Results 1 to 3 of 3
    New Member One Ring
    Jan 29 2012
    Boulder Creek, CA
    Long time lurker first time poster....and it's a duesy!!
    I'm looking to borrow / rent a cam lock tool and crank lock pin for a b5 S4.
    Anyone in the Bay Area have one that I can use? I'm in the SC mountains but could drive anywhere in the area and pick it up.
    I have a spark plug thread that has blown out and is totally stripped and I need to repair it.
    It looks like there are two camps of thought on this
    1) Just get a TIME SERT installed by a shop and it should be fine.
    2) Pull the head and have it repaired so that no metal shavings or debris gets into the cylinder.
    I have gone as far as removing the valve cover and intake manifold but I would like some advice before biting the bullet and removing the head.
    Any help would be greatly appreciated.
    Travis
    Active Member Two Rings sr71sss's Avatar
    Jan 20 2009
    datsuns, mitsubishi vr4, pulsar gti-r
    Antioch,ca
    travis,
    you should be find with a time sert not worth pulling head unless motor needs a rebuild, just make sure you get all shavings with a small magnet, I would put that cylinder in top dead center so when the chips fall it doesnt fall to far in the hole, take your time and you will b ok most of my friends always screw things up when they are rushing to finish the job and I have to save the day thats ok if they pay me to save their ass.
    GL with the repair
    Jan 20 2009
    Antioch,ca
    time sert should b ok just take yur time, use a small magnet out of a magnetized antenna mast and you'll be able to pick upthe chips plus use grease to minimize the chips in the first place.
    I have seen a product that you can repair the existing threads but not sure how well that works, if it was me time sert FTW.
    GL with the repair
