Results 1 to 3 of 3
    New Member One Ring
    May 27 2011
    sammamish
    What is a good diff for a 4000cs when I go rwd?
    is there a strong rear dif I can use in my 4000 that has LSD? I'm going to be swapping in a Nissan sr20 and converting to rwd pretty soon and I'm trying to get everything for it now. Just hoping I don't have to make a custom rear end too because its already going to be a lot of work
    Jan 25 2012
    Ankeny, IA
    im assuming you want IRS in which case BMW 3 series lsd (e30 ish) are cheap and usually fairly available... 4 bolt driveshaft and 6 bolt axle shaft inner cups...
    Veteran Member Two Rings
    Feb 16 2004
    Long Beach, CA.
    You can stay with the stock diff. A lot of guys are running high HP, through those diffs. They have more problems with the axles, than the diffs.
    Greg
    The can have my car when they pry my cold dead fingers from the steering wheel
