Results 1 to 9 of 9
Thread: Quick Question
    Active Member Three Rings Audi4.2's Avatar
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    Quick Question
    I Just finished the valve,cam seals, half moon etc gaskets on one side of my car and have the cams out, i cant find anywhere how much FT i need to torque them down to, i just did 7 feet for now? anybody has the exact number? Thanks
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    Quote Originally Posted by Audi4.2 View Post
    To torque the cam caps, the bolts are TTY, it's 7 ft/lbs and 1/4 turn.
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    great Scotty thanks, also while im in there i see that the cams are off? isnt that notch supposed to be in line with the little arrow? they where like that when i started too, both couldn't get the picture of the other though. how do i adjust them?
    EDIT: My crank is not at TDC so nevermind
    Senior Member Four Rings G Men 08's Avatar
    Feb 05 2008
    You name it..
    yeah, it is something weird like 12 NM or roughly 7 ft lbs, like Scotty said.
    Run with the best, or die like the rest, Audi Quattro~SVT Mustang
    B6 A4 3.0-sold
    C5 A6 4.2-sold :(
    C4 A6 2.8-current
    B5 S4 A few mods-current
    I drive an Audi, it isn't in the shop to be repaired. It is in the shop to be maintained.
    At least thats what I tell myself in order to keep a level head!
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    thanks, i am done with the job, but i had a problem, one of my cam chain tensioners valley seal was a pain to get out, i managed to get it out in the end but this came out with it??? Is this an important part? Looks like some kind of filter?
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    Should i just leave it or open up again and try to put it in place?
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    All done. I got a new problem however, fault code P1393 Camshaft Position Sensor Bank 2 (G163): Open Short to Plus. How do i fix it and which One is it, left or on the right side?
    Jan 29 2011
    Made In Germany
    Kelowna, Bc Canada
    Cable was unplugged
    Feb 05 2008
    You name it..
    haha, woops! oh well, it happens.
    B6 A4 3.0-sold
    C5 A6 4.2-sold :(
    C4 A6 2.8-current
