick
    REDRUM
    seph: who's ricky and why were you at his place with all those dildos?
    Jan 22 2011
    Iowa City
    Quote Originally Posted by BUSAfREAkA4 View Post
    And the 12 city mpg that comes with it...
    Jan 01 2012
    San Bruno CA
    I know it's not a racecar but it's faster than most stage 1 cars, and I'm waiting to get money to buy an s4 but I'd be getting the b5 platform for the 2.7T motor.
    I already avg 12-15 mpg highway/city
    Senior Member Four Rings waldo1324's Avatar
    Apr 06 2009
    only the immortal 02A4TQ5sp staring at me...laughing
    The StL
    if you have a 007 you can def FEEL it like its kicking your air pedal.
    and yah ** maybe a few minivans may smoke us, and ricers beat us,, but ill be damned if they dont have wet dreams about the way we look!
    ""GHETTO MODIFIERS"" member #1
    Forge 007/ Neuspeed snub / Lou Kang TIP / 2.5" TBH / Vent Gauge / BKR6E / airbox gutted / hacked off shifter / K&N filters / SAI delete / N249 delete / JVC head Kenwood EQ + mono amp Alpine type r 10" / M1 0-40
    buy my N75-R / front headrests / engine cover
    *APR II savings meter: 27.4% im buying whuuuls! f a tune
    Jan 01 2012
    San Bruno CA
    You must of really out drove him, I don't see how you'd keep up otherwise?
    Jan 22 2011
    Iowa City
    Vbox likens my 0-60 to 5.8 seconds when I was on the stock downpipe and clutch. It would fall off pretty quick after the 1/8 mile though...
    Those Dodges are roughly high 14, low 15 second trucks in the quarter with around a 90 mph trap speed*
    *on a good day
    Dec 17 2009
    NJ All Day
    Just buy the motor and swap it into the b6
    -Nick
    REDRUM
    Jan 01 2012
    San Bruno CA
    *on a good day
    I stay racing on the street hopefully I'm already 2000 rpms boosting because of the turbo and throttle lag and on the freeway my high end is shit after 80-90 mph I need lots more work.
    Jan 01 2012
    San Bruno CA
    I'd love to do that I like the b6 body so much more than the b5 but I live in shitty ass CA and there's no way that swap would ever be legal.
    Active Member Three Rings DNasty777's Avatar
    Aug 01 2010
    '69 Plymouth Valiant
    Rochester NY
    Stop street racing, seriously. And to be fast after 80-90 you're going to need a larger turbo.
    2003 A4 1.8TQM
    [Tein S.Techs][Bilstein Sports][RPM 505s][RAI TP][Milltek DP][TT225][Uni Stg2][Magnaflow 16601][Hyperboost DV]
    --Dave--
    Senior Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Do you have one of these? I do, and I've found that it's the best thing at scaring the ricers. Of course, I do have a turbo, so there's no need to fake it, per se. However, this thing gives me extra psi sound. Prior to installing it, I loosened one of my FMIC clamps to create a slight leak so that I could get a whistle.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by kwimberly View Post
    I bought two of them so I could get stereo turbo
    Nobody eff's with me now.
    Still have all my hoses and check valves and proud of it!
    Senior Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Huh? More like most stock cars are faster than a stage 1 B6 1.8t.
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    This thread is making me laugh.
    OP it sounds like you need to get your car in shape before you start throwing more money at mods. If your stage 1 isn't significantly faster than stock you've got engine issues. Get a boost gauge, or borrow a Vag Com from someone and log your boost. I bet its far below the 18 PSI a stage 1 tune should clock in at.
    Also you want to get an adjustable cam gear to fix a timing issue?!
    Again, if you're averaging 12mpg in a 1.8t you have issues. I dont care how bad the traffic is, I don't even think its POSSIBLE to get that low on a stage 1 1.8t...
    Restrictive stock filter? Turbo spooling in neutral? Hearing the turbo in reverse? Troll?
    Not sure where to start....
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
