Results 1 to 40 of 51
    Jan 27 2012
    Sweden, Luleå
    2.0 TFSI Vast gt2876 fuelcuts
    Hello,
    Im having problems with fuelcuts and also lost of power at my 2.0 tfsi with a gt2876r turbokit from VAST.
    Also have 2.5" full exhaust and FMIC Intercooler.
    So powerlost and no CEL....
    Did a dyno on this car at motornord in Sweden they also did the tunefile for it, 211 whp @ 1.5 bar.
    0-200 km/h takes 25 sec...
    Checked it with VAG COM and the code is:
    012 555 - Low Pressure Fuel regulation: Fuel pressure out of tolerance
    P310B - 002 - Lower Limit exceeded - Intermittent errors
    frozen data:
    Error status: 00100010
    Felprioritet: 0
    Unsuccessful: 1
    Mileage: 93163 km
    Time Indication: 0
    frozen data:
    RPM: 6484 / min
    Load: 94.1%
    Speed: 140.0 km / h
    Temperature: 78.0 ° C
    Temperature: 13.0 ° C
    Absolute Pressure: 1010.0 mb
    Voltage: 14,097 V
    I have changed my thrust sensor allready, but it didnt help, any tips?
    Have been trying to find out the problem now since the summer...
    Readiness: 0000 0101
    Stage 2 Banner Advertiser Two Rings SALES@RS WORX's Avatar
    Oct 03 2011
    New Jersey
    Do you have an upgraded hpfp?
    .:Redline Speed Worx:.
    Tri-State's Premier APR Installation Center
    German Automotive Repair, Performance & Fabrication
    908.223.7477
    Senior Member Four Rings bmc333's Avatar
    Feb 12 2009
    2007 A4 2.0TQ / 2006 TSX
    NoVA
    And upgraded injectors?
    2007 A4 2.0T-Q - DSB - Tip - APR Stage III+ - Snow Stage III Meth kit - Billy Boat Cat back - APR TP - APR HPFP - APR Intake - Forge DV - Koni FSD/Eibach - RS4 Rear Sway - 034 Intercooler hoses - Evolution Racewerks SMICs - Hawk Ceramic Pads - 034 Catch Can - Podi Electronic Boost Gauge - Sterns Control Arms - Pioneer AVIC Z-120 - Rieger front splitter - Votex rear valance - 19" Avant Garde M310's
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    How do people even get this far without Audizine? Lol. Lpfp? Injectors? Prv? We will need to know your full mod list before anything.
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
    Jan 27 2012
    Sweden, Luleå
    oh sorry,
    it is a complete kit that comes with these parts:
    VAST 2.0GT ball bearing turbo kit:
    - All mounting, fastening, and sealing hardware
    - All oil and coolant lines
    - Air intake and plumbing
    - 2.5" stainless steel test pipe/downpipe off turbo
    - 321 stainless steel tubular exhaust manifold with all hardware/gaskets
    - Custom built GT2876R ball bearing turbo
    - Ceramic coating of turbo exhaust housing, tubular exh. manifold, downpipe
    - Hi-flow FSI fuel injectors
    - Bosch f5dp0r spark plugs
    - Oil catch can kit
    - Firesleeving
    - Manual boost controller
    - Mechanical diverter valve kit
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    High flow injectors??? As in RS4 or S3 injectors??? Oh and there is a thread named P0089 that you will need to visit...
    vizi
    05.5 B7 A4 6sp AWD Quartz Gray 173,000mi I like to drive!
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20,Wossner Pistons 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, Eurojet VC, EJ S3 Dv Flange, Custom STASIS Exhaust, Precision 600hp FMIC, RS4 injectors, Tial 38mm, APR HPFP, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mount, DO 4 port w/m direct injection, HPFPUpgrade 142bar fuel relief valve
    Absolute Automotive Tuned to 373+awhp (Corrected)
    Jan 27 2012
    Sweden, Luleå
    I will look that up thanks! It is Audi s3 injectors...also have an Autotech fuelpump upgrade kit...
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    P0089...
    And look into the PRV or check your follower, as the auto tech pump might have failed
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Senior Member Two Rings baldy's Avatar
    May 11 2010
    A4 Avant, Crossfire, Touareg V8, Yamaha R1
    BC
    This is the exact same problem I'm having.. Good to know I'm not alone, except I'm on a K04.
    So far I've replaced:
    PRV (Rs4 one now)
    LPFP
    Coils
    Plugs
    Cam follower
    So only things left in my equation are the HPFP or the LPFP controller.
    Let me know what you figure out, and I'll let you know what I figure out...once the RS4 pump controller gets here
    I started a thread here: http://www.audizine.com/forum/showth...GT-logs-wanted
    OEM S3 K04..Unitronic!!!! Autotech HPFP..RS4 PRV..S3 injectors..RS4 LPFP Controller..3" DP..Neuspeed Exhaust..034 HFC..Carbonio..ER DSMIC's..034 Silicone IC and Inlet Hoses..OEM S3 DV Relocate..MANN Provent 200 Catch Can...034 Breather Plate...RS4 Sway....245/40 RE760...H&R Sport Springs...Bilstein Sport...Cayenne 6-Pot 330mm front / S4 rears...HAWK HPS Pads...Goodrige Lines...NewSouth Ventgauge..Bose Mod..Aux-in..12" Sub in Fiberglass Box..HID Fogs
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Baldy have you replaced the thrust sensor thats on the side of the HPFP yet?? Not the one on top of the pump...
    vizi
    May 11 2010
    BC
    Hi Vizi
    The G410 was replaced 6 months ago. The N276 hasn't been replaced recently, but I got a whole new HPFP about 6 months ago when the Autotech internals were installed into it..
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Quote Originally Posted by baldy View Post
    Hi Vizi
    Do you still have the old thrust sensor you can swap it out just to rule it out for sure???? It's one of those code that can be grusome to track down...
    vizi
    May 11 2010
    BC
    Nope, I threw it out..
    Guess I will have to buy another one.. For now, I'm going to wait for the RS4 controller to come and see what happens. Rumour has it from a tech I know, the RS4 one makes the LPFP flow about 30% more... If that really is the case, then my problems should be solved, provided it's not a G410, N276, Leaking HPFP somehow (eventhough there's no gas in the oil and the fuel trims suggest it's perfect), or a pinched line (hard to track down possibly since it runs behind the heat shield I beleive on the firewall, but a possibility since my car had a "thermal incident" above the downpipe from oil leaking from the vaccuum pump and saturating the heatshield material... and the tranny was out amongst over $10k of parts)...
    I called about the DW300 today, but they told me to call Vast and see what needs to be done to fit one in our application...
    Vizi, can you PM me your email and I'll send you my logs.. Maybe your logs will give me an idea of if it's tune related... My tune requests 130 bar from 5K and the injector time is 7.5ms roughly... and that's when all hell breaks loose (9degrees of timing pull)... I'm just fishing here.. Another friend at Mercedes gave me a suggestion of checking the sock on the intake on the driver side, since they have seen problems if only one side of the tank is plugged...The dealer changed the LPFP, so I wouldn't doubt that they didn't clean the other side...
    Jan 27 2012
    Sweden, Luleå
    yeah, feeel good to know that im not the only one with this problem... I have changed my camfollower and the sensor located on the fuel rail aswell, sparkplugs too but no help. Can thsi problem be software related? I have some misfire to... Guess next step is the intank DW300 from VAST, but im getting sick of throwing money at this can without gettting any preformance...
    Thanks for trying to help me out!
    //John
    May 11 2010
    BC
    Quote Originally Posted by Jonnieboy123 View Post
    //John
    I hear you on that one.. The funny part is nobody I have talked to has a concrete solution.. All suggestions, but when I searched other forums there are quite a few people that have had the same problem and never posted their solutions, other than Vizi (unfortunately my new pump didn't change anything)...
    So tomorrow or Monday (when I have less gas in the tank) I will take a look at the pickup on the driver side and the fuel lines..
    If that doesn't fix it, I'll try another G410
    If that doesn't fix it, the RS4 controller should be here next week..
    If that doesn't fix it, I might just suck it up and get a new HPFP from HPFPupgrade.com
    If that doesn't fix it, then I'm going to look at taking the car in for a fine tooth comb lookover at a shop...
    If that doesn't fix it, then I might and look at software as being the cause, but I've already been down that road and was assured everything is perfect.. so I'm lost...
    Jan 27 2012
    Sweden, Luleå
    Did some fuel related logging this moring. I need a RS4 RPV dont you think?
    http://ultrashare.net/hosting/fl/6753fb2778/fuelrail
    //John
    Senior Member Three Rings FLYINGLEGGS's Avatar
    May 04 2009
    Clearwater, FL
    I have had fuel cuts three times.
    First time a new and upgraded oem intake cam and cam follower fixed it for several months.
    Second was a worn out lpfp. Replaced and upgraded it. This fixed it for a year.
    Having cuts again. Will be diagnosing over the next week. will update.
    May 11 2010
    BC
    //John
    Your logs look slightly worse than mine, but same idea (although you didn't log rpms or timing or injection or egt, so I can't really compare.... )
    All these logs below are with RS4 PRV, Stock NGK Platinum plugs, plus everything in my sig..
    Beginning to wonder if it's not the LPFP but the HPFP just can't keep up... hmmmm...
    Old LPFP Logs
    New Filter, Old LPFP
    New LPFP
    Jan 27 2012
    Sweden, Luleå
    No succes yet, its bben damn cold here in Sweden... About -30c so no testing yet... Im probably going to go with a DW 300 and see what happens.... Or maybe the PRV for an RS4...
    Oct 14 2009
    Robins AFB, GA
    I am personally going tO get the RS4 PRV. I do t have fuel cuts but I really hope your issues are found and fixed
    -Shane Drake
    DRAKLOREs Build
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    This is interesting. Looking forward to hearing the end solution.
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    Quote Originally Posted by DRAKLORE View Post
    why not get the bigger prv from hpfp which cracks higher than the rs4
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Oct 14 2009
    Robins AFB, GA
    Running bigger injectors requires less rail pressure. So a 136 bar should suffice. If the newly priced hpfpupgrade valve was a bit cheaper I would consider it.
    -Shane Drake
    DRAKLOREs Build
    May 11 2010
    BC
    The PRV didn't help for me... Still waiting for the RS4 fuel pump controller, so no progress yet.
    Jonnieboy, if the DW300 works, let me know..
    Oct 14 2009
    Robins AFB, GA
    Honestly the dw300 from vast is cheap enough
    -Shane Drake
    DRAKLOREs Build
    May 11 2010
    BC
    Shane, how much was it and is it a direct fit?
    Oct 14 2009
    Robins AFB, GA
    Iirc it's between 160-200$ but I bought a ton of shit and had shipping with a clutch so don't quote me.
    Andy@vastperformance.com can tell you better than me, it is pretty much a direct drop in, you have to splice together the two leads but everything is included.
    I think D1drift did an article on the Dw300 and it outperformed a lot of its in line and drop in competitors and is much cheaper$$
    -Shane Drake
    DRAKLOREs Build
    Oct 14 2009
    Robins AFB, GA
    https://vastperformance.com/index.ph...universal.html
    Here's the link guys, awesome at 169$
    Heres a pic I took right before dropping the LPFP back in the tank.
    The blue nipple is the dw300, and the labels were a practical joke haha
    From there it's just a matter of putting the "hat" in place and splicing the wires.
    They can also provide you with the seal for the tank as well, (just replaced mine) 8-14$
    Definently worth it IMO +++super quite
    -Shane Drake
    DRAKLOREs Build
    May 11 2010
    BC
    Pic?
    Also to update my situation, I played devils advocate and succombed to Unitronics suggestion that the O2 sensor was too close to the flange now that the K04 was in and EGT reading was too high???.. So i had a new HFC made yesterday.. O2 sensor is now even further back 0.25" than stock location..Computer sees temps around 80-100 degrees cooler (although this is probably because the new HFC has less cells and flows more freely or just the conditions I logged in)... Anyways, I left the shop and the car was a lot faster... cruised on highway then grabbed my laptop and went for a drive to do some logs.. After letting the car adapt for about 50km's, I ran logs... Basically same shit as before with slightly less timing pull...
    Anyways, RS4 controller should be here any day, so I'll do that next since I already bought it.. if that doesn't work, DW300.. (I might just buy it anyways.. )
    Oct 14 2009
    Robins AFB, GA
    I'm sorry, here's the pic
    Drops right in
    -Shane Drake
    DRAKLOREs Build
    May 11 2010
    BC
    Thank you for the picture Shane..
    So I have a question or two.. Since nobody within a 2 hour drive has a DW300 in stock (and I guess I'm getting inpatient), apparently the Aeromotive 340 Stealth pump has the same specs... and I can pick one up locally...
    http://aeromotiveinc.com/products-pa...-center-inlet/
    Anyone have any experience with these?
    Also, Shane can you tell me what inlet/outlet configuration the DW300 was? Center inlet/oulet, offset inlet/center out, or offset/offset... There's 3 options from Aeromotive so just wanted to know which orientation would work (if there's nothing bad about these ...otherwise I'll call Vast and order the DW300)
    Thanks in advance to anyone that answers..
    Oct 14 2009
    Robins AFB, GA
    IDK, andy installed mine in the cage for me. You could call or email him, or spend the extra money the aeromotive cost on faster shipping for the DW?
    good luck, keep us updated
    -Shane Drake
    DRAKLOREs Build
    Jan 27 2012
    Sweden, Luleå
    did change my fuelfilter, but notting happend... also did the calibration, the car felt a little bit smother... I have contacted motornord and they told me they will have a look at the software... Hopefully thats going to help me out... Fuelpressure is under 3 bar at rpm over 4500... If i lower the boost, I will get a bit higher fuelpressure aswell...
    //John
    Stage 1 Advertiser Three Rings hpfpupgrade's Avatar
    Aug 10 2011
    Auburn, WA
    //John
    Have you torn the HPFP down yet? That sounds like a HPFP failure, 3 bar is below low pressure line pressure. With everything you have done, I would look into the high pressure fuel pump. Did you datalog any of your N276 voltage? I have seen those fail under RPM but normally its 5500 RPM and above that the N276 has issues with.
    Keep us posted on what you find out.
    Thanks,
    John
    Ignore the first part of my post... it was low pressure you were talking about, not high pressure
    Fueling your passion for power!
    The only "complete" fueling solution for FSI/TFSI engines!
    Hours 10 - 7 Monday - Friday
    Phone 253-887-8305
    Email sales@hpfpupgrade.com
    Site www.hpfpupgrade.com
    Aug 10 2011
    Auburn, WA
    Pic?
    Hit me up if you need that DW300 we should have them added to the site very soon at great pricing.
    Thanks,
    John
    Phone 253-887-8305
    Aug 10 2011
    Auburn, WA
    Correct, but when you start to run out of injector you are going to wish you had more fuel pressure or the ability to hold that rail valve shut to a higher commanded fuel pressure.
    $130 for the RS4 valve and ours at $149, is $19 going to break the bank? Not only that but you cannot get 145 or 155 BAR rail valves anywhere else. It has been mentioned that I should be charging $200 for these, but like we have talked about before... its not always about the money.
    Thanks,
    John
    Phone 253-887-8305
    Aug 10 2011
    Auburn, WA
    What bolt are you running on the feed side of your turbo, banjo or bamboo barbed fitting?
    Also, have you checked your low pressure feed line from the firewall to the high pressure fuel pump. I have been told that there is a restriction inside of that line and it can be drilled out to a larger line. Check on those few things.
    Hope this helps.
    Phone 253-887-8305
    Oct 14 2009
    Robins AFB, GA
    .... John we understand you've cornered the market on these valves!
    Anyways not to dig at your sales pitch, but GAP sent me my RS4 valve for 102$ shipped..
    And remember that the vast DW300 comes with all the install hardware and he even offers to do the install if you send him your LPFP. At 169$
    Like I said, not a dig at your sales pitch... Cause I'm sure at 250$ people would buy them, but again it's not about the money (why bring it up then )
    OP- good luck, I would agree with John that your hpfp may be the cause I wish I could offer more help!
    Goodnight
    -Shane Drake
    DRAKLOREs Build
    May 11 2010
    BC
    Ok, so a little update.
    Since I've been on a wild goose chase, I also gave in and swapped the LPFP controller with another one from a friends A4 (he just had his replaced recently under warranty), since my RS4 one is apparently walking from Germany. End result, NO difference. Ok, so at this point I want to tear my hair out, when I though to myself, WTF.
    If you look at the logs, I'm running lambda at 0.7 (10.29) AFR. The injectors are open for a long time, and that's when my fuel issues start. The timing pulls, whole other topic. So I went to get re-flashed back to the regular Uni K04 file, since my EGT issue has been fixed right. Well, the car runs smoother and is a little slower, but I didn't feel any jerky throttle so I assumed no timing pull.
    I ran some logs (will post up later) and sure enough, no timing pull, HPFP up to 136 bar, and LPFP around 3.8 bar at redline, all while the EGT doesn't get over 830 roughly... Injector timing, around 6.6... Only 2 small issues... MAF is down to 252 g/s max (from 280), and boost tapers down to 13 psi... If I could get that resolved, so the car was/felt stronger / faster like it did on the other tune, I'll be happy like a fat kid at a buffet.
    Moral of the story so far:
    O2 sensors on our cars need to be exactly at the factory distance off the turbo flange since the EGT probe is built in, and the projected value is affected by this
    LPFP can't drop below 3.5 bar or HPFP won't meet requested pressures of 130 bar (LPFP at 3 bar will let the HPFP flow up to 120 bar only)
    AFR of 10.29 is way too rich and beyond LPFP/HPFP/S3 injector combo limits...
    injector timing greater than 7.26 ms @ 120 - 130 bar is beyond the flow capability of our stock LPFP (pressure drops below 3.6 bar at this number)
    Hope that helps... I'll update when the RS4 controller for the LPFP gets here...
    Jan 27 2012
    Sweden, Luleå
    I have orded a DW300 now and motornord is looking in the software, probably the solution is closer then ever :P
    Have a nice day!!
