Results 1 to 7 of 7
    Stage 2 Banner Advertiser Three Rings CampioniShop's Avatar
    Jan 30 2012
    FORGESTAR wheels: In stock and new sets!
    CampioniShop presents Forgestar wheels. An exciting new company that debuted in 2009 with exciting new designs, manufacturing technology and unmatched pricing! It is that time of the year to prepare for the upcoming track season, get in on this opportunity to get great wheels at unbelievable pricing! We are one of Forgestar's biggest dealer and as such offer year-round specials on all their products!
    About Forgestar Performance Wheels:
    Introducing the World's 1st 1 piece lightweight flow formed wheel lineup.
    • 1 piece flow formed wheels
    • Lightweight
    • Clears big brake kit
    • Great range of offsets
    • Same Technology Used on Formula 1 and Indy Cars
    • Standard finishes: Gloss black, Matte black, Textured black, Silver, Gunmetal, Textured Gunmetal, Matte Gunmetal, Frost white, Race gold
    • Custom made: 8 weeks lead time for production
    • TPMS compatible
    • All Forgestar wheels are provided with metal hub centric rings in order to mount the wheels.
    • 18" Forgestar F14 have passed at a 1520 LBS or 690KG load rating and have JWL and VIA certification!
    F14 Weights (will vary slightly depending on offset and wheel selection):
    18x8.5: 17.6 lbs
    18x10: 18.2 lbs
    19x8.5: 22.5 lbs
    19x10: 24.7 lbs
    Pricing:
    PM for pricing.
    MSRP (per wheel)
    F14
    18: $440
    19: $505
    20: $640
    22: $790
    CF5
    18: $440
    19: $505
    20: $640
    CF10:
    19: $505
    20: $640
    F10:
    20: $615
    For more wheel info:
    http://www.campionishop.com/products...nd=5004&clev=0
    FLOW-FORMING
    Forgestar's flowforming process is a unique solution to a common problem – how to make a wheel both light and strong.
    This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
    This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
    Cancellation policy:
    Custom wheel orders cannot be canceled once the wheels are in production.
    The making of a Forgestar wheel:
    http://www.youtube.com/watch?v=uGYedhVpYgU
    Pictures
    R8 Spyder
    CF5
    Brushed Charcoal [NEW FINISH]
    19×8.5 Front
    19×11 Rear
    B7 S4
    F14
    19×9 Front
    19×9 Rear
    Textured black
    S6 V10
    F14
    20×9 Front
    20×9 Rear
    Piano black
    B8 A4
    F14 Brushed Titanium
    19×10 Front and Rear 255/35/19 Toyo Proxes
    S5 Cab
    20×8.5 fronts Nitto Invo 255/30-20
    20×10.5 rears Nitto Invo 305/25-20
    F10
    Piano Black with a Hyper Polish Step Lip.
    S5
    20×9.5 F
    20×9.5 R
    Matt / info@campionishop.com / (718) 690-3380 / www.CampioniShop.com
    Brands: Forgestar | IForged | ADV1 | COR Forged | MORR | StopTech | Akrapovic | REMUS | SuperSprint | Capristo | Eisenmann | KW | Vorsteiner | IPE Innotech
    Official NA Distributor for SuperSprint Porsche - Mercedes AMG - Audi S/RS applications.
    Jan 30 2012
    Sets in stock
    Audi A4/A6/S5
    CF5
    Flat Black powdercoat
    20x9+42 square setup
    1849 shipped
    F14
    Race gold
    19x9+42 square setup
    1549 shipped
    F14
    Matte black
    20x8.5+38 square setup
    1849 shipped
    F14
    Gunmetal powdercoat
    20x9.5+37 square setup
    1849 shipped
    A5/S5/RS4
    CF5
    Gunmetal powdercoat
    19x9+24 square setup
    1549 shipped
    Veteran Member Three Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Not generally a fan of the black/gray wheels look, but I'm liking everything about the wheels on that R8. Those are available for order in 19x8.5 I assume? Any way to PM me a pricing for a set of those in that finish or something a little lighter in color for a B8 S4?
    Trample the Weak; Hurdle the Dead
    l 2011 S4 l Prestige l 6mt l Brilliant Black l Black/Red Silk Nappa l SRD l 35% Ceramic Tint l Milltek Non-Resonated Exhaust & Downpipes l VMR V710 19x9.5 ET45 Gunmetal
    Jan 30 2012
    You have a PM!
    Jan 30 2012
    Still have these :)
    Jan 30 2012
    Bump!
    Jan 30 2012
    PMs were sent!
