Results 1 to 25 of 25
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    DTM S4, B6 USP (DD), B5 1.8T (RIP)
    Fremont, CA
    Just a short jhm launch control video
    http://youtu.be/iDGLGWo29xg
    JHM launch control is awesome, gives me more time to concentrate on clutch movement (slipping/dumping) and throttle control. Will be making some more in car videos and some from outside soon. and i bogged this launch, but i've gotten better! for those that haven't used it before:
    1. turn esp off
    2. press clutch down all the way
    3. floor gas pedal
    4. release clutch
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Senior Member Three Rings Amsterdamned's Avatar
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Nice, is this on an OEM clutch?
    .:2004 DG S4 6MT:.
    Clear Corners // 6000k HID Fogs & Lows // Hardwired V1 // 3M 35% Tint
    Trexturk Cat-less DP's // 2.5" Magnaflow // K&N Drop-in // JHM LWCP // JHM 93 Tune
    Apikol Snub & 034 Bracket // Stern Pro Mounts // 034 Street Trans. Mount // Apikol Rear Diff Mount
    Mar 06 2005
    Fremont, CA
    yep, and it's not slipping yet
    USP CLUB MEMBER #10
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    10 S4 6MT
    Oakland, CA
    nice, your car sounded mean when you used it leaving HWY 9 yesterday. :)
    '10 S4 6MT Prestige :: Phantom :: Black/Magma Carbon Atlas :: Sport Diff :: APR Stg II+ :: AWE Exhaust :: Roc-Euro Intake :: VMR v713 19x9.5 :: H&R OE Sport :: AluKreuz :: JHM Short Shifter :: RS4 Grill
    Senior Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    Central Florida
    As intended by their tuning, I've found that just dumping the clutch and letting the launch assist feed in the throttle as programmed works excellently well for [on stock diff's] a very short 4-wheel burnout followed by holy cow. With an LSD out back there is essentially no wheelspin - just WOW.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01
    1996 Lexus LS400 - Bone stock, almost a quarter million miles, runs and drives great
    LifeWithSquid
    Senior Member Four Rings BUD-S4's Avatar
    Jul 01 2009
    B7 S4 MT6, Honda Civic Hybrid
    Hollywood, CA
    Badass. I need a tune... real bad.
    Do you have DP's?
    .:B7 ///S4:.
    VIDEO -> Exhaust
    Active Member Two Rings speedfreek04's Avatar
    May 27 2011
    04 S4, 05.5 A4 3.2, 67 F100, 67 Sport Fury, 69 Lemans
    Northern Virginia
    I bet that Vette was like WTF WAS THAT!?
    2004 6MT S4 - EEEETTTSSSS AAAALLLIIIIIVVVVVEEEEE!!!!!!!! - JHM 93 OCT TUNE, INTAKE SPACERS, LWFW/STG 4 CLUTCH, LWCP - PIGGIES - STERN MOTOR MOUNTS - 034 TRANS MOUNT - APIKOL SNUB MOUNT - SAI DELETE - RS4 REPS ON THE WAY, NEED MOAR LOW
    2005.5 A4 3.2 - My attempt at keeping the wife from wanting to drive the S4
    1967 F100 - Seemingly bulletproof
    1967 Sport Fury - Twin turbo 383
    1969 Lemans - Single turbo 350 *in progress*
    Do your part; Help stop SAI on S4 crime
    Oct 03 2011
    2004 Imola S4, 2009 R1
    Sacramento
    i love the way you guys drive your cars, but do you think it contributes to the pre 100k catastrophic failures?? im at 80k and getting paranoid... sorry for the off topic
    awesome launch, where was that? you guys mentioned 9, i just did 1 **> 84 **> skyline **> 92 sunday
    cya out there!
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I must have watched your video 20x. Great video great sound and for once the LA has made me a little jealous of the manual cars. Even tho the Automatics have there own LA your car really did pop out well.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Veteran Member Four Rings cellg8's Avatar
    Sep 19 2007
    Seattle/Taiwan
    THUMBS UP!!! Very nice! Love the sound!!!!! More please... drive bys...etc...
    i love blue.
    2008 B7 S4 / Stasis Ohlins SL / ADV10 Trackspec 20x8.5 ET 28 + 245/30/20 / CF wrapped rear valance / CF wrapped engine cover pieces
    Mar 06 2005
    Fremont, CA
    Thanks for the comments guys. Yes I do have downpipes, they are trexturks 2.5".
    The route was an exit off 237 E, don't remember which exit
    I will be making more videos as soon as i find a camera/camcorder that can capture all the sound (including bass)
    USP CLUB MEMBER #10
    Veteran Member Three Rings V8EATER's Avatar
    Nov 15 2006
    Thornton CO
    AWESOME!!
    2000 A4 Avant One-point-ate-tea
    Mods:
    Podi Stepper Boost Gauge
    Active Member Two Rings karsty's Avatar
    Dec 10 2010
    2007 Imola RS4
    Edmonton, Alberta Canada
    Nice video! Noticed some smoke at the top of 2nd. Is that the JHM tune running a bit rich to keep things cool at high rpm's?
    Active Member Two Rings JoeyZ's Avatar
    Oct 10 2011
    Sounds mean.
    Senior Member Three Rings R&Cs4's Avatar
    Oct 19 2009
    S4 Cabriolet, A3 2.0T
    Fairfax, VA
    Quote Originally Posted by Justincredible View Post
    how do you use the LA on a Tip? Just got the tune and haven't tried it out yet
    2005 S4 Cabriolet ~ Alot of JHM goodies ~
    Active Member Two Rings Dustondo's Avatar
    Feb 01 2012
    2008 CLK63 AMG Black Series
    Does the JHM tune automatically set you up with this launch control or is it something you have to ask for to be added to the tune on a six speed? And I haven't seen anyone with an answer yet to the above question about the risk of catastrophic failure etc at or near 100k on a completely stock clutch/drivetrain.
    2006 B7 S4 Stasis/Alcon big brake kit, apr snub mount, avantgarde M310's, H&R coils. more to come soon:)
    Registered Member Two Rings
    Jan 24 2012
    Snowboard, Skateboard, Mountain Bike.
    I am scared to do that with my car lol.
    Active Member Three Rings Apat's Avatar
    Jul 04 2011
    B7 S4 , 97 XJ
    Minneapolis, MN
    Love the video. You've got a mean sounding car. I'll be trying out the LA this weekend for the first time.
    From what I understand taking off with JHM LA is actually easier on the drive train than a non JHM LA launch. Obviously, launching a car and running 1/4 miles stress your parts a little more but what the heck is the point of owning a fast car if you aren't going to run it every once and a while
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM Intake Manifold and Spacers // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // PSS9 Coilovers // 034 Rear Sway // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights // 19" MRR GT1 summers // 18" VMR V710 winters
    Apr 24 2010
    Central Florida
    The Launch Assist is easier on the clutch than an inexperienced driver launching the car because the lack of experience often means the driver slips the clutch too much, causing a lot more heat and wear to the clutch and flywheel.
    And if running your sports car full throttle causes it to break, then something is very wrong. Plenty of other cars get beat on just as much as our S4's, and without problem. In my opinion, there has been overwhelming amounts of proof that it's a few design flaws that lead to the problems and not the way that the car is driven. I also believe that regular hard use (full throttle time/higher revs), at least once in a while, is important to engine longevity. It helps burn off gasoline-based impurities in your motor oil, helps keep injectors clean, helps keep carbon from building up in your combustion chamber and on your pistons and rings, and helps keep the valves clean as well. Lots of good comes from working the car out regularly. Even my old Lexus gets its share of full throttle action, mostly for above benefits (but sometimes because people are idiots and I'm impatient).
    -Jason
    LifeWithSquid
    Senior Member Three Rings stormscr3's Avatar
    Jul 08 2008
    2011 Ford Edge
    MA
    Quote Originally Posted by Dustondo View Post
    This ^ ... I currently have a JHM tune for my B7 and am unaware if launch assist is automatically active with it. Checked out the website and saw no information ... great vid by the way and clean launch. I'm sure the guy in the Vette was like wtf was that
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    ^stop the car, mat the gas, and see if the RPM's catch around 5500. If they don't catch before 6k, you don't have it, if they do, then you do. (but remember always turn esp off first and don't slip the clutch at all!)
    If your tune came out in the last year or year & half, you probably have it. If not, JHM will update your tune free, just ship them your board.
    2005.5 S4 MT6 l JHM Parts: Stg 1 Supercharger, Long Tube Headers, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I. Res B6 Exhaust, Pedals &Weighted Shifter l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Senior Member Four Rings Mr. Corey's Avatar
    Jan 14 2009
    Syracuse / NYC
    Sweet video! Thing sounds mean............
    B6 Nogaro with some mods
    Jul 24 2008
    chicago
    Quote Originally Posted by SquiddyB6S4 View Post
    This 100%.
    someone asked about a little smoke at upper RPM's. That is more then likely carbon getting cleaned out of the cylinders after a long pull. AS squiddy said low rpm driving over time can get amounts of carbon build up in the motor let alone the exhaust. A good blast every now and again will clearn that out.
    Dec 10 2010
    2007 Imola RS4
    Cool thanks.
    Nice, thanks for sharing it.
    M2, M3, Rolleiflex 3.5 B, Yashica Mat 124G, Nikon D90, Nikon F100, Nikon FM, Pentax K1000.. Advice and constructive criticism always welcome..
    digital hd video camera
