Results 1 to 2 of 2
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Items for Sale
    Post How to remove rear bumper cover in Audi A6 Sedan
    Here is DIY how to remove rear bumper in Audi A6 Sedan
    In order to remove rear bumper you need to gain access to 10 bolts from inside of the vehicle and 5 bolts from outside
    Tools needed
    • 8 mm key
    • 10 mm key
    • T 27 Hex key
    • screw drivers
    • T 25 Hex Key
    • small wrench with extension
    open the trunk and on left and right remove the trim door covers
    starting on the left you need to remove the cage that holds your emergency tools and if you have your cd changer you need to remove it as well
    there are approx 5 bolts that hold the cage in place as shown in picture below
    once you remove the cage put it a side
    now you need to remove the 5 nuts with washers that attach the bumper into car body
    there are 3 nuts with washer visible using 10 mm key remove all of them as shown on picture below
    there are 2 nuts with washer that are hidden inside car frame and are visible as shown on picture below
    once you remove them put them a side
    now move to right side of the car , you should have clear view of the 3 nuts and removed them like you did on the other side
    these two nuts are little hard to access because of the trim but using long 10 mm key you should still able to remove them
    once you remove it there are 5 screws that need to be remove , on each side of the wheel well there are two screw either T25 or 10 mm bolts that hold the lower portion of the bumper to the car
    last bolt is located underneath of the bumper in the center using either T27 or T25 hex key remove it as shown on picture below
    now you are ready to remove the bumper, having two people is easier to remove it, but if you are alone start from one end and work to other end,
    first pull the lower part out and then pull the bumper slowly from mounts
    you are done, and do the installation in reverse
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Aug 25 2010
    07 Audi A4 Avant, 08 Porsche 911 C4s, 07 Audi v10 S6
    Items for Sale
    Great writeup!
