To usher 2012, the team at EuroCode Tuning is offer expert complimentary installation for the first 10 customers in 2012 that purchase APR's 2.0 TSI S3/Golf R K04 Conversion System from us. Priced at $2649.00 for transverse applications and $2999.00 for longitudinal, no system provides more bang for your buck than APR's K04!!
Our expert complimentary installation includes the following:
  • Remove factory turbo and install APR's 2.0 TSI S3/Golf R K04 Conversion System $800.00 value
  • Remove ECM and flash with APR's patented EMCS engine management calibration $150.00 value
  • Flush coolant system and fill with OEM G12 coolant $50.00 value
  • Five litres of Motul 8100 X-cess 502 00/505 00 fully synthetic oil with new OEM oil filter $90.00 value
  • Total savings of $1090.00
Components
APR provides all hardware and software needed to ensure a complete install. All items which can be preassembled on the turbocharger come preassembled by APR. The APR K04 turbocharger system consisting of the following:
  • APR EMCS Software
  • APR Modified OEM K04 Turbocharger with Billet Compressor Wheel, Stainless Steel Exhaust Manifold, N75 Solenoid and Wastegate Actuator
  • APR CNC Turbo Outlet Flange
  • APR Turbo to Turbo Outlet Flange O-Ring
  • APR Turbo to Turbo Outlet Screws (3x)
  • APR Turbo Outlet Silicon Hoses
  • APR Turbo Outlet Hose Clamps (2x)
  • APR CNC Compressor Cover DV Mounting Flange
  • APR Turbo to DV Mounting Flange O-Rings (2x)
  • APR Turbo to DV Mounting Flange Screws (3x)
  • OEM DV Mounting Screws (3x)
  • OEM DV Mounting Screw Lock Washers (3x)
  • APR Laser Cut PCV Port Cover
  • APR PCV Port Cover Gasket
  • OEM PCV Port Cover Screws (2x)
  • OEM PCV Port Cover Screw Lock Washers (2x)
  • OEM Turbo Manifold Gasket
  • OEM Turbo Manifold Nuts (4x)
  • OEM Downpipe Studs (4x)
  • OEM Downpipe Nuts (4x)
  • OEM Downpipe Gasket
  • OEM EVAP Line One Time Use Hose Clamps (3x)
  • OEM Oil Return Line Gasket (2x)
  • OEM Oil Feed Line Washers (2x)
  • OEM Coolant Feed Line Washers (2x)
  • OEM Coolant Return Line Washers (2x)
Stealthy OEM Appearance
APR's S3 K04 Turbocharger Conversion System is constructed from OEM parts and appears OEM. It's easy to install and 100% reversible. Every OEM part is fully Plug and Play:
  • Exhaust (Upgrade Highly Recommended)
  • Intercooler (Upgrade Highly Recommended)
  • Intake (Upgrade Highly Recommended)
  • Diverter Valve
  • Positive Crankcase Ventilation Lines
  • EVAP Lines
  • Coolant Lines
  • Oil Lines
  • Turbo Support Brace
Dyno Performance
Local installation we performed
To schedule and appointment or if you have any questions, please feel free to call us at 310-294-8108 or email info@ecodetuning.com
