Results 1 to 40 of 73
Thread: F"&K my life
    Dec 16 2011
    Bronx,NY
    F"&K my life
    My freaking clutch went! I can't shift into any gears while the car is on but can when off and when in a gear it moves even with the clutch pushed in...Poor freshman college student with no money for even the basics. Any help? Recommendations? Something. Im loosing my freaking mind.
    Senior Member Four Rings DownhillA4's Avatar
    Jun 23 2008
    Around
    Quote Originally Posted by Miguel4u2 View Post
    Sorry I can't be helpful, but an Audi A4 is not meant for someone who can't keep a slush fund for OEM maintenance problems.
    For Sale- 2004 A4 OEM Exhaust System
    WTB: Front Passenger Doorblade (B6 Model/Unpainted)
    Dec 16 2011
    Bronx,NY
    well, it just hit when at my worst. If this would of been a 2 months ago i would be fine and gotten a stage 2 or something. Any place to get a cheap clutch? or transmission?
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    Fast Audi sedan, Slow Subie wagon
    SL,UT
    how did it go out? seems kind of sudden for the symptoms its having.
    and yes, an A4 is hardly a poor college kids ideal vehicle
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    FYL!
    Look for the Valeo clutch/SMF flywheel conversion. It's fairly inexpensive ($400 ish iirc) and people seem to think it works pretty well.
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Dec 16 2011
    Bronx,NY
    Just driving home while attempting to switch to 3rd gear, it would not let me so i tried to put it back in 2nd and was unable to. It drives but just can't shift gears while the car is on and clutch still grabs when pedal is pushed all the way down, could it be fluid? Or the stick itself? shifting was not smooth at all the week before but i did not really pay to much attention to it.
    Sep 17 2006
    SL,UT
    i would check your hydraulic fluid level and inspect the master and slave cylinders just in case there is some anomaly. the disk probably just wore to its natural death though. its a cheap fix if you do the labor yourself. but expect to be raped if you take it to a shop.
    why do you need a new transmission?
    Senior Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    Trek 4500, 1972 kawasaki F6 125(for sale)
    north new jersey/boston, ma
    Maybe try to find someone that is parting out a B6, or upgrading to a performance cultch and get their used clutch for the time being? not ideal but maybe you can deal.
    I feel your pain as i am also a "poor" college student.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Sep 17 2006
    SL,UT
    if you're in college with an Audi, especially modded, you're not "poor"
    call mommy and daddy, I'm sure a shop will take their CC info over the phone
    Mar 27 2005
    Ducati S2R & Land Rover Discovery 2
    Tampa Bay Area
    Can't you find someone in the Bronx to steal you a parts A4 for a couple of 40's?
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin/Swift Suspension w/ H-Sport Sways
    -STaSIS/Alcon 355mm Mono4 BBK & 305mm Rear
    -STaSIS 4:1 Center Diff & STaSIS LSD Rear Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    I have a good condition stock clutch disk and pressure plate laying on my garage floor, taking up space.
    Look over the hydraulic system, if that's fine and you want a cheap OEM replacement, PM me.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Don't hate me but here is an idea, buy an ebay clutch. They are cheap, and would only really be a temporary fix. One of my friends ran a ebay clutch in his 60trim b5 a4 and it held up decently.
    Senior Member Three Rings iamshayan's Avatar
    Jan 13 2010
    b61.8gTrs 5mt quattro
    Toronto Canada
    Quote Originally Posted by Turbwhistle View Post
    Vaelo also sells a clutch kit for around 350$ look for that one.
    Also man up and change that shit yourself I'm a poor college student my whole transmission took a shit on me and I swapped it out in my driveway layin on my back.
    static
    Because who doesn't trust a dog dressed in a business suit.
    I miss my usp center grill.
    Senior Member Four Rings waldo1324's Avatar
    Apr 06 2009
    only the immortal 02A4TQ5sp staring at me...laughing
    The StL
    Quote Originally Posted by Dan[FN]6262 View Post
    check hydro, then get this^ (or pirate one from a junkyard B6).. then print out your DIY and go cut some knuckles.
    i somehow keep mine running with no money either..its like apersonal challenge and ive never had so much pride in a car i work on myself.
    ""GHETTO MODIFIERS"" member #1
    Forge 007/ Neuspeed snub / Lou Kang TIP / 2.5" TBH / Vent Gauge / BKR6E / airbox gutted / hacked off shifter / K&N filters / SAI delete / N249 delete / JVC head Kenwood EQ + mono amp Alpine type r 10" / M1 0-40
    buy my N75-R / front headrests / engine cover
    *APR II savings meter: 27.4% im buying whuuuls! f a tune
    Jan 13 2010
    Toronto Canada
    Quote Originally Posted by waldo1324 View Post
    this made me smile ... me too.
    static
    Apr 06 2009
    The StL
    Quote Originally Posted by iamshayan View Post
    i.. just.. love her...snifffff.... SO MUCH!
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    2010 A4, 2000 S4, 2003 A4 Avant, 2007 Dodge Caliber
    Falcon, CO
    It sounds more like the slave cylinder died and/or it needs to be re-bled. I would check this first.
    2010 A4 Meteor Gray ~ DD.
    03 A4 Avant ~ Polar White ~ 2.7TT Swap/Build thread
    Senior Member Two Rings Samir4486's Avatar
    Jul 02 2008
    04 A4 1.8TQ 6MT
    ATX
    Like a few suggested check your slave/master cylinder first. I had a similar issue where i couldn't change gears at all and thought my clutch was out, replaced the slave and master and it was all good.
    2004 1.8TQM/Revo stage II/034 HFC/TT downpipe/V-maxx/19" VMR VB2/
    Dec 07 2009
    Quote Originally Posted by sean1.8t View Post
    lol
    Diode Mod!!
    -Andrew
    Active Member Three Rings A42007's Avatar
    Jan 12 2011
    07 A4, 1989 Jeep Cherokee
    Phoenix, AZ
    Looking at $800+ easy for a shop and parts. Mine went out in my Honda, got all the parts from Honda on a buddies discount and spent about another $500 for the shop too install.
    My Build Thread - http://www.audizine.com/forum/showth...di-07-A4-Build.
    2007 B7 A4 - APR Stage II / Magna Flow Cat Back / 2.5" TP / ST Coilovers / 19x8.5 ET 32 RS6 Reps / Aftermarket Navigation / 235/35 Hankook Ventus V12 Evo's.
    Registered Member Two Rings
    Jul 15 2011
    Kennesaw, GA
    A short-term loan from your parents is always an option!
    Jan 12 2011
    Phoenix, AZ
    Double Post....
    Dec 16 2011
    Bronx,NY
    Full time job as well, no mom and dad money here
    Dec 16 2011
    Bronx,NY
    Quote Originally Posted by OEM View Post
    MY dad owes me money, not an option..
    Dec 16 2011
    Bronx,NY
    I would love to do everything myself which i try to( did the coils and vcg myself) but i do not have a garage available and i really cannot do it in the street. How much would it be to replace the master and slave cylinder for both parts and labor? I am not broke, but money is just going more into bills than anything else currently and i can't afford to have the clutch go out on me so hopefully its the fluid or cylinders.
    Dec 16 2011
    Bronx,NY
    Which is more cost effective, replacing the clutch or a whole transmission?, i can get one for like 350. Thats why i ask about the transmission
    Dec 16 2011
    Bronx,NY
    You will be the first if i am replacing! Thanks for the offer.
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    I bet its a hydraulic problem as well. If your trans isn't going into gear at all, its possibly as simple as the clutch isn't physically releasing because the slave rod isn't pushing the pressure plate. Did you check the fluid levels? the brakes and the clutch use the same fluid/reservoir, on top of the brake master cylinder.
    You guys are being supremely unhelpful btw. Isn't it you guys who are always annoyed when people assume you're Mr. moneybags because you drive an Audi? And you're telling me you've never been blindisded with a problem at a time when funds are low? Bunch of haters on here this morning...
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Jul 02 2008
    04 A4 1.8TQ 6MT
    ATX
    The slave cylinder isn't that hard, the master was much more of a PITA but not impossible to replace if you're patient.
    i used this DIY to get an idea of what to do:
    http://www.a4mods.com/index.php?page...tml&category=1
    slave cyl:
    BTW is your clutch pedal normal? mine would stick and only come back halfway up when this happened to me?
    Jan 13 2010
    Toronto Canada
    Quote Originally Posted by Samir4486 View Post
    slave cyl:
    I have an extra slave cylinder if needed too, just pay shipping.
    static
    Senior Member Four Rings onceover's Avatar
    Jun 08 2008
    Calgary AB Canada
    Generally a (new or used) transmission wont even come with a clutch, since the clutch is actually bolted to the engine. No sense in spending money on something thats perfectly operational anyways.
    Start with bleeding the slave, if that doesnt work, clutch time
    2004 Audi A4 1.8T // quattro // 6 Speed // Brilliant Red
    Built 1.8T || AEB || revo || GT3076R
    1991 BMW ///M5 3.6 // 5 Speed // Macao Blue Metallic
    BetaAlphaTau Member #111
    Jan 02 2011
    Holy shit, audizine really pulling together, one person with a slave cylinder, and another who will hook op up with a stock clutch.
    Jan 12 2011
    Phoenix, AZ
    Check for leaking fluid, best case scenario it could be a bad seal. The clutch system is relatively simple, not a lot of places to look. Start with the small and cheap stuff first and work your way up!
    Apr 06 2009
    The StL
    and ill overnight a shop towel
    Jun 27 2011
    I'll send positive thoughts. For free!!
    -CP
    Dec 16 2011
    Bronx,NY
    I love audizine, you are the most helpful people! Anyone who has offered parts will be first on the list if i need it, as of right now i am awaiting income tax check to do a proper diagnosis and repair. I am hoping for it to be either the slave or master cylinder, there is enough hydraulic fluid in the reserve, is that the brake fluid as well, And how will you be able to tell if its the slave of master cylinder?
    Dec 16 2011
    Bronx,NY
    slave cyl:
    While driving it does tend to stick but eventually comes all the way up, ant diagnosis for this? Thanks for the info
    Dec 16 2011
    Bronx,NY
    Thanks for the offer, ill be sure to shoot you a pm when needed!
    Dec 16 2011
    Bronx,NY
    Ill hold you to that xD
    Jun 27 2011
    slave cyl:
    That picture is just so wrong...
    (Trying so hard not to make a penis joke...)
    -CP
