    Mar 17 2008
    Acta, sopa & pipa
    Whats your opinion ?
    I believe that you cannot stop piracy and ACTA will do more harm than good. Government sucks and is full of old snobbish people...
    http://www.megaupload.com/ **> This is just fuc*ed up.
    Senior Member Four Rings Elliott's Avatar
    Oct 28 2007
    While not the most eloquent analysis, I agree. For those unaware, here is a run down of ACTA.
    ACTA is a lot different to SOPA as it covers all intellectual property and not just digital versions.
    The idea of the document is that it takes best practice from around the world and suggests a standard implementation that would allow a Government to create a system that allows them to protect intellectual property rights. It is based entirely on best practice and suggests that it should be altered to take into account the countries existing laws. It isn't a binding document - it is a set of guidelines.
    Now some government's will blindly apply the document, but others won't. Japan has already implemented ACTA several months ago.
    Most of the disagreement (in Europe) to the bill have been because of four reasons:
    The document was written in 'secret'. This is standard procedure for these style of documents - releasing draft editions frequently just causes bad press by those who don't understand the process.
    Those who oppose the EU on principle use any directives passed down by the EU as ammunition to claim that the EU is big brother and every country should leave.
    Those who disagree with any controls on copyright based on the principle that they like getting stuff for free don't like it as it could lead them to get prosecuted.
    Finally those who think that the implementation of the ruling will be taking literally and will never be altered. As with virtually all new regulations there will be teething problems that will need work.
    ACTA has some pros and some cons:
    Cons:
    It's broad definition of what could be classed as an infringement of intellectual property means that it could lead to some unforeseen circumstances (like generic medicines being)
    It suggests that 'lost profits' from the intellectual property owner by the infringer be taken into account when the case comes to court, which is open to abuse
    It's rife for abuse by border control authorities - many companies don't have the most 'honest' border control and may use bribary
    It's relatively loose in terms of its definition of penalties, which will be open to abuse (" sufficiently high to provide a deterrent to future acts of infringement, consistently with the level of penalties applied for crimes of a corresponding gravity."
    Websites are obliged to tell authorities who it was who was infringing copyright if they know
    Pros:
    It creates a standard framework across all countries - you can't plead "It's different in my country!" to get away with it, especially important in an international environment
    It creates a framework that gives guidelines on how things work so that intellectual property owners can't go rogue and do things like take down megaupload without due process
    It relates only to the goods/services etc that relate to the intellectual property infringement - you couldn't close down Reddit because one sub-reddit infringed
    It sets out very clearly that it is the intellectual property holders job to enforce the law
    The rights holder have to provide enough evidence for there to be prima facie an infringement before anything can be seized
    If it turns out the rights holder is wrong then the goods seized have to be in a fit state to be returned to the defendant
    Active Member Two Rings JD6's Avatar
    May 01 2011
    Busted Mtn bike
    S. Cali
    EDIT: ^^What he said
    Josh AKA JD
    B6 A4 DG USP 6MT Quattro
    20% Tint//Stern Snub Mount//ST CO's//Forge 007 DV//034 HFC//RS4 Rear Sway//
    TT 225 Injectors//SouthBend Stage 3//AWE LWFW//B7 S4 F Brakes//GIAC Stage 1+
    If it ain't broke don't fix it...
    False, preventative maintenance FTW
    Mar 17 2008
    Good info, I still think the government is trying to control every piece of already limited freedom we have.
    Pretty interesting.
    http://games.yahoo.com/blogs/plugged...205144239.html
    Active Member Four Rings rollerton's Avatar
    Sep 16 2010
    03' 3.0/MT Avant + 02 S4 Avant+ 67 Speed Buggy
    Central Wash
    I don't know about ACTA, I've heard it's the worst of all. My main and initial problem with SOPA and PIPA is that the language really does very little to stop piracy at all. Everyone agree that both of those bills would hamper Internet growth and create liability for literally anyone who allows content to be published through a service/ portal on the web. Web content and service providers could be summarily shut-down without a chance to even investigate the charges. There-in lies the opportunity for censorship of the worst kind.
    I think the web should only monitored for actual crimes against people, children, human trafficking, etc etc..
    There is an opportunity for crime ANYWHERE, anytime something this ambiguous and vague is presented in the name of liberty its real root lies in the greed of the already insanely rich old white ******s that are screwing us every way they can.
    CONTROL.
    When you're the only one making sense, chances are no one else understands you.
    Support Kaylah!: http://www.audizine.com/forum/showth...=1#post7183644
