Results 1 to 40 of 49
    Active Member Three Rings
    Jun 18 2010
    00 S4 Vast Stg 3, 06 Pontiac Gto
    Fort Lauderdale Florida
    Dentist drill = Engine pull on franken turbos.......Need some advice
    So i have the dentist drill with my Franken Turbos.....Driver's side......I believe its due to the down pipe spring being wound to tight. It was cut to make the down pipes fit. ssac down pipes.
    I'm going to have at least the drivers side turbo rebuilt maybe the passenger side too since its under the 1 year warranty for the next three days ($250 a turbo).
    Thanks Doug @ franken turbo for extending the warranty period as there is no way in hell those turbos are coming out that fast...
    1 - Now I have to decide to return the car to stock.....and sell the stage 3 pieces separate (not part out)
    2 - repair the turbos and sell it stage 3
    3 - Anyone in south florida willing to work out a trade deal with cash on top of parts swap........
    4- keep it and possible buy a lower mileage motor and do any extra repairs while I'm in there ? current mileage 145k
    Here is the list of stuff and the repairs been done......
    Upgrades
    Franken turbos
    H&R springs + bilstein shocks
    034 ko4 inlets
    Vast tune
    Awe intercoolers
    Samaco hose kit
    Apr bi-pipe kit....
    034 housing with hitatchi MAF
    custom cold air intake
    SSAC down pipes
    UUC exhaust
    dutechworks fuel pump
    rebuilt tranny
    replaced rear calipers with new
    replaced front calipers with rebuilt ones
    electric fan kit (fan delete)
    lower temp thermostat - hot florida weather
    intake manifold spacers
    Audi 710 diverter valves...
    short throw shifter....not sure of the brand
    neuspeed rear sway bar...
    low temp aux coolant fan sensor
    Service
    All seals have been replaced - valve covers, cam seals, cam caps, tensioner seals crank seal, rear main, upper and lower oil pan seals redone
    New battery
    clutch sensors both replaced
    both 02s replaced
    New front axles
    1 Cam sensor replaced
    034 engine mounts
    rs4 tranny mounts
    new spark plugs and coils
    timing belt done at 135k
    oem stereo replaced with ECS refurb....
    Trim swap from wood to aluminum..
    purge valve replaced
    new n75 with orginal turbo swap
    aux water pump replaced
    oil level sensor replaced..
    control arms were done around 60k
    Jun 18 2010
    I need a final retune.....but I was maxing out on boost at 25 psi......so I want that dropped to about 20 ish regardless of what I do with the car...
    Senior Member Three Rings Aureus1's Avatar
    Feb 06 2010
    2002 Stg3 S4, 2005 F150, 1994 Ranger 4x4, 2012 Focus SEL Hatch, 1991 MK1 Cabriolet,
    LiveFreeOrDie
    Quote Originally Posted by speedlyte View Post
    How many miles were on your turbos when this happened??? My palms are starting to sweat...
    "You love your car as much as you hate it..." - my GF
    GSE www.granitestateeuropean.com
    Team Sad Panda
    Jun 18 2010
    I don't think you want me to answer that question.......5k.....In all honesty I don't blame them for going bad to many variables on my side....I've addressed them all but still causes wear and tear...
    * found multiple misfires - all resolved now
    * 25 psi to high for these turbos in my opinon I maybe wrong
    * The spring helping to clamp down drivers side down pipe was cut resulting in more tension
    * Do to oil leaks found out I was a quart to low........
    * I had boost leak problems....drivers side turbo hose popped off twice!
    * running super rich due to the egts going bad
    * during tuning realized I bad 02s
    * started with a k04 tune.....that was bad idea.....
    Senior Member Three Rings slappy_dunbar's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Westchester County NY
    Refresh them both. At $150 a pop it's crazy not to.
    FrankenTurbo
    Let's Do This
    Jun 18 2010
    Quote Originally Posted by slappy_dunbar View Post
    And people swear by k04s rather than Franken turbos......I'd be up the creek without a paddle right now......
    Senior Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    Yes k04s are oem parts.
    I trust oem wheels over replicas.
    01.5 S4 ; 00 2 door golf TDi 320k
    VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    Active Member Four Rings S4 00 2.7's Avatar
    May 13 2011
    This.
    APR | SSAC | UUC SS | JHM Delrin
    2003 Z06 (Sold)
    Wicked
    Feb 06 2010
    LiveFreeOrDie
    Yeah sounds like life wasn't too easy for them. I'm around 16k on mine so hopefully I'm somewhat in the clear...
    Team Sad Panda
    Active Member Three Rings Monty23's Avatar
    Oct 27 2011
    S4, R6, Raptor 660, 2011 Jeep Wrangler Unlimited, 2000 Dodge Dakota 4.7
    Near Philly, Pa
    Quote Originally Posted by DanS4 View Post
    Do franks not have oem KO4 CHRAs?
    Registered Member One Ring RicoSuave's Avatar
    Jun 15 2011
    '01 Audi S4
    ↑state, NY
    PM me regarding the turbos, fueling and intercoolers.
    Thanks, and hope all goes well on the rebuild!
    Santorin Blue B5 S4 6MT
    flickr
    Jun 18 2010
    Well I've decided to keep it and rebuild the turbos, replace with a lower mileage motor, and keep it stage 3. I found a good deal on replacing with a lower mileage motor and am selling my motor to a local so I'd like to freshen up the newer engine.
    * I want to thank Bryan @ Audis4parts he is supplying the engine......As always A+ customer service and parts.
    List I should do to freshen up the motor...
    Valve covers, cam tensioners, cam seals, crank seals, upper and lower oil pan, rear main, valley pan gasket
    Timing belt kit
    turbo install kit
    fly wheel bolts
    clutch throw out bearing * clutch is 5k old so no need for new clutch w light weight fly wheel
    exhaust manifold gasket
    Front passenger cam position sensor - APR bi-pipe blocks it off so I would have to pull the front end to do it.....
    oil change with larger oil filter
    coolant, power steering fluid, brake fluid, etc
    spider hose is less than a year old...
    n75 - less than a year old
    spark plugs less than 500 miles and coils are fairly new
    Samaco hose kit - already installed
    Extras I should do? Or maybe not? Or something else?
    Oil lines for the turbo - prevent clogged lines?
    Crank sensor - time to install and location?
    knock sensor - time to install and location?
    speed sensor - time to install and location?
    reference sensor - don't even know what that is but ...again based off time to install and location...should I
    Anything else anyone recommend I should do?
    Jun 18 2010
    This was quoted from Vast's website.
    Hybrid K04 framed turbochargers with hybrid compressor wheels, rivaling that of the overall performance of the RS6-k04 turbocharger and the flow characteristics of the Porsche 997 compressor wheel, but with better spool downlow.
    Jun 14 2007
    Connecticut
    ^ Right, and I hope no one interprets that they have OEM K04 CHRAs... They are a turbo crafted in the fine land of China with a different wheel.. Absolutely no parts from the mother land (Germany) in those turbos.
    VAST Performance Stage 3 B5 S4 | Videos
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    I thought it was "Father land" LOL.....
    Nov 10 2009
    Somerville, MA/Palo Alto, CA
    ^ Right, and I hope no one interprets that they have OEM K04 CHRAs... They are a turbo crafted in the fine land of China with a different wheel.. Absolutely no parts from the father land (Germany) in those turbos.
    Ftfy
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Sorry, but I almost guarantee that is not the cause of your turbo going out... Your downpipe bolts directly the exhaust housing of the turbo, which is also bolted directly to the exhaust manifold; there is no flex in a cast iron turbine housing to cause your wheels to touch a housing or something.... Your crap SSAC downpipes will crack/flex far before a turbo should; they are made from sheet metal almost (this is from experience, not because we make a better product).
    Unless you installed the turbos wrong, which is basically impossible since you've been running around with them for some time, your turbo went out for a different reason then your clamp being wrong on the bottom of your downpipe... You are also running 25psi on a turbo that...is not made to be run at 25psi.
    Active Member Four Rings RedB5S4's Avatar
    Dec 06 2010
    B5 S4, K4 750
    I'd like to keep my car.
    Quote Originally Posted by Max@034 View Post
    Glad I'm not the only one that thought the "spring causing turbo failure" didn't sound right.
    Like Max said, the downpipes are going to break wayyyyyy before the turbine housing would warp. On the same hand, though, I don't see why people continuously insist on putting 25+psi through K04s and FrankenTurbos and then wonder why they fail prematurely. They simply weren't manufactured to consistently see those boost pressures.
    I find it ironic that the colors red, white, and blue represent freedom until they are flashing behind you.
    Veteran Member Two Rings
    May 16 2004
    Washington
    Just my opinion, but only boost should be a factor in contributing to the failure IMO. Innovative repaired 2 sets of K04's for FREE when they failed on my car.
    Aug 30 2007
    nyc
    flexing downpipes.. now I've heard everything lol....
    c5 A6 tip
    this n that
    ssp tuned
    Jun 18 2010
    That makes sense......What is weird is the car wasn't boosting up 25 psi with my tune. Then I installed the down pipes and it was boosting up to 25 psi......I wonder if the N75 is bad or something else..... ?
    Senior Member Three Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    25psi = 1.73bar
    That's wayyy too much boost for sthose turbo's. okay some people will be lucky but you cant have a nice linear dyno graph with those boostlevels on K04 framed turbo's. I'd say 21psi max if you wanna have a reliable car!
    Current: S4 Avant by Mihnea 386whp
    Sold: M3 E46 SMGII ESS VT450 S/C 380whp
    Jun 18 2010
    And so this dismantling begins......and getting ready for the lower mileage engine......The joys of s4 ownership....lol
    Sep 21 2008
    Toronto, Canada
    get us some pics of the wheels and/or a video of shaft play, if any...!
    Jun 14 2007
    Connecticut
    Quote Originally Posted by Audi_S4 View Post
    25psi = 1.73bar
    Ever see what Flyboy (my favorite member on Audizine) runs?
    That image is from his build thread..
    Jun 18 2010
    He is hitting like 27-28 pounds of boost!
    **If you look at my third picture the waste gate hose was split open......Which was probably the cause of my turbo failure.
    Jan 06 2007
    Virginia
    Keep in mind that for one thing I don't drive around holding high boost all that much, second, I intentionally have pushed the boost level to see what I could achieve briefly with a degree of comfort. That boost profile is higher that what I currently use.
    Thus illustrating the need for anybody to reserve judgment about the product reliability until a cause of failure can be found. Having the turbine continue to accelerate until the TIP can force the wg flapper open was probably not conducive to longevity.
    Quote Originally Posted by RedB5S4 View Post
    This has been the hundred dollar question for me, how much boost pressure to make so that the reliability is not greatly impacted. You guys seem to have some insight into the answer, could you share what you know? I've gone over the compressor map and used some estimates for pressure losses across the turbo and it doesn't seem like 25-26 psi is pushing the FT's, as long as the boost tapers off at the uppermost rpm's, above the 6000 rpm mark.
    Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL/TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H
    VAST Performance Sucks (Updated: 27 Apr 2012)
    Jan 25 2006
    MD
    I was looking at the picture and wondering if that line was torn... BINGO!
    Jun 18 2010
    The line was definitely torn. Going with stainless steel braided lines this time around.
    Feb 04 2010
    Bush
    Quote Originally Posted by FlyboyS4 View Post
    A compressor map is not the tell all, it simply shows what a turbo theoretical capeable is on a bench under controlled conditions.
    As far as I can tell your input on those turbos is going to be limited because you are never get on them for any extended period of time. By your own admission you are just looking for a little push in your prefered RPM band in rush hour traffic.
    Looking into my little crystal bowl tells me if you run FT's or KO4's at 26 psi at Vmax on unrestricted roads they are going to blow fairly quickly.
    Jun 18 2010
    Quote Originally Posted by sektor M7 View Post
    My tune wasn't higher than 22 psi.....When the down pipes were installed the boost increased to 25 psi. My guess is the pipe connecting the wastegates was nicked. Eventually splitting the hose.
    Jan 25 2006
    MD
    Or one turbo was barely spinning and the other was working @ 100%.... Assuming such a thing is possible.
    Jan 06 2007
    Virginia
    I understand that there are affects that I'm not recording that could alter the way I see the turbo performance and that the compressor map should be viewed as an approximation. That was why I was inquiring with Max@034 and RedB5S4 about how they knew the FT was not designed to operate at 25 psi.
    I've explained to you previously (past discussion) that my evaluation of the parts on my car are under the conditions that I operate the vehicle. I realize that you believe a part should be tested under more stressful conditions than it is normally operated to get useful results, even if the conditions are unlikely to be encountered during regular operation of the vehicle.
    I operate my car on public roads where multiple-gear, wot acceleration is unnecessary. A single gear pull through 3rd is more than enough for any situation I'll encounter on these roads. I would be concerned about reliability and component failure if I were to take my car to a track and be driving wot through multiple gears for an extended time. Of course I wouldn't just be concerned about the turbo's reliability under those conditions, there are numerous other parts on the car that would be subjected to higher stresses and be more prone to failure as well.
    Active Member Three Rings aysix's Avatar
    Feb 06 2012
    OP Please let me know if you go with a steel braided line, I'd like to get them too & let me know what size if you find out...:]
    C5 A6 2.7T F4BT Stage 3
    WTB: WAGNER/ER IC's & AWE Boost gauge
    Jun 18 2010
    Quote Originally Posted by aysix View Post
    I already received them and my mechanic will install them. Here is what I got. I ordered 4 hoses when I really only needed 1. I can sell you the hose but you'll still need order the 0-fit hose clamps.
    from www.summitracing.com:
    Quantity / Part number / Description
    1 / SUM-230406 / (-4 stainless steel braided hose 6ft)
    4 / 900304ERL / Earl's Performance Econ-O-Fit Hose Clamps
    Jun 18 2010
    Doug @ Franken turbo confirmed some of the problems I had. Here is his input.
    1. FOD: something fine and gritty is getting into both turbos. So your leak is upstream of the Y-pipe. The material is very small and you wouldn't hear it hitting the turbos, but it's wrecked both CHRAs
    2. Oil at the turbine inlets: your exhaust has a lot of oil in it. Does the car smoke? Because if so, refurbished turbos won't help make it stop.
    I was finding a trace of oil in the y-pipe and diverter valves so I know the turbo was leaking a little bit. The y-pipe could use a cleaning on the inside as its rather dirty. But I don't know what got into the y-pip or before it. I've never ran the car without the filter. Although I'm going to replace it as a precaution and clean out the charge pipes and y-pipe.
    For those concerned with Franken turbos quality I do believe there were definitely too many variables to determine it was the fault of turbo failure. I would honestly buy another set if I needed to but with $300 rebuild cost. Thats exactly what I'm having done. Thanks again Doug.
    Jun 18 2010
    So Status update. I recieved my replacement engine with 80k on it from Bryan @ Audis4parts.
    Jun 18 2010
    The two engines side by side old and new. 144k and 80k.
    Jun 18 2010
    Upgraded the actuator end pieces since this was part of the reason for my turbo failure. Stainless steel lines.
    Those interested in performing the stainless steel line upgrade. I highly recommend as 10+ year old car the lines need to be changed and those lines are very expensive if you buy the whole pipe from audi. Here is the info on parts.
