Might help if we knew what you were trying to hook up, due to location/proximity of fuses to your equipment. Also, if you don't require 12v it may open up other options.
I recently tapped into my garage door opener fuse (front drivers side panel) to use for the remote turn on input of my new amp, but later learned it doesn't have power with the keyfob in the ACC postion (only the engine on position). NBD though, since I don't sit in my car listening to the stereo with the engine off, but that may not work for you.
http://www.sears.com/shc/s/p_10153_1...=1328072650556
These are cheap and work pretty well but I'd just go ahead and invest in a decent DMM, you're likely to need it again in the future.
