Results 1 to 14 of 14
    Aug 28 2010
    Arvada, CO
    Engine fan runs full speed at idle?
    I have a 2003 Audi A4 1.8T with 35k miles. For the past few weeks, after I have been driving for a while, when I put the car in park and sometimes at stop lights the fan speeds up to full speed. It is so loud I can hear it inside the car. My engine temp is normal. This started happening the same day my "Oil Level Sensor" light came on if that has anything to do with it? What's going on here?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    Aprilia SXV 550, BMW F800GS, Honda CRF450X Timbersled, Ram EcoDiesel, 1989 Bronco
    Lander, Wyoming
    I believe the problem is the relay module, there are thread on this topic. The module is in the front of the car near where the hood latch mechanism is located. My car did this for a bit and then miraculously stopped having the problem.
    The oil level sensor is in the oil pan and I doubt they are related; however, it is possible that the wiring is close to each other. IIRC the oil pan sensor wiring comes up and there is a harness near the ABS pump, maybe look there for corroded harnesses. Is the oil light still an ongoing problem?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Items for Sale
    So many threads about this the whole week.
    Here's one ****>>>> BAMM
    Silver 02 Audi A4 1.8T Q MT
    LED headlight :)
    '11 2.0T Audi A5 Premium Plus quattro.....Auto
    C7 S7 4.0 TT Prestige
    >>>>>Garage Sale<<<<<
    Dec 13 2011
    Dearborn MI
    That happened to me when my green temp sensor fell out (Yeah it fell out when I was driving and I lost all my coolant. Stupid place for a plastic clip...) Anyway, replacing the sensor and clearing the codes did it for me.
    Aug 28 2010
    Arvada, CO
    Quote Originally Posted by lookaught View Post
    I didn't think about the wiring being close to each other. Yes, the oil level sensor light is on every time I drive the car. It never turns off.
    Aug 28 2010
    Arvada, CO
    Quote Originally Posted by audi_nightrider View Post
    My fan does not run at startup, it runs full speed when the engine is warm and sitting still.
    Veteran Member Four Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 1.8T, 02 VW GTI 1.8T
    Long Island, NY
    Items for Sale
    yea so many threads and I havent seen a post confirming that it is actually the fan control module. I am still trying to find one but I might just have to buy it brand new for 270
    E85 with stock K03, custom return fuel system, Tuned by Daz. Other Mods...
    Established Member Two Rings viTamin b6's Avatar
    Dec 29 2011
    Danbury, CT
    I know I'm bringing this back but I'm having this same problem and was wondering if anybody had any luck diagnosing the issue?
    Oct 16 2010
    Long Island, NY
    Items for Sale
    I have had this same issue but I never actually bought the 275 dollar module to see if it works.
    Dec 29 2011
    Danbury, CT
    I dont blame you. Thats too much money to spend on a hunch
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Quote Originally Posted by viTamin b6 View Post
    Lol, I had this intermittent issue a few years ago, and it fixed itself, and never acted up again!
    Dec 29 2011
    Danbury, CT
    Quote Originally Posted by cdn20valve View Post
    hopefully after an in depth tune up it'll disappear
    Aug 26 2005
    If tbere is any cooling system performance DTC/s set, then the ECU calls for cooling fan high speed after start up, as a precaution agains overheating. Check/scan ECU for cooling system related DTCs. Another possible cause is if there is water inside the ECU box. If there is water inside, it will short out the several relays under the ECU. The symptoms of water inside, are usually the rad fan trys to start up or runs after turning the engine off, and after variable delays after shut down, including the fan running at high speed after starting and after engine shut down. The symptoms with the cooling performance DTCs are the fan running at high speed after starting, but not running with the engine turned off. If the cooling fan power control module was faulty, then it is more likely that the rad fan does not run at all, with the rad fan motor/s not getting power from the fan module, instead of running only at high speed right after start up.
    Vorsprung durch Technik
    Aug 28 2010
    Arvada, CO
    Turns out it was the lower ECT Sensor, which sends data to the engine fan control module. It was reading a crazy high temperature causing the fan to kick in.
