Thread: airbag light
    Jan 10 2012
    Indianapolis
    airbag light
    I was doing some troubleshooting in the fuse box to figure out whats going on with my lack of driverside headlight. All I did was pull out a couple fuses and test them, put them back in. Next thing--Airbag warning light comes on. I assume its related to me being in the fuse box. Yes, i tested the fuse for the airbags and all is good, but the warning light stays on. I dont care about the light, all I care about is if god forbid I get into a wreck the airbags work for me and my munchkins!
    06 Audi A3 2.0T Fwd
    Senior Member Four Rings Mantvis's Avatar
    Jun 05 2009
    Audi Mk1 TT, Mk4 VW GTI
    Chicago, Naperville
    under drivers seat there is some wires, passanger side has them to. but a common porblem is drivers seat. there is the connector and it useualy goes out from moving the seat cak and forth.. so chech the connectors.
    and about the fuse box i have no clue. hmm
    If you don't need both hands on the wheel, then you're NOT driving.
    Jan 10 2012
    Indianapolis
    haa ha, i let my shorty neighbor drive my car...he def adjusted the seat...will check. And thank you
    Jan 10 2012
    Indianapolis
    wire are connected under the seat, fuses are fine...anybody?
    Jun 05 2009
    Chicago, Naperville
    Id they are connected it doesnt mean that the wires inside are find ;)
    mine were connected, but the light was on. So i took out the connector and just soldered the wires together. and guess what! no light :)
