Results 1 to 4 of 4
    Stage 2 Banner Advertiser Four Rings PAT@RS WORX's Avatar
    Jul 02 2008
    '01.5 S4 Avant, '12 Q7 TDI, '06 A8
    Washington, NJ
    Redline Speed Worx Presents: Service Specials !
    Service_Promo
    Timing Belt Services
    All Timing Belt “Specials” include Timing belt, Tensioner, Rollers, Metal Water pump, Serpentine belt / Drive belt, coolant, and LABOR.
    VW MK4
    - 1.8T - $ 700.00
    - 2.0L - $ 600.00
    - 1.9TDI - $ 750.00
    VW MK5
    - 2.0T FSI - $ 700.00
    - 1.9TDI - $ 750.00
    VW B5/5.5 Passat
    - 1.8T - $ 700.00
    - 1.9TDI - $750.00
    VW B6 Passat
    AUDI B5 / B6 A4
    - 1.8T - $ 750.00
    - 2.8 V6 - $ 750.00
    - 3.0 V6 - $ 850.00
    AUDI B5 S4
    - 2.7T - $ 800.00
    AUDI B7 A4
    A/C System Services
    All VW / Audi A/C System Services are completed with R-134a refrigerant. All VAG vehicles require +/- 525g or 2LBS of refrigerant; service pricing listed covers up to suggested refrigerant quantities. Vehicles requiring over suggested quantity will have additional charge applied.
    - Recover & Recharge System - $ 150.00
    - Recover, Recharge, Inject Dye, & Leak Inspection - $ 200.00
    Drivetrain Services
    All drivetrain services pricing include required fluids / filters. OEM VW / Audi Fluids & Amsoil used depending on service / vehicle make and model.
    Haldex Service
    - $ 299.00 – OEM VW Fluid & Filter
    DSG Transmission Service
    02J / 02M Transmission Fluid Service
    - $ 135.00 – OEM VW Fluid
    01E Transmission Fluid Service
    - $ 85.00 – AMSOIL 75W-90 Synthetic Gear Lube
    Audi Rear Differential Fluid Service
    - $ 75.00 – AMSOIL 75W-90 Synthetic Gear Lube
    FSI Engine Carbon Cleaning Services
    All service pricing includes all required parts that must be changed / replaced at the time of service. 2.0T FSI vehicle service pricing includes replacement OEM Camshaft Follower.
    VW / AUDI 2.0T FSI
    - $ 650.00
    Audi RS4 / S5 4.2 V8
    - $ 850.00
    Audi S6 5.2 V10
    - $ 1,050.00
    Brake Pad & Rotor Services
    All VW / Audi / BMW / Porsche / Mercedes Benz Brake System services share identical labor rates.
    Single Axle Pad Change
    - $ 90.00
    Single Axle Pad & Rotor Change
    - $ 180.00
    Brake Flush Services
    All VW / Audi Brake Flush Services are completed with ATE Super Blue Synthetic DOT 4 Performance braking fluid
    - $ 100.00
    - $ 250.00 – Mercedes Benz equipped with SBC System. E-Class / SL
    Coolant System Flush Services
    All coolant flush services include the price of the required OEM VW / Audi / Mercedes Benz / BMW / Porsche engine coolant
    - $ 100.00
    Power Steering System Flush Services
    All power steering flush services include the price of the required OEM VW / Audi / Mercedes Benz / BMW / Porsche power steering fluid
    - $ 100.00
    Alignments
    Pricing covers basic starting point costs for vehicles with factory suspension components and/or adjustable coil overs. Vehicles with non-factory aftermarket suspension components; ie. Adjustable control arms due increase the cost of the alignment.
    Front Wheel Drive
    - $ 100.00
    All Wheel Drive
    - $ 150.00
    Lube, Oil, Filter Service
    All vehicle oil change services include Amsoil 5W-40 European Performance Synthetic Blend engine oil as well as OEM VW / Audi / Mercedes Benz / BMW / Porsche engine oil filters.
    Additionally all vehicles receive a 27 point vehicle inspection, setting vehicle tire pressures to spec, as well as topping off windshield washer fluid.
    Engine Oil
    - $ 10.50 / Quart
    - Filter Pricing Varies per vehicle / engine
    Clutch Installation Services
    Front Wheel Drive Transverse
    - $ 300.00
    All Wheel Drive Longitudinal
    - $ 700.00
    Exhaust System Installation
    Pricing of installation includes both OEM / Aftermarket bolt on accessories, if modification is required to either exhaust system or vehicle for installation pricing is increased accordingly.
    VW MK5 / 6 FSI & TSI
    - $ 150.00 – Downpipe
    - $ 100.00 – Catback
    Audi B5 S4 2.7T
    - $ 450.00 – Downpipes / Does Not include replacement hardware, or gaskets
    Audi B5 / B6 / B7 / B8
    Pricing does not include installation of catback exhaust systems on vehicles such as Audi RS4 ( Valved ), Audi R8 etc.
    - $ 150.00 – Catback Exhaust Systems
    Suspension System Installations
    VW MK3 / MK4 / MK5 / MK6
    - $ 300.00 Shocks / Struts & Springs
    - $ 300.00 Aftermarket Coilover Suspension Systems w/o remote reservoirs.
    .: Redline Speed Worx :. 908.223.7477
    Tri-State's Premier APR Installation Center
    German Automotive Repair, Performance & Fabrication
    Shop Life - Click Me ! | We Complete Specialty Alignments !
    Jul 02 2008
    Washington, NJ
    Get your maintenance / service needs done before the quickly approaching show season !
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Pat - for the carbon cleaning for the 2.0T, do you take the the head off? curious. i might have a few friends that are interested. group buy?
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jul 02 2008
    Washington, NJ
    We can take the head off, but for our normal service we do not ! Just the intake manifold.
