Results 1 to 7 of 7
    Veteran Member Three Rings Yuppie's Avatar
    Feb 14 2005
    S4, 92 Passat
    usa
    Advice on what product to purchase and detailing
    I have a 2001.5 Audi S4 Nogaro Blue with white/cream interior. I want to give my car a detail which would make the paint and interior come back to life.
    I have few scratches on the roof of my car and the hood, I was told to wet sand. What is the best method and process to use when wet sanding?
    Below are the parts I want to focus on
    Exterior
    *Paint
    *Black piece by the doors
    *Engine bay
    *wheels/tires
    *fenders/brakes
    *Headlights
    Interior
    *White/cream leather seats
    *Black Panels
    *Monster/Winter Mats
    *Carpet
    I need to know what products to purchase i.e. steamer,washing mitt, pressure hose, etc and if someone can give helpful tips that would be excellent!
    TIA
    2001.5 Nogaro sedan AWE stage III--Current
    2001 Black Sedan S4-K04/Rs6 Hybrid turbos w/ meth custom tuned Vast--SOLD
    Active Member Two Rings OTDetailer's Avatar
    Oct 13 2011
    NNJ/LA
    1st whats your level on detailing?
    are you just starting detail?
    do you know how to wash the car properly?
    prep it properly?
    have you used a D/A polisher before?
    are you comfortable with a rotary buffer?
    what is your budget?
    do you have a indoor garage?
    what tools you have already?
    do you have a paint meter?
    Feb 14 2005
    S4, 92 Passat
    usa
    Quote Originally Posted by OTDetailer View Post
    1st whats your level on detailing?--Just to be safe I'll say I'm a starter
    are you just starting detail? --No, I have been cleaning/detailing with off the shelf products from chain retailers(autozone,advance auto,etc)
    do you know how to wash the car properly?** I do however I am willing to always listen and try new ways
    prep it properly?** I think I do but again I am willing to listen and try to methods
    have you used a D/A polisher before?** No
    are you comfortable with a rotary buffer?** I have never used one but I am okay with using one
    what is your budget?** I would like to spend less than 400.00 if possible
    do you have a indoor garage?** Yes I do
    what tools you have already?** No tools since I moved to a different state and don't have anything here
    ** No I do not
    TIA
    Oct 13 2011
    NNJ/LA
    from the information I gather from you, I recommend these kits. I wouldn't wetsand if I don't have a paint meter and that's $300 + already for a reliable one. A rotary polish can cost $200 +. both these items along with products will cost you close to $1000.
    http://www.detailersdomain.com/Porte...dle_p_307.html
    choose 3 yellow uber pads and 2 uber green pads.
    http://www.detailersdomain.com/The-U...Kit_p_625.html
    decon kit
    http://www.detailersdomain.com/Uber-...Kit_p_404.html
    wheels and tire kit
    Hope this helps.
    Feb 14 2005
    S4, 92 Passat
    usa
    I appreciate the help. I see those things are for exterior, what would you recommend for interior? I can exceed 400.00 if needed, If this comes out fine I will do my other vehicles also.
    What you recommend using the following items also?
    http://www.detailersdomain.com/Gilmo...Kit_p_112.html
    http://www.detailersdomain.com/Uber-...wel_p_516.html
    http://www.detailersdomain.com/Uber-...-V2_p_515.html
    TIA
    Registered Member One Ring OzDasher's Avatar
    Jan 29 2012
    79 B1, 79 Mk1 (both dailies), 59 Beetle, 2 more Mk1s, 02 Bora 4mo.
    Melbourne, Australia
    I've been using Poorboy's World trim restorer for several months now, on exterior plastic/rubber and interior plastic/rubber/vinyl items and have been a bit chuffed at the results.
    http://www.poorboysworld.com/trim-restorer.htm
    Keeps things very dark for months, and not too pricey to buy.
    Autoglym stock an amazing array of products too. This
    http://www.poorboysworld.com/natty-blue.htm
    and this
    http://www.poorboysworld.com/blackhole.htm
    on black cars makes it look amazing! Do a clay bar clean first, then try with the polishes, waxes and sealants.
    VWDasher.com - B1 fans!
    Oct 13 2011
    NNJ/LA
    Quote Originally Posted by Yuppie View Post
    This
    TIA
    Those kits will put you way over $400. Just 2 uber sponge, 2 grit guards, and two 5 gal buckets is good enough to start
    here's a link to the uber sponge
    http://www.detailersdomain.com/Uber-...nge_p_196.html
    For your interior
    http://www.detailersdomain.com/1Z-ei...Kit_p_163.html
    For fabrics I have luck with optimum powerclean
    http://www.detailersdomain.com/Optim...ser_p_193.html
